HP Z2 G4 Intel Xeon E-2104G 16GB 512GB SSD Windows 10 Pro
Quicklinx: DQHCWS00 Mfr#: 4RW99EA#ABU
Processor Type: Xeon
Operating System: Windows 10 Pro 64-bit Edition
Installed Memory: 16GB, 16GB
Hard Drive Capacity: 512GB
Storage Type: SSD
  • Xeon
£1,218.95 ex VAT
£1,462.74 inc VAT
Get next-level performance with a remarkably small and versatile device that can handle single and multi-threaded software. With the ability to support the latest technology and workforce demands, it's the obvious choice for the modern workplace.
  • Uncompromised power
    Whether designing in 3D or running multiple applications at once, high-speed CPUs and optional NVIDIA Quadro P1000 graphics optimize your performance. Plus, leading software certifications mean reliable performance throughout your workflow.
  • A perfect fit for any environment
    Improve your workspace with the stunning, versatile design. Mount under a desk, behind a display or in a rack. Flexible I/O ports for peripheral and connectivity needs let you create the ideal setup-from the office to the shop floor to the data center.
  • HP's most secure and manageable workstations
    Get powerful protection from evolving malware threats with self-healing, hardware-enforced security solutions like HP Sure Start Gen4 which protects against BIOS attacks. Plus, easily manage multiple devices with the HP Manageability Integration Kit Gen2 .
HP Workstation Z2 Mini G4 Entry - mini - Xeon E-2104G 3.2 GHz - 16 GB - SSD 512 GB - UK
Workstation - mini
1 x Intel Xeon E-2104G / 3.2 GHz (Quad-Core)
Processor Main Features
Intel Turbo Boost Technology 2
Cache Memory
8 MB
Cache Per Processor
8 MB
RAM
16 GB (installed) / 32 GB (max) - DDR4 SDRAM - non-ECC - PC4-21333
Storage Controller
SATA (SATA 6Gb/s)
Hard Drive
SSD 512 GB - PCI Express 3.0 x4 - M.2 2280 - HP Z Turbo Drive G2, NVM Express (NVMe)
Optical Storage
No optical drive
Graphics Controller
Intel HD Graphics P630 Shared Video Memory (UMA)
Audio Output
Stereo
GigE
Keyboard
OS Provided
Space grey with black chrome accents
21.6 cm x 21.6 cm x 5.8 cm
1.93 kg
Limited warranty - parts and labour - 3 years - on-site
Workstation
Product Form Factor
Mini
Built-in Devices
Speaker
Embedded Security
Trusted Platform Module (TPM 2.0) Security Chip
Processor / Chipset
CPU
Number of Cores
Quad-Core
CPU Qty
1
Max CPU Qty
1
Chipset Type
Intel C246
Cache Memory
Installed Size
8 MB
Cache Per Processor
8 MB
RAM
Installed Size
16 GB / 32 GB (max)
Effective Memory Speed
2666 MHz
Rated Memory Speed
2666 MHz
Memory Specification Compliance
PC4-21333
SO-DIMM 260-pin
Slots
2 (Total) / 0 (empty)
Configuration Features
2 x 8 GB
Hard Drive
SSD - M.2 2280
1 x 512 GB
Interface Type
PCI Express 3.0 x4
Storage Controller
1 x SATA
Controller Interface Type
SATA 6Gb/s
Optical Storage
No optical drive
Monitor
Monitor Type
None.
Graphics Controller
Graphics Processor
Video Interfaces
DisplayPort
Audio Output
Sound Output Mode
Stereo
High Definition Audio
Input Device
Mouse, keyboard
Keyboard
Keyboard Name
HP USB Business Slim Keyboard
USB
Localization & Layout
Mouse
Optical
USB
Ethernet Controller
Intel I219-LM
Remote Management Protocol
ASF 2.0
Wake on LAN (WoL), PXE support
IEEE 802.3, IEEE 802.3u, IEEE 802.3i, IEEE 802.3z, IEEE 802.1Q, IEEE 802.1p, IEEE 802.1as, IEEE 802.3az
Bays
1 (total) / 1 (free) x internal 2.5"
Slots
1 (total) / 1 (free) x M.2 Card - 2230 (x1 mode) , 1 (total) / 0 (free) x M.2 Card - 2280 (x4 mode)
4 x USB 3.0 (2 front, 2 rear) (one of them is charging) , 1 x headphones/microphone (1 in front) , 1 x LAN (Gigabit Ethernet) , 1 x DisplayPort , USB-C 3.1 Gen 2 (charging)
Theft/Intrusion Protection
Security Slot Type
Kensington security slot
VESA Mounting Interface
ACPI, RoHS, WEEE, low halogen
Power adapter
Nominal Voltage
Power Factor Correction
Yes (active)
Operating System / Software
OS Provided
Windows 10 Pro 64-bit Edition English
Software
HP Performance Advisor, HP PC Hardware Diagnostics UEFI, HP Remote Graphics Software 7
21.6 cm
21.6 cm
5.8 cm
1.93 kg
5 °C
35 °C
10 - 85% (non-condensing)
Storage Type: SSD
Processor Model: E-2104G
Type: Workstation
Case Style: Ultra small form factor
Display: not included
Optical Storage: None
Brand: HP
Price Range Ex VAT: 1000 - 1500
