Get next-level performance with a remarkably small and versatile device that can handle single and multi-threaded software. With the ability to support the latest technology and workforce demands, it's the obvious choice for the modern workplace.
Windows 10 Pro 64
Work without compromising on performance or security with Windows 10 Pro, powered by HP's collaboration and connectivity technology. -
Intel Core i7 processor
Run several CPU–heavy programs simultaneously without sacrificing performance with an Intel Core i7 processor.
- HP Workstation Z2 Mini G4 Entry - mini - Core i7 8700 3.2 GHz - 8 GB - SSD 256 GB - UK
- Workstation - mini
- Localisation
- Processor
- 1 x Intel Core i7 (8th Gen) 8700 / 3.2 GHz (4.6 GHz) (6-core)
- Processor Main Features
- Intel Turbo Boost Technology 2
- Cache Memory
- 12 MB
- Cache Per Processor
- 12 MB
- RAM
- 8 GB (installed) / 32 GB (max) - DDR4 SDRAM - non-ECC - PC4-21333
- Storage Controller
- SATA (SATA 6Gb/s)
- Hard Drive
- SSD 256 GB - PCI Express 3.0 x4 - M.2 2280 - HP Z Turbo Drive G2, NVM Express (NVMe)
- Optical Storage
- No optical drive
- Graphics Controller
- Intel UHD Graphics 630 Shared Video Memory (UMA)
- Audio Output
- Stereo
- Networking
- GigE
- Keyboard
- UK
- Power
- AC 120/230 V (50/60 Hz)
- OS Provided
- Windows 10 Pro 64-bit Edition
- Space grey with black chrome accents
- 21.6 cm x 21.6 cm x 5.8 cm
- 1.93 kg
- Limited warranty - parts and labour - 3 years - on-site
- Workstation
- Product Form Factor
- Mini
- Built-in Devices
- Speaker
- Embedded Security
- Trusted Platform Module (TPM 2.0) Security Chip
- Localisation
Processor / Chipset
- CPU
- Intel Core i7 (8th Gen) 8700 / 3.2 GHz
- Max Turbo Speed
- 4.6 GHz
- Number of Cores
- 6-core
- CPU Qty
- 1
- Max CPU Qty
- 1
- Chipset Type
- Intel C246
Cache Memory
- Installed Size
- 12 MB
- 12 MB
RAM
- Installed Size
- 8 GB / 32 GB (max)
- Technology
- Effective Memory Speed
- 2666 MHz
- Rated Memory Speed
- 2666 MHz
- Memory Specification Compliance
- PC4-21333
- Form Factor
- SO-DIMM 260-pin
- Slots
- 2 (Total) / 1 (empty)
- Configuration Features
- 1 x 8 GB
Hard Drive
- SSD - M.2 2280
- Capacity
- 1 x 256 GB
- Interface Type
Storage Controller
- 1 x SATA
- Controller Interface Type
- SATA 6Gb/s
Optical Storage
- No optical drive
Monitor
- Monitor Type
- None.
Graphics Controller
- Graphics Processor
- Video Interfaces
- DisplayPort
Audio Output
- Sound Output Mode
- Stereo
- High Definition Audio
Input Device
- Mouse, keyboard
Keyboard
- Keyboard Name
- HP USB Business Slim Keyboard
- Interface
- USB
- Localization & Layout
- UK
Mouse
- Technology
- Optical
- Interface
- USB
- Ethernet Controller
- Intel I219-LM
- Data Link Protocol
- Remote Management Protocol
- ASF 2.0
- Wake on LAN (WoL), PXE support
- IEEE 802.3, IEEE 802.3u, IEEE 802.3i, IEEE 802.3z, IEEE 802.1Q, IEEE 802.1p, IEEE 802.1as, IEEE 802.3az
- Bays
- 1 (total) / 1 (free) x internal 2.5"
- Slots
- 1 (total) / 1 (free) x M.2 Card - 2230 (x1 mode) , 1 (total) / 0 (free) x M.2 Card - 2280 (x4 mode)
- 4 x USB 3.0 (2 front, 2 rear) (one of them is charging) , 1 x headphones/microphone (1 in front) , 1 x LAN (Gigabit Ethernet) , 2 x DisplayPort , USB-C 3.1 Gen 2 (charging)
- Theft/Intrusion Protection
- Security Slot Type
- Kensington security slot
- VESA Mounting Interface
- ACPI, RoHS, WEEE, low halogen
- Power adapter
- Voltage Required
- Efficiency
- 88%
- Power Factor Correction
- Yes (active)
Operating System / Software
- OS Provided
- Windows 10 Pro 64-bit Edition English
- 21.6 cm
- 21.6 cm
- 5.8 cm
- 1.93 kg
- 5 °C
- 35 °C
- 10 - 85% (non-condensing)
