Experience server-grade power in a desktop workstation with impressive expandability. Confidently tackle complex workloads like BIM and rendering with up to Ultra 3D graphics and the latest Intel Core or Intel Xeon processors.
Take processing to record speeds
Crush demanding single and multi-threaded workflows and take on aggressive multi-tasking without throttling. We redesigned our proprietary motherboard to give you full performance, while keeping components running cool and quiet. -
Built to expand
Need to swap graphics cards? Increase CPU power? Add specialized PCIe cards? Go for it. Our most expandable entry workstation is an investment that will last for years. -
Safeguard your data
Advanced security features come standard on every Z2 Tower. System safeguards like HP Client Security Suite Gen3 and HP Sure Start Gen4 - the industry's first self-healing BIOS - mean your device is locked down tight, so your data and identity are too.
- HP Workstation Z2 G4 - MT - Core i7 8700 3.2 GHz - 8 GB - HDD 1 TB - UK
- Workstation - mini tower
- Platform Technology
- Intel vPro Technology
- Localisation
- Processor
- 1 x Intel Core i7 (8th Gen) 8700 / 3.2 GHz (4.6 GHz) (6-core)
- Processor Main Features
- Hyper-Threading Technology, Intel Turbo Boost Technology 2, Intel Smart Cache
- Cache Memory
- 12 MB
- Cache Per Processor
- 12 MB
- RAM
- 8 GB (installed) / 64 GB (max) - DDR4 SDRAM - non-ECC - PC4-21333
- Storage Controller
- SATA (SATA 6Gb/s)
- Hard Drive
- HDD 1 TB - SATA 6Gb/s - 7200 rpm
- Optical Storage
- DVD-Writer
- Graphics Controller
- Intel UHD Graphics 630 Dynamic Video Memory Technology 5.0
- Networking
- GigE
- Keyboard
- UK
- Power
- AC 120/230 V (50/60 Hz)
- OS Provided
- Windows 10 Pro 64-bit Edition
- Black
- 16.9 cm x 43.5 cm x 35.6 cm
- 7 kg
- Limited warranty - parts and labour - 3 years - on-site
- Workstation
- Product Form Factor
- Mini tower
- Built-in Devices
- Speaker
- Embedded Security
- Trusted Platform Module (TPM 2.0) Security Chip
- Black
- Localisation
Processor / Chipset
- CPU
- Intel Core i7 (8th Gen) 8700 / 3.2 GHz
- Max Turbo Speed
- 4.6 GHz
- Number of Cores
- 6-core
- CPU Qty
- 1
- Max CPU Qty
- 1
- CPU Upgradability
- Upgradable
- Chipset Type
- Intel C246
Cache Memory
- Installed Size
- 12 MB
- 12 MB
RAM
- Installed Size
- 8 GB / 64 GB (max)
- Technology
- Effective Memory Speed
- 2666 MHz
- Rated Memory Speed
- 2666 MHz
- Memory Specification Compliance
- PC4-21333
- Form Factor
- DIMM 288-pin
- Slots
- 4 (Total) / 2 (empty)
- Configuration Features
- 2 x 4 GB
Hard Drive
- HDD
- Capacity
- 1 x 1 TB
- Interface Type
- SATA 6Gb/s
- Spindle Speed
- 7200 rpm
Storage Controller
- 1 x SATA
- Controller Interface Type
- SATA 6Gb/s
- Channel Qty
- 4
- RAID Level
- RAID 0, RAID 1
Optical Storage
- DVD-Writer DVD-Writer
Monitor
- Monitor Type
- None.
Graphics Controller
- Graphics Processor
- Video Interfaces
- DisplayPort
Audio Output
- High Definition Audio
Input Device
- Mouse, keyboard
Keyboard
- Keyboard Name
- HP Business Slim Keyboard
- Interface
- USB
- Localization & Layout
- UK
Mouse
- Technology
- Optical
- Interface
- USB
- Ethernet Controller
- Intel I219-LM
- Data Link Protocol
- Wake on LAN (WoL), ACPI support, PXE support, Intel Active Management Technology (AMT) 12
- IEEE 802.3, IEEE 802.3u, IEEE 802.3i, IEEE 802.3z, IEEE 802.1Q, IEEE 802.3ab, IEEE 802.1p, IEEE 802.1as, IEEE 802.3az
- Bays
- 2 (total) / 1 (free) x external 5.25" , 2 (total) / 1 (free) x internal 3.5"
- Slots
- 1 (total) / 1 (free) x PCIe 3.0 x16 , 1 (total) / 1 (free) x PCIe 3.0 x16 (x4 mode) , 2 (total) / 2 (free) x PCIe 3.0 x4 (x1 mode) , 2 (total) / 2 (free) x M.2 Card (x4 mode) , 1 (total) / 1 (free) x M.2 Card (x1 mode)
- 6 x USB 3.0 (2 front, 4 rear) (one of them is charging) , 1 x headphones/microphone (1 in front) , 2 x DisplayPort , 2 x USB 2.0 , 1 x LAN (Gigabit Ethernet) , 1 x audio line-in , 1 x audio line-out
- Theft/Intrusion Protection
- Security lock slot (cable lock sold separately), padlock loop
- Security Slot Type
- Kensington security slot
- RoHS, WEEE
- Nominal Voltage
- Power Provided
- 250 Watt
- Efficiency
- 90%
- Power Factor Correction
- Yes (active)
Operating System / Software
- OS Provided
- Windows 10 Pro 64-bit Edition English
- Software
- HP Performance Advisor, HP PC Hardware Diagnostics UEFI, HP Remote Graphics Software 7
- 16.9 cm
- 43.5 cm
- 35.6 cm
- 7 kg
- Shipping Width
- 49.9 cm
- Shipping Depth
- 29.5 cm
- Shipping Height
- 59.9 cm
- Shipping Weight
- 11.47 kg
- 5 °C
- 35 °C
- 10 - 85% (non-condensing)
