Finally a revolutionary mini PC for CAD that delivers breakthrough power and versatility in a small, elegant design. Made by and for design professionals, the Z2 Mini gives you both performance and reliability for the best CAD experience.
Latest Operating Systems
Support your unique user needs with a choice of Windows 10 Pro or Linux operating systems. -
Intel Xeon /Core Processors
Current and next generation Intel Core and Intel Xeon processor options for powerful workstation-class performance. -
NVIDIA Quadro Pro Graphics
Powerful M620 professional graphics from NVIDIA for your more demanding 3D models. -
HP Z Turbo Drive
Reduce boot up, file loading, and response times by revolutionizing how your Z2 Mini handles large files with up to 1.5 TB of storage with the optional HP Z Turbo Drive for a remarkably fast and innovative solution. -
Remarkably Small
At only 5.8 cm (2.3") high the Z2 Mini fits into any office environment. -
Designed for designers
Stylish and sleek. It's what a CAD PC should be.
- HP Workstation Z2 Mini G3 Performance - mini - Xeon E3-1225V5 3.3 GHz - vPro - 16 GB - SSD 256 GB - UK
- Workstation - mini
- Platform Technology
- Intel vPro Platform
- Localisation
- Processor
- 1 x Intel Xeon E3-1225V5 / 3.3 GHz (3.7 GHz) (Quad-Core)
- Processor Socket
- LGA1151 Socket
- Processor Main Features
- Intel Turbo Boost Technology 2, Intel Smart Cache
- Cache Memory
- 8 MB
- Cache Per Processor
- 8 MB
- RAM
- 16 GB (installed) / 32 GB (max) - DDR4 SDRAM - PC4-19200
- Storage Controller
- SATA (SATA 6Gb/s)
- Hard Drive
- SSD 256 GB - PCI Express - M.2 2280 - HP Z Turbo Drive
- Optical Storage
- No optical drive
- Graphics Controller
- NVIDIA Quadro M620 / Intel HD Graphics P530
- Video Memory
- 2 GB GDDR5 SDRAM
- Audio Output
- Stereo
- Networking
- GigE
- Keyboard
- UK
- Power
- AC 120/230 V (50/60 Hz)
- OS Provided
- Windows 10 Pro 64-bit Edition
- Space grey with black chrome accents
- 21.6 cm x 21.6 cm x 5.8 cm
- 2.04 kg
- Limited warranty - parts and labour - 3 years - on-site
- Workstation
- Product Form Factor
- Mini
- Embedded Security
- Trusted Platform Module (TPM 2.0) Security Chip
- Localisation
Processor / Chipset
- CPU
- Intel Xeon E3-1225V5
- Clock Speed
- 3.3 GHz
- Max Turbo Speed
- 3.7 GHz
- Number of Cores
- Quad-Core
- CPU Qty
- 1
- Max CPU Qty
- 1
- CPU Upgradability
- Upgradable
- CPU Socket
- LGA1151 Socket
- Chipset Type
- Intel C236
Cache Memory
- Installed Size
- 8 MB
- 8 MB
RAM
- Installed Size
- 16 GB / 32 GB (max)
- Technology
- DDR4 SDRAM
- Effective Memory Speed
- 2133 MHz
- Rated Memory Speed
- 2400 MHz
- Memory Specification Compliance
- PC4-19200
- Form Factor
- SO-DIMM 260-pin
- Slots
- 2 (Total) / 0 (empty)
- Unbuffered
- Configuration Features
- 2 x 8 GB
- RAM Supported
- 32 GB unbuffered - ECC , 32 GB unbuffered - non-ECC
Hard Drive
- SSD - M.2 2280
- Capacity
- 1 x 256 GB
- Interface Type
- PCI Express
- HP Z Turbo Drive
Storage Controller
- 1 x SATA
- Controller Interface Type
- SATA 6Gb/s
Optical Storage
- No optical drive
Monitor
- Monitor Type
- None.
Graphics Controller
- Graphics Processor
- Video Memory
- 2 GB GDDR5 SDRAM
- Video Interfaces
- DisplayPort
- Max Monitors Supported
- 6
Audio Output
- Sound Output Mode
- Stereo
- High Definition Audio
Input Device
- Mouse, keyboard
Keyboard
- Keyboard Name
- HP Business Slim Keyboard
- Interface
- USB
- Localization & Layout
- UK
Mouse
- Technology
- Laser
- Interface
- USB
- Ethernet Controller
- Intel I219-LM
- Data Link Protocol
- Remote Management Protocol
- ASF 2.0
- Wake on LAN (WoL), PXE support, auto-uplink (auto MDI/MDI-X)
- IEEE 802.3, IEEE 802.3u, IEEE 802.3i, IEEE 802.3z, IEEE 802.1Q, IEEE 802.3ab, IEEE 802.1p, IEEE 802.1as, IEEE 802.3az
- Bays
- 1 (total) / 1 (free) x internal 2.5"
- Slots
- 2 (total) / 0 (free) x SO-DIMM 260-pin , 1 (total) / 0 (free) x CPU , 1 (total) / 1 (free) x M.2 Card - 2230 (x1 mode) , 1 (total) / 0 (free) x M.2 Card - 2280 (x4 mode)
- 4 x USB 3.0 (2 front, 2 rear) (one of them is charging) , 2 x USB-C 3.1 Gen 1 , 1 x LAN (Gigabit Ethernet) , 4 x DisplayPort , 1 x headphones/microphone (1 in front)
- Theft/Intrusion Protection
- Security Slot Type
- Kensington security slot
- ACPI, RoHS, WEEE
- Power adapter
- Voltage Required
- Power Provided
- 200 Watt
- Efficiency
- 89% (230VAC)
- Power Factor Correction
- Yes (active)
Operating System / Software
- OS Provided
- Windows 10 Pro 64-bit Edition English
- 21.6 cm
- 21.6 cm
- 5.8 cm
- 2.04 kg
- 5 °C
- 35 °C
- 8 - 85%
Monitors (1)
HP DreamColour 31.1" 4096x2160 10ms 2xHDMI 2xDisplayPort USB-C LED Monitor | In Stock | £2,821.06 |
Accessories (1)
HP VESA Mount Solution - Mounting kit (wall arm) | In Stock | £64.94 |
Other bundles (2)
HPE DisplayPort To VGA Adapter | In Stock | £13.72 |
HPE DisplayPort DVI-D Adapter | In Stock | £13.23 |
