HP Z1 G2 27" Touchscreen AIO Intel Xeon E3-1226v3 8GB 256GB SSD Windows 8.1 Professional 64-bit
Quicklinx: BD43WS00 Mfr#: G1X48EA#ABU
  • Windows 8.1 Pro 64-bit Edition
  • Xeon
  • IEEE 802.11n
  • Bluetooth 4.0
The HP Z1 G2 Workstation is HP's elegant and innovative all-in-one workstation with a large-screen display. Easily modify and change most components-no tools required. Unleash your creativity with accelerated performance and world-class reliability. Customize your display with optional 10-point touch technology in a stunning edge-to-edge glass design.
  • Spark creativity
    Bring ideas to life faster than ever with the Intel Xeon processor, NVIDIA Quadro graphics, ECC memory and a wide range of ISV certifications.Be wowed and do more with features enabled by HP's cutting-edge engineering, including a high-end professional MXM Graphics cooling module, optional multiple hard drives and an adjustable custom display stand.Connect in a flash and strike productivity with optional high-performance Thunderbolt 2.0 ports located on the side of the HP Z1 G2 for easy accessibility.Take computing performance to another level with more efficient processing thanks to 4th generation Intel Core/Xeon E3 processors.A wide range of professional 3D graphics options from NVIDIA give you the confidence that you're working with the very best tools available. Or, choose Intel's new integrated graphics for the ultimate visual experience.
  • Powerful and refined
    Change most components or make upgrades on your own without tools or a service technician. Simply snap open the chassis and customize to fit your needs.Your most frequently used data is quickly accessible on the HP Z1 G2 Workstation with optional mSATA storage technology that provides fast storage and cache for OS and applications.Easily plug in devices to accessible I/O ports and enjoy the simplicity of push button display movement into and out of service mode on the HP Z1 G2 Workstation.Treat your ears to premium audio features on the HP Z1 G2 Workstation, including dual cone, front-facing speakers and DTS Studio Sound.
  • Versatile view
    Reach for success on the HP Z1 G2 Workstation with the optional 10-point touchscreen. Get creativity flowing and let your fingers fly over the stunning edge-to-edge glass display.Step into the light. Reduce reflection and work with clarity on the HP Z1 G2 Workstation with no-glass, anti-glare display.Your work never looked better. Let your ideas shine on the HP Z1 G2 Workstation Next Generation 68,6 cm (27') diagonal IPS display (2560x1440).
HP Workstation Z1 G2 - all-in-one - Xeon E3-1226V3 3.3 GHz - vPro - 8 GB - SSD 256 GB - LED 27"
Workstation - all-in-one - power-on password, USB port control, chassis intrusion detection, Intel Active Management Technology (iAMT), audio ports control, network port control, Setup Password
Platform Technology
Intel vPro Platform
1 x Intel Xeon E3-1226V3 / 3.3 GHz (, up to 3.7 GHz, (Quad-Core)
Processor Socket
LGA1150 Socket
Processor Main Features
Intel Turbo Boost Technology 2
Cache Memory
8 MB
Cache Per Processor
8 MB
RAM
8 GB (installed) / 32 GB (max) - DDR3 SDRAM - ECC - PC3-14900
Storage Controller
SATA (SATA 6Gb/s)
Hard Drive
SSD 256 GB - SATA 6Gb/s - mSATA
Optical Storage
DVD SuperMulti
Card Reader
Monitor
27" - LED - 2560 x 1440 - 16:9
Graphics Controller
Intel HD Graphics P4600 Dynamic Video Memory Technology 5.0
Audio Output
Stereo - integrated
GigE, 802.11a, 802.11b/g/n, Bluetooth 4.0, Wi-Fi 5
OS Provided
Software Included
PDF Complete Corporate Edition, HP Performance Advisor, HP Remote Graphics Software 6
66.04 cm x 41.91 cm x 53 cm
21.32 kg
Environmental Standards
ENERGY STAR Qualified
Limited warranty - parts and labour - 3 years - on-site - response time: next business day
Platform Technology
Intel vPro Platform
Workstation
Recommended Use
Small business, corporate business
Product Form Factor
All-in-one
Built-in Devices
Stereo speakers
Embedded Security
Trusted Platform Module (TPM 1.2) Security Chip
Processor / Chipset
CPU
Clock Speed
3.3 GHz
Max Turbo Speed
3.7 GHz
Number of Cores
Quad-Core
CPU Qty
1
Max CPU Qty
1
CPU Upgradability
Upgradable
CPU Socket
LGA1150 Socket
Chipset Type
Intel C226
Cache Memory
Installed Size
8 MB
Cache Per Processor
8 MB
RAM
Installed Size
8 GB / 32 GB (max)
DDR3 SDRAM - ECC
Effective Memory Speed
1600 MHz
Rated Memory Speed
1866 MHz
Memory Specification Compliance
PC3-14900
DIMM 240-pin
Slots
4 (Total) / 2 (empty)
Unbuffered, dual channel memory architecture
Configuration Features
2 x 4 GB
RAM Supported
PC3-14900 - 16 GB unbuffered - non-ECC , PC3-14900 - 32 GB unbuffered - ECC
Hard Drive
SSD - mSATA
1 x 256 GB
Interface Type
SATA 6Gb/s
Storage Controller
1 x SATA - integrated
Controller Interface Type
SATA 6Gb/s
Channel Qty
3
RAID Level
RAID 0, RAID 1
Optical Storage
DVD±RW (±R DL) / DVD-RAM DVD SuperMulti - SATA
Card Reader
Card reader
Supported Flash Memory Cards
SD Memory Card
Monitor
Monitor Type
LED - IPS
Diagonal Size
27"
Native Resolution
2560 x 1440
Widescreen Display
Image Aspect Ratio
16:9
Horizontal Viewing Angle
178
Vertical Viewing Angle
178
Colour Gamut
100% sRGB (CIE 1931), 77% NTSC (CIE 1931)
Pixel Pitch
0.2331 mm
Response Time
14 ms
Image Brightness
380 cd/m²
Image Contrast Ratio
1000:1
Graphics Controller
Integrated
Graphics Processor
Video Interfaces
DisplayPort
Audio Output
Integrated
Sound Output Mode
Stereo
High Definition Audio
Speakers Included
2 x right / left channel
Camera
Integrated
Resolution (MP)
2 Megapixel
Input Device
Mouse, keyboard
Keyboard
Wireless
Mouse
Wireless
Audio Input
Stereo microphone
Ethernet Controller
Intel I217-LM
Wireless LAN Supported
Wireless NIC
Intel Dual Band Wireless-AC 7260
Ethernet, Fast Ethernet, Gigabit Ethernet, IEEE 802.11b, IEEE 802.11a, IEEE 802.11g, IEEE 802.11n, Bluetooth 4.0, IEEE 802.11ac
Remote Management Protocol
DMI
Wake on LAN (WoL), ACPI support, PXE support, auto-uplink (auto MDI/MDI-X)
IEEE 802.3, IEEE 802.3u, IEEE 802.3i, IEEE 802.3z, IEEE 802.1Q, IEEE 802.3ab, IEEE 802.1p, IEEE 802.11b, IEEE 802.11a, IEEE 802.11g, IEEE 802.1as, IEEE 802.11n, IEEE 802.3az
Bays
1 (total) / 1 (free) x internal 2 x 2.5"/3.5" shared
Slots
1 (total) / 0 (free) x CPU , 4 (total) / 2 (free) x DIMM 240-pin , 1 (total) / 1 (free) x MXM 3.1 (x16 mode) , 2 (total) / 1 (free) x Mini PCIe 2.0/mSATA - full-length
2 x USB 3.0 , 1 x headphones , 1 x microphone , 1 x DisplayPort , 5 x USB 2.0 (4 rear, 1 internal) , 1 x LAN (Gigabit Ethernet) , 1 x audio line-out (subwoofer) , 1 x SPDIF output , 1 x audio line-in , 1 x audio line-out
Power-on password, USB port control, chassis intrusion detection, Intel Active Management Technology (iAMT), audio ports control, network port control, Setup Password
Theft/Intrusion Protection
RoHS, WEEE, ACPI 4.0
Power supply
Power Provided
400 Watt
80 PLUS Certification
80 PLUS
Efficiency
90%
Power Factor Correction
Yes (active)
Operating System / Software
OS Provided
Software
Sustainability Information
ENERGY STAR Certified
66.04 cm
41.91 cm
53 cm
21.32 kg
5 °C
35 °C
8 - 85% (non-condensing)
