Introducing power without the tower. The new HP Z1 is the world's first all-in-one workstation featuring a 68,6 cm (27") diagonal display that snaps open to let you swap out parts and make upgrades . No tools required . Unleash your creativity with accelerated performance, 68,6 cm (27") LED-backlit display that supports over a billion colors , and HP's world-class reliability. The HP Z1. Advanced design from A to Z.
Open the display. Expand your potential
Get the simplicity of an all-in-one design, the power of a workstation, and the beauty of a 68,6 cm (27") display . Upgrade or add a hard drive, graphics card, or memory by snapping it open. And enjoy the control of easily swapping out parts on your own.With whisper quiet acoustics, you get high-performance with no distraction. Have face-to-face meetings and capture HD-quality video with the built-in HD webcam . Plus take advantage of SRS Premium Sound to give your work the high-quality audio it deserves. -
Workstation performance without compromise
Get the only all-in-one workstation featuring a 68,6 cm (27") diagonal display with quad-core Intel Xeon processors . And stay one step ahead of your imagination.Your most important work deserves the best memory. Avoid single-bit memory errors, help preserve data integrity, and make system crashes a thing of the past with supported EEC memory. -
High performance graphics. Incredible from every angle
Use professional NVIDIA Quadro graphics for blazing fast rendering and performance, and spend more time being your creative best.See your work clearly on a 68,6 (27") diagonal LED-backlit IPS display that supports over a billion colors . With a wide, 178 degree viewing angle and an IPS panel, it's professional any way you look at it. -
Build the machine you want to drive
Choose from a variety of storage types, including 7.2K and 10K SATA, SSD, or optional RAID configurations. Always be confident you have the tools to get the job done.A professional workstation calls for a variety of I/O choices, including internal and external PCI Express slots, and USB 2.0 and 3.0 for blazing fast speeds. -
World-class reliability from HP
We design systems to be fundamentally more reliable. Then we rigorously test and optimize components to ensure it. Whether it is graphics cards, memory, or operating systems, you're able to focus on your projects, not your machine.With thoroughly tested and certified hardware and software combinations, you'll enjoy peace of mind knowing the tools you demand will work when you need them.
- HP Workstation Z1 - all-in-one - Xeon E3-1245V2 3.4 GHz - vPro - 8 GB - SSD 256 GB - LED 27"
- Workstation - all-in-one - system password, power-on password, USB port control, chassis intrusion detection
- Platform Technology
- Intel vPro Platform
- Localisation
- Processor
- 1 x Intel Xeon E3-1245V2 / 3.4 GHz (3.8 GHz) (Quad-Core)
- Processor Socket
- LGA1155 Socket
- Processor Main Features
- Hyper-Threading Technology, Intel Turbo Boost Technology 2
- Cache Memory
- 8 MB
- Cache Per Processor
- 8 MB
- RAM
- 8 GB (installed) / 32 GB (max) - DDR3 SDRAM - ECC - PC3-12800
- Storage Controller
- SATA (SATA 6Gb/s / SATA 3Gb/s)
- Hard Drive
- SSD 256 GB - SATA 3Gb/s
- Optical Storage
- Blu-ray Writer
- Card Reader
- 4 in 1
- Monitor
- 27" - LED - 2560 x 1440 - 16:9
- Graphics Controller
- MXM 3.0 Type B - NVIDIA Quadro K3000M
- Video Memory
- 2 GB GDDR5 SDRAM
- Audio Output
- Stereo - integrated
- Networking
- GigE, Bluetooth, 802.11a, 802.11b/g/n
- Power
- AC 120/230 V (50/60 Hz)
- OS Provided
- Microsoft Windows 7 Professional 64-bit Edition (downgrade from Windows 8 Pro 64-bit) + Windows 8 Pro 64-bit Licence
- Software Included
- Intervideo WinDVD, Roxio Easy Media Creator, HP Power Assistant, PDF Complete Corporate Edition, HP Remote Graphics Software 5
- Jack black
- 66.04 cm x 41.91 cm x 58.42 cm
- 21.32 kg
- Limited warranty - parts and labour - 3 years - on-site - response time: next business day
- Workstation
- Recommended Use
- Small business, corporate business
- Product Form Factor
- All-in-one
- Built-in Devices
- Stereo speakers
- Embedded Security
- Trusted Platform Module (TPM 1.2) Security Chip
- Jack black
- Localisation
Processor / Chipset
- CPU
- Intel Xeon E3-1245V2
- Clock Speed
- 3.4 GHz
- Max Turbo Speed
- 3.8 GHz
- Number of Cores
- Quad-Core
- CPU Qty
- 1
- Max CPU Qty
- 1
- CPU Upgradability
- Upgradable
- CPU Socket
- LGA1155 Socket
- Chipset Type
- Intel C206
Cache Memory
- Installed Size
- 8 MB
- 8 MB
RAM
- Installed Size
- 8 GB / 32 GB (max)
- Technology
- DDR3 SDRAM - ECC
- Effective Memory Speed
- 1600 MHz
- Rated Memory Speed
- 1600 MHz
- Memory Specification Compliance
- PC3-12800
- Form Factor
- DIMM 240-pin
- Slots
- 4 (Total)
- Unbuffered, dual channel memory architecture
- RAM Supported
- PC3-12800 - 8 GB unbuffered - non-ECC , PC3-12800 - 32 GB unbuffered - ECC
Hard Drive
- SSD
- Capacity
- 1 x 256 GB
- Interface Type
- SATA 3Gb/s
Storage Controller
- 1 x SATA - integrated
- Controller Interface Type
- SATA 6Gb/s / SATA 3Gb/s
- Channel Qty
- 3
- RAID Level
- RAID 0, RAID 1
Optical Storage
- BD-RE Blu-ray Writer - SATA
Card Reader
- 4 in 1 card reader
Monitor
- Monitor Type
- LED
- Diagonal Size
- 27"
- Native Resolution
- 2560 x 1440
- Widescreen Display
- Image Aspect Ratio
- 16:9
- Horizontal Viewing Angle
- 178
- Vertical Viewing Angle
- 178
- Colour Gamut
- 100% sRGB (CIE 1931), 77% NTSC (CIE 1931), 96% NTSC (CIE 1976)
- Pixel Pitch
- 0.2331 mm
- Response Time
- 12 ms
- Image Brightness
- 380 cd/m²
- Image Contrast Ratio
- 1000:1
Graphics Controller
- Plug-in card
- Interface Type
- MXM 3.0 Type B
- Graphics Processor
- Video Memory
- 2 GB GDDR5 SDRAM
- Video Interfaces
- DisplayPort
Audio Output
- Integrated
- Sound Output Mode
- Stereo
- High Definition Audio
- Speakers Included
- 2 x right / left channel
Camera
- Form Factor
- Integrated
- Resolution (MP)
- 2 Megapixel
Input Device
- Mouse, keyboard
Audio Input
- Stereo microphone
- Ethernet Controller
- Intel 82579LM
- Wireless LAN Supported
- Data Link Protocol
- Ethernet, Fast Ethernet, Gigabit Ethernet, Bluetooth, IEEE 802.11b, IEEE 802.11a, IEEE 802.11g, IEEE 802.11n
- Remote Management Protocol
- DMI
- Wake on LAN (WoL), PXE support, auto-uplink (auto MDI/MDI-X)
- IEEE 802.2, IEEE 802.3, IEEE 802.3u, IEEE 802.1Q, IEEE 802.3ab, IEEE 802.1p, IEEE 802.11b, IEEE 802.11a, IEEE 802.11g, IEEE 802.11n, IEEE 802.3az
- Bays
- Internal 2 x 2.5"/3.5" shared
- Slots
- 1 (total) / 0 (free) x CPU , 4 DIMM 240-pin , 1 (total) / 0 (free) x MXM (x16 mode) , 3 (total) / 2 (free) x PCIe 2.0 Mini Card
- 2 x USB 3.0 , 1 x FireWire , 1 x headphones , 1 x audio line-in/microphone , 1 x DisplayPort , 4 x USB 2.0 , 1 x LAN (Gigabit Ethernet) , 1 x audio line-out (subwoofer) , 1 x TOSLINK , 1 x audio line-in , 1 x audio line-out
- System password, power-on password, USB port control, chassis intrusion detection
- Theft/Intrusion Protection
- RoHS, WEEE
- Power supply
- Voltage Required
- Power Provided
- 400 Watt
- 80 PLUS Certification
- 80 PLUS
- Efficiency
- 90%
- Power Factor Correction
- Yes (active)
Operating System / Software
- OS Provided
- Microsoft Windows 7 Professional 64-bit Edition (available through downgrade rights from Windows 8 Pro 64-bit) + Windows 8 Pro 64-bit Licence
- Software
- 66.04 cm
- 41.91 cm
- 58.42 cm
- 21.32 kg
- 5 °C
- 35 °C
- 8 - 85% (non-condensing)
