HP Z1 AIO 27" Intel Core i3-3220 8GB 256GB SSD Windows 7 Professional
Quicklinx: 98TFWS00 Mfr#: WM561EA#ABU
  • Microsoft Windows 7 Professional 64-bit Edition
  • Core i3
  • BD-RE
  • IEEE 802.11n
Introducing power without the tower. The new HP Z1 is the world's first all-in-one workstation featuring a 68,6 cm (27") diagonal display that snaps open to let you swap out parts and make upgrades . No tools required . Unleash your creativity with accelerated performance, 68,6 cm (27") LED-backlit display that supports over a billion colors , and HP's world-class reliability. The HP Z1. Advanced design from A to Z.
  • Open the display. Expand your potential
    Get the simplicity of an all-in-one design, the power of a workstation, and the beauty of a 68,6 cm (27") display . Upgrade or add a hard drive, graphics card, or memory by snapping it open. And enjoy the control of easily swapping out parts on your own.With whisper quiet acoustics, you get high-performance with no distraction. Have face-to-face meetings and capture HD-quality video with the built-in HD webcam . Plus take advantage of SRS Premium Sound to give your work the high-quality audio it deserves.
  • Workstation performance without compromise
    Get the only all-in-one workstation featuring a 68,6 cm (27") diagonal display with quad-core Intel Xeon processors . And stay one step ahead of your imagination.Your most important work deserves the best memory. Avoid single-bit memory errors, help preserve data integrity, and make system crashes a thing of the past with supported EEC memory.
  • High performance graphics. Incredible from every angle
    Use professional NVIDIA Quadro graphics for blazing fast rendering and performance, and spend more time being your creative best.See your work clearly on a 68,6 (27") diagonal LED-backlit IPS display that supports over a billion colors . With a wide, 178 degree viewing angle and an IPS panel, it's professional any way you look at it.
  • Build the machine you want to drive
    Choose from a variety of storage types, including 7.2K and 10K SATA, SSD, or optional RAID configurations. Always be confident you have the tools to get the job done.A professional workstation calls for a variety of I/O choices, including internal and external PCI Express slots, and USB 2.0 and 3.0 for blazing fast speeds.
  • World-class reliability from HP
    We design systems to be fundamentally more reliable. Then we rigorously test and optimize components to ensure it. Whether it is graphics cards, memory, or operating systems, you're able to focus on your projects, not your machine.With thoroughly tested and certified hardware and software combinations, you'll enjoy peace of mind knowing the tools you demand will work when you need them.
HP Workstation Z1 - all-in-one - Core i3 3220 3.3 GHz - 8 GB - SSD 256 GB - LED 27"
Workstation - all-in-one - system password, power-on password, USB port control, chassis intrusion detection
1 x Intel Core i3 (3rd Gen) 3220 / 3.3 GHz (Dual-Core)
Processor Socket
LGA1155 Socket
Processor Main Features
Hyper-Threading Technology
Cache Memory
3 MB
Cache Per Processor
3 MB
RAM
8 GB (installed) / 32 GB (max) - DDR3 SDRAM - PC3-12800
Storage Controller
SATA (SATA 6Gb/s / SATA 3Gb/s)
Hard Drive
SSD 256 GB - SATA 3Gb/s
Optical Storage
Blu-ray Writer
Card Reader
4 in 1
Monitor
27" - LED - 2560 x 1440 - 16:9
Graphics Controller
Intel HD Graphics 2500 Dynamic Video Memory Technology
Audio Output
Stereo - integrated
GigE, Bluetooth, 802.11a, 802.11b/g/n
OS Provided
Microsoft Windows 7 Professional 64-bit Edition (downgrade from Windows 8 Pro 64-bit) + Windows 8 Pro 64-bit Licence
Software Included
Intervideo WinDVD, Roxio Easy Media Creator, HP Power Assistant, PDF Complete Corporate Edition, HP Remote Graphics Software 5
Jack black
66.04 cm x 41.91 cm x 58.42 cm
21.32 kg
Limited warranty - parts and labour - 3 years - on-site - response time: next business day
Workstation
Recommended Use
Small business, corporate business
Product Form Factor
All-in-one
Built-in Devices
Stereo speakers
Embedded Security
Trusted Platform Module (TPM 1.2) Security Chip
Jack black
Processor / Chipset
CPU
Clock Speed
3.3 GHz
Number of Cores
Dual-Core
CPU Qty
1
Max CPU Qty
1
CPU Upgradability
Upgradable
CPU Socket
LGA1155 Socket
Chipset Type
Intel C206
Cache Memory
Installed Size
3 MB
Cache Per Processor
3 MB
RAM
Installed Size
8 GB / 32 GB (max)
DDR3 SDRAM
Effective Memory Speed
1600 MHz
Rated Memory Speed
1600 MHz
Memory Specification Compliance
PC3-12800
DIMM 240-pin
Slots
4 (Total)
Unbuffered, dual channel memory architecture
RAM Supported
PC3-12800 - 8 GB unbuffered - non-ECC , PC3-12800 - 32 GB unbuffered - ECC
Hard Drive
SSD
1 x 256 GB
Interface Type
SATA 3Gb/s
Storage Controller
1 x SATA - integrated
Controller Interface Type
Channel Qty
3
RAID Level
RAID 0, RAID 1
Optical Storage
BD-RE Blu-ray Writer - SATA
Card Reader
4 in 1 card reader
Monitor
Monitor Type
LED
Diagonal Size
27"
Native Resolution
2560 x 1440
Widescreen Display
Image Aspect Ratio
16:9
Horizontal Viewing Angle
178
Vertical Viewing Angle
178
Colour Gamut
100% sRGB (CIE 1931), 77% NTSC (CIE 1931), 96% NTSC (CIE 1976)
Pixel Pitch
0.2331 mm
Response Time
12 ms
Image Brightness
380 cd/m²
Image Contrast Ratio
1000:1
Graphics Controller
Integrated
Graphics Processor
Video Interfaces
DisplayPort
Max Monitors Supported
2
Audio Output
Integrated
Sound Output Mode
Stereo
High Definition Audio
Speakers Included
2 x right / left channel
Camera
Integrated
Resolution (MP)
2 Megapixel
Input Device
Mouse, keyboard
Audio Input
Stereo microphone
Ethernet Controller
Intel 82579LM
Wireless LAN Supported
Ethernet, Fast Ethernet, Gigabit Ethernet, Bluetooth, IEEE 802.11b, IEEE 802.11a, IEEE 802.11g, IEEE 802.11n
Remote Management Protocol
DMI
Wake on LAN (WoL), PXE support, auto-uplink (auto MDI/MDI-X)
IEEE 802.2, IEEE 802.3, IEEE 802.3u, IEEE 802.1Q, IEEE 802.3ab, IEEE 802.1p, IEEE 802.11b, IEEE 802.11a, IEEE 802.11g, IEEE 802.11n, IEEE 802.3az
Bays
Internal 2 x 2.5"/3.5" shared
Slots
1 (total) / 0 (free) x CPU , 4 DIMM 240-pin , 1 (total) / 1 (free) x MXM (x16 mode) , 3 (total) / 2 (free) x PCIe 2.0 Mini Card
2 x USB 3.0 , 1 x FireWire , 1 x headphones , 1 x audio line-in/microphone , 1 x DisplayPort , 4 x USB 2.0 , 1 x LAN (Gigabit Ethernet) , 1 x audio line-out (subwoofer) , 1 x TOSLINK , 1 x audio line-in , 1 x audio line-out
System password, power-on password, USB port control, chassis intrusion detection
Theft/Intrusion Protection
RoHS, WEEE
Power supply
Power Provided
400 Watt
80 PLUS Certification
80 PLUS
Efficiency
90%
Power Factor Correction
Yes (active)
Operating System / Software
OS Provided
Microsoft Windows 7 Professional 64-bit Edition (available through downgrade rights from Windows 8 Pro 64-bit) + Windows 8 Pro 64-bit Licence
Software
66.04 cm
41.91 cm
58.42 cm
21.32 kg
5 °C
35 °C
8 - 85% (non-condensing)
