Be a productive powerhouse with the sleek HP Z23n G2 58.42 cm (23") Display. This virtually seamless Full HD display is factory-tested for reliability and longevity with integrated color calibration, uninterrupted multi-screen tiling, and expansive device connections.
Streamline productivity with screens for every project
Multi-task without disruptions across multiple displays with a 3-sided micro-edge bezel on each screen. Get stunning visuals from the 1920 x 1080 resolution, 16:9 aspect ratio, 58.42 cm (23") diagonal IPS screen and over 2 million pixels. -
Out-of-this-world color right out of the box
Consistent, accurate color between displays and from project to project is easier than ever with factory color calibration from the very first time you power on. -
Quality from the start
We rigorously test each HP Z Display to help ensure it's a reliable, long-life visual solution, and back it up with the HP Zero Bright Dot Guarantee, HP's most stringent pixel policy, which replaces the screen if even one bright sub-pixel fails. -
Big ideas for small spaces
Make the most of your available workspace by mounting powerful machines like the HP Z2 Mini Workstation directly behind the display for a compact, efficient, single-footprint solution.
- HP Z23n G2 - LED monitor - Full HD (1080p) - 23"
- LED-backlit LCD monitor - 23"
- Energy Class
- Class A
- Energy Consumption per Year
- 31 kWh
- Power Consumption (On mode)
- 21 W
- USB 3.0 hub
- Panel Type
- IPS
- Aspect Ratio
- 16:9
- Native Resolution
- Full HD (1080p) 1920 x 1080 at 75 Hz
- Pixel Pitch
- 0.2652 mm
- Brightness
- 250 cd/m²
- Contrast Ratio
- 1000:1 / 10000000:1 (dynamic)
- Response Time
- 5 ms (grey-to-grey)
- Colour Support
- 16.7 million colours
- Input Connectors
- HDMI, VGA, DisplayPort
- Height, pivot (rotation), swivel, tilt
- Screen Coating
- Anti-glare
- Black Pearl
- Dimensions (WxDxH) - without stand
- 52.1 cm x 4.33 cm x 31.17 cm
- 3.3 kg
- Localisation
- English / United Kingdom
- Environmental Standards
- TCO Certified Displays 8, TCO Certified Edge Displays, ENERGY STAR Qualified
- Plug and Play, VCCI, BSMI, GS, TUV S, WHQL, CB, CCC, PSB, FCC, ISO 9241-307, WEEE, ICES, cTUVus, MEPS, E-Standby, KC, ERP, CEL, CEL Grade 1, ISC, RCM, MSIP, SEPA, CoC, low halogen, CU, SmartWay
- 3-year warranty
- Display Type
- Energy Class
- Class A
- 31 kWh
- 21 W
- Diagonal Size
- 23"
- Viewable Size
- 23"
- Built-in Devices
- USB 3.0 hub
- Panel Type
- IPS
- Aspect Ratio
- 16:9
- Native Resolution
- Pixel Pitch
- 0.2652 mm
- Pixel Per Inch
- 96
- Brightness
- 250 cd/m²
- Contrast Ratio
- Colour Support
- Response Time
- Vertical Refresh Rate
- 50 - 75 Hz
- Horizontal Refresh Rate
- 30 - 84 kHz
- Horizontal Viewing Angle
- 178
- Vertical Viewing Angle
- 178
- Screen Coating
- Anti-glare
- Backlight Technology
- LED backlight
- Colour Temperature
- 6500K
- OSD Languages
- Chinese (traditional), Chinese (simplified), English, German, French, Italian, Portuguese, Spanish, Dutch, Japanese
- Zero Bright Dot, HDCP, On-screen Digital Controls, Hard Coating (3H), slim bezel design, Mercury free, Factory Calibration, arsenic-free glass, Micro Edge, 94% sRGB colour gamut
- Black Pearl
- 52.1 cm x 4.33 cm x 31.17 cm - without stand
- 3.3 kg
- VGA , HDMI (HDCP) , DisplayPort (HDCP) , USB 3.0 upstream , 2 x USB 3.0 downstream
Mechanical
- Tilt Angle
- -5/+22
- Swivel Angle
- 90
- Height Adjustment
- 150 mm
- VESA Mounting Interface
- 100 x 100 mm
- Security lock slot (cable lock sold separately), detachable stand, VESA 100 x 100 mm
- Cables Included
- 1 x USB cable - 1.8 m , 1 x DisplayPort cable - 2 m , 1 x power cable - 1.9 m
- Backlight Life
- 30,000 hours
- Localisation
- Security Slot Type
- Kensington security slot
- Voltage Required
- AC 120/230 V (50/60 Hz)
- 18 Watt
- Power Consumption Stand by
- 0.5 Watt
- On / Off Switch
- Included Software
- HP Display Assistant
- Dimensions & Weight Details
- Without stand - width: 52.1 cm - depth: 4.33 cm - height: 31.17 cm - weight: 3.3 kg , With stand - width: 52.1 cm - depth: 20.5 cm - height: 45.8 cm - weight: 5.9 kg
- Shipping Width
- 60.2 cm
- Shipping Depth
- 26.5 cm
- Shipping Height
- 39 cm
- Shipping Weight
- 8.4 kg
- TCO Certified
- ENERGY STAR Certified
- Limited warranty - parts and labour - 3 years
- 5 °C
- 35 °C
- 20 - 80% (non-condensing)
