HP Z Book G4 14u Core i7-7500 16GB 512GB SSD 14" Windows 10 Pro
Quicklinx: DQHXWS00 Mfr#: 1RR03EA#ABU
  • Core i7
Meet our thin and light HP ZBook 14u. This Ultrabook Workstation delivers an extraordinary level of power and graphics capability in a remarkably compact design. Now you can take workstation-class power anywhere you go.
  • Designed to move
    Hit the road in style with our thin and light mobile workstation. At 22 mm thin, as little as 1.64 kg (3.61 lbs) and impressive features like a 35.56 cm (14") touch or 4K UHD display, you'll be ready to innovate from anywhere.
  • Next-level power
    Step-up to workstation-class power with 3D graphics, the latest Intel Core i5 and i7 processors, up to 32 GB memory and 2 TB of storage. Plus, it's certified with leading software partners for fast performance across multiple apps.
  • No compromise reliability
    Confidently take on your workday with our durable & reliable HP ZBook 14u. With a 3-year limited warranty, 120,000 hours of testing, and 30 years of HP Z DNA this is where the fusion of innovation, performance & reliability meet.
HP ZBook 14u G4 Mobile Workstation - 14" - Intel Core i7 - 7500U - 16 GB RAM - 512 GB SSD - UK
Mobile workstation
Operating System
Win 10 Pro 64-bit - English
Intel Core i7 (7th Gen) - 7500U / 2.7 GHz, up to 3.5 GHz / 4 MB Cache
16 GB DDR4 (1 x 16 GB)
Storage
512 GB SSD - HP Z Turbo Drive, NVMe, MLC
Display
14" LED backlight touchscreen 1920 x 1080 / Full HD - 157 ppi
Graphics
AMD FirePro W4190M / Intel HD Graphics 620
Video Memory
2 GB GDDR5 SDRAM
Input Device
Keyboard, touchpad, pointing stick
Keyboard
Keyboard Backlight
Integrated Webcam
Gigabit Ethernet
3-cell - up to 10 hours
Dockable
Security
Trusted Platform Module (TPM 2.0) Security Chip, smart card reader
Space Silver
33.8 cm x 23.7 cm x 2.21 cm
1.64 kg
Environmental Standards
ENERGY STAR Qualified
Limited warranty - parts and labour - 3 years
Mobile workstation
Operating System
Windows 10 Pro 64-bit Edition - English
Processor / Chipset
CPU
Intel Core i7 (7th Gen) 7500U / 2.7 GHz
Max Turbo Speed
3.5 GHz
Number of Cores
Dual-Core
Cache
4 MB
64-bit Computing
Hyper-Threading Technology, Intel Turbo Boost Technology 2.0, Intel Smart Cache
RAM
16 GB (1 x 16 GB)
Max RAM Supported
32 GB
DDR4 SDRAM - non-ECC
Speed
2133 MHz / PC4-17000
Rated Speed
2133 MHz
SO-DIMM 260-pin
Slots Qty
2
Empty Slots
1
Storage
Main Storage
512 GB SSD M.2 2280 PCIe - HP Z Turbo Drive, NVM Express (NVMe), multi-level cell (MLC)
Display
14" - TN
LCD Backlight Technology
LED backlight
Touchscreen
Resolution
1920 x 1080 (Full HD)
Widescreen
Pixel Density (ppi)
157
Image Brightness
300 cd/m²
Anti-fingerprint, Full HD standard-viewing angle (SVA) eDP
Audio & Video
Multi-GPU Configuration
1 single GPU card / integrated GPU
Graphics Processor
Video Memory
2 GB GDDR5 SDRAM
Video System Features
AMD Enduro technology
Camera
Yes - 720p
Video Resolutions
1280 x 720
Frame Rate
30 frames per second
Camera Features
720p HD movie recording
Sound
Stereo speakers, two microphones
Codec
CX7501
Audio Features
Output: Bang & Olufsen Audio
Input
Keyboard Backlight
Keyboard Layout
Volume control, spill-resistant, touchpad with gesture support
Communications
Network Interface
Gigabit Ethernet
Ethernet Controller
Intel I219-V
Miracast, Wake-on-LAN (WOL)
3-cell lithium polymer
51 Wh
Run Time
Up to 10 hours
AC Adapter
Input
Output
65 Watt, 19.5 V
Connections & Expansion
Slots
1 x SIM card (1 free)
Interfaces Details
VGA , USB 3.0 (charging) , USB-C 3.1 Gen 1 , USB 3.0 , DisplayPort , Headphone/microphone combo jack , LAN , Dock
Memory Card Reader
Yes (SD Card, SDHC Card, SDXC UHS-II Card)
Space Silver
Case Material
Aluminum, magnesium alloy
Dockable
Security
HP 3D DriveGuard, HP DuraKeys, HP SpareKey, soft-touch surface, HP BIOS Protection, HP SureStart, SecureBoot, HP Automatic Drive Lock, HP DriveLock, Hybrid Boot, Master Record Security, Measured Boot, Power On Authentication, Pre-Boot Security
Theft/Intrusion Protection
Security Slot Type
Kensington security slot
Power adapter
ACPI, CSA, UL, VCCI, BSMI, CCC, FCC, RoHS, KCC, WEEE, A-Tick, ICES, Common Criteria EAL4+
Localization
1.64 kg
Sustainability Information
TCO Certified
ENERGY STAR Certified
35 °C
10 - 90% (non-condensing)
Shock Tolerance (operating)
40 g @ 2 ms half-sine pulse
Shock Tolerance (non-operating)
200 g @ 2 ms half-sine pulse
Vibration Tolerance (operating)
0.75 g @ RMS (random)
Vibration Tolerance (non-operating)
1.5 g @ RMS (random)
