HP X331 165W 100-240VAC to 12VDC Power Supply
Quicklinx: D99VWS00 Mfr#: J9739A
Marketing description is not available.
HPE X331 - power supply - hot-plug / redundant - 165 Watt
Power supply - hot-plug / redundant - plug-in module
790 g
Input Voltage
AC 100-240 V
Output Voltage
12 V
Power Capacity
165 Watt
8.64 cm x 23.8 cm x 4.04 cm
HPE Aruba 2920-24G (165 Watt), 2920-48G (165 Watt)
Input Voltage
AC 100-240 V
Output Voltage
12 V
Power Capacity
165 Watt
8.64 cm
23.8 cm
4.04 cm
790 g
