Product
HP X3300 Optical Wireless Mouse - Grey/Silver
Quicklinx: BBDBWS00 Mfr#: H4N93AA#ABB
This is about to become your favorite go-to mouse. It's sleek size travels light. Strong 2.4GHz wireless connection gives you lots of freedom. The 4th button is programmable. And, it works perfectly with Windows 8.
  • No drop outs
    The strong 2.4 GHz frequency achieves a reliable connection. The 9 meters (30 feet) roaming range gives you the freedom to work anywhere.
  • Get more done - and have fun doing it
    4th button is programmable for your needs. Plus, highly precise optical sensor works almost everywhere.
  • Save valuable USB port space
    Boost convenience. The HP Wireless Mouse X3300 connects 5 compatible devices all at the same time.
HP X3300 - mouse - 2.4 GHz - grey
Mouse
Wireless - 2.4 GHz
Grey
6 cm x 9.8 cm x 3.45 cm
86 g
English / Europe
Wireless Receiver
USB wireless receiver
Movement Detection Technology
Optical
Buttons Qty
4
Scrolling wheel
1 x AA type
2 years warranty
Compaq; HP 15; Envy; ENVY x360; Pavilion 15; Pavilion TouchSmart; Pavilion Wave; Pavilion x2; x360; Spectre x2; x360; Split x2; Stream x360; x2; x360
Mouse
Wireless Receiver
6 cm
9.8 cm
3.45 cm
86 g
Grey
English / Europe
Input Device
Wireless
2.4 GHz
Max Operating Distance
Up to 9 m
Optical
Buttons Qty
4
Scrolling wheel
1 x USB - 4 pin USB Type A
AA type
Installed Qty
1
Run Time (Up To)
9 months
System Requirements Details
Windows XP/Vista/7/8
Shipping Width
21.5 cm
Shipping Depth
16 cm
Shipping Height
5.1 cm
Shipping Weight
0.2 kg
HP 15-d090nr, 15-g000sl, 15-g002sp, 15-g029ca, 15-g030eo, 15-g030so , HP Envy , HP ENVY x360 , HP Pavilion 15-e000sa, 15-e000so, 15-e001sl, 15-e005sf, 15-e006sg, 15-e008so, 15-e010sp, 15-e011ei, 15-e011sa, 15-e012sa, 15-e013sa, 15-e014sa, 15-e020eo, 15-e020sa, 15-e021el, 15-e021sa, 15-e022sa, 15-e023ss, 15-e025sf, 15-e025so, 15-e026sa, 15-e026sf, 15-e026ss, 15-e027cl, 15-e027sa, 15-e027ss, 15-e028sa, 15-e029ss, 15-e033sl, 15-e034sf, 15-e034ss, 15-e036sa, 15-e036sf, 15-e036ss, 15-e037so, 15-e037ss, 15-e040so, 15-e040ss, 15-e041sa, 15-e041so, 15-e042sa, 15-e042so, 15-e043cl, 15-e043sa, 15-e044sa, 15-e045sa, 15-e047sa, 15-e052sg, 15-e052so, 15-e056sp, 15-e058sb, 15-e066ei, 15-e066si, 15-e067sl, 15-e068ei, 15-e068si, 15-e069sl, 15-e070sl, 15-e082sg, 15-e085nr, 15-e086nr, 15-e087nr, 15-e088nr, 15-e089nr, 15-e089sg, 15-e089sl, 15-e090sl, 15-e091sl, 15-e093eg, 15-e095eg, 15-e095sr, 15-e096sr, 15-n200eb, 15-n200ed, 15-n201eo, 15-n201sa, 15-n201so, 15-n201sr, 15-n202sf, 15-n203ed, 15-n203sr, 15-n203tu, 15-n204sa, 15-n205sa, 15-n206eo, 15-n206sa, 15-n206sc, 15-n206so, 15-n207eo, 15-n207so, 15-n208sa, 15-n209sa, 15-n209sf, 15-n209so, 15-n210ed, 15-n210eo, 15-n210ez, 15-n210sf, 15-n210so, 15-n210sy, 15-n210us, 15-n211eo, 15-n211sf, 15-n211so, 15-n212tx, 15-n213ed, 15-n213eo, 15-n213so, 15-n214eo, 15-n214so, 15-n216eo, 15-n216so, 15-n217eo, 15-n217so, 15-n218eo, 15-n218so, 15-n219sf, 15-n220sa, 15-n220sf, 15-n224ea, 15-n229sa, 15-n230sl, 15-n235sa, 15-n235sl, 15-n239ca, 15-n240eo, 15-n240sa, 15-n240so, 15-n243eo, 15-n243sa, 15-n243so, 15-n244eo, 15-n244sa, 15-n244so, 15-n245sa, 15-n247sl, 15-n248sa, 15-n250eb, 15-n252sg, 15-N252ss, 15-n253nf, 15-n257eo, 15-n257so, 15-n258ss, 15-n263eo, 15-n263so, 15-n265eo, 15-n267eo, 15-n267so, 15-n269eo, 15-n274eo, 15-n285so , HP Pavilion TouchSmart , HP Pavilion Wave , HP Pavilion x2 , HP Pavilion x360 , HP Spectre x2 , HP Spectre x360 , HP Split x2 , HP Stream x360 , HP x2 , HP x360
