This is about to become your favorite go-to mouse. It's sleek size travels light. Strong 2.4GHz wireless connection gives you lots of freedom. The 4th button is programmable. And, it works perfectly with Windows 8.
No drop outs
The strong 2.4 GHz frequency achieves a reliable connection. The 9 meters (30 feet) roaming range gives you the freedom to work anywhere. -
Get more done - and have fun doing it
4th button is programmable for your needs. Plus, highly precise optical sensor works almost everywhere. -
Save valuable USB port space
Boost convenience. The HP Wireless Mouse X3300 connects 5 compatible devices all at the same time.
- HP X3300 - mouse - 2.4 GHz - grey
- Mouse
- Connectivity Technology
- Wireless - 2.4 GHz
- Grey
- 6 cm x 9.8 cm x 3.45 cm
- 86 g
- Localisation
- English / Europe
- Wireless Receiver
- USB wireless receiver
- Movement Detection Technology
- Optical
- Buttons Qty
- 4
- Scrolling wheel
- Battery
- 1 x AA type
- 2 years warranty
- Designed For
- Compaq; HP 15; Envy; ENVY x360; Pavilion 15; Pavilion TouchSmart; Pavilion Wave; Pavilion x2; x360; Spectre x2; x360; Split x2; Stream x360; x2; x360
- Mouse
- Wireless Receiver
- 6 cm
- 9.8 cm
- 3.45 cm
- 86 g
- Grey
- Localisation
- English / Europe
Input Device
- Wireless
- Interface
- 2.4 GHz
- Max Operating Distance
- Up to 9 m
- Optical
- Buttons Qty
- 4
- Scrolling wheel
- 1 x USB - 4 pin USB Type A
- AA type
- Installed Qty
- 1
- Run Time (Up To)
- 9 months
- System Requirements Details
- Windows XP/Vista/7/8
- Shipping Width
- 21.5 cm
- Shipping Depth
- 16 cm
- Shipping Height
- 5.1 cm
- Shipping Weight
- 0.2 kg
- Limited warranty - 2 years
- Designed For
- HP 15-d090nr, 15-g000sl, 15-g002sp, 15-g029ca, 15-g030eo, 15-g030so , HP Envy , HP ENVY x360 , HP Pavilion 15-e000sa, 15-e000so, 15-e001sl, 15-e005sf, 15-e006sg, 15-e008so, 15-e010sp, 15-e011ei, 15-e011sa, 15-e012sa, 15-e013sa, 15-e014sa, 15-e020eo, 15-e020sa, 15-e021el, 15-e021sa, 15-e022sa, 15-e023ss, 15-e025sf, 15-e025so, 15-e026sa, 15-e026sf, 15-e026ss, 15-e027cl, 15-e027sa, 15-e027ss, 15-e028sa, 15-e029ss, 15-e033sl, 15-e034sf, 15-e034ss, 15-e036sa, 15-e036sf, 15-e036ss, 15-e037so, 15-e037ss, 15-e040so, 15-e040ss, 15-e041sa, 15-e041so, 15-e042sa, 15-e042so, 15-e043cl, 15-e043sa, 15-e044sa, 15-e045sa, 15-e047sa, 15-e052sg, 15-e052so, 15-e056sp, 15-e058sb, 15-e066ei, 15-e066si, 15-e067sl, 15-e068ei, 15-e068si, 15-e069sl, 15-e070sl, 15-e082sg, 15-e085nr, 15-e086nr, 15-e087nr, 15-e088nr, 15-e089nr, 15-e089sg, 15-e089sl, 15-e090sl, 15-e091sl, 15-e093eg, 15-e095eg, 15-e095sr, 15-e096sr, 15-n200eb, 15-n200ed, 15-n201eo, 15-n201sa, 15-n201so, 15-n201sr, 15-n202sf, 15-n203ed, 15-n203sr, 15-n203tu, 15-n204sa, 15-n205sa, 15-n206eo, 15-n206sa, 15-n206sc, 15-n206so, 15-n207eo, 15-n207so, 15-n208sa, 15-n209sa, 15-n209sf, 15-n209so, 15-n210ed, 15-n210eo, 15-n210ez, 15-n210sf, 15-n210so, 15-n210sy, 15-n210us, 15-n211eo, 15-n211sf, 15-n211so, 15-n212tx, 15-n213ed, 15-n213eo, 15-n213so, 15-n214eo, 15-n214so, 15-n216eo, 15-n216so, 15-n217eo, 15-n217so, 15-n218eo, 15-n218so, 15-n219sf, 15-n220sa, 15-n220sf, 15-n224ea, 15-n229sa, 15-n230sl, 15-n235sa, 15-n235sl, 15-n239ca, 15-n240eo, 15-n240sa, 15-n240so, 15-n243eo, 15-n243sa, 15-n243so, 15-n244eo, 15-n244sa, 15-n244so, 15-n245sa, 15-n247sl, 15-n248sa, 15-n250eb, 15-n252sg, 15-N252ss, 15-n253nf, 15-n257eo, 15-n257so, 15-n258ss, 15-n263eo, 15-n263so, 15-n265eo, 15-n267eo, 15-n267so, 15-n269eo, 15-n274eo, 15-n285so , HP Pavilion TouchSmart , HP Pavilion Wave , HP Pavilion x2 , HP Pavilion x360 , HP Spectre x2 , HP Spectre x360 , HP Split x2 , HP Stream x360 , HP x2 , HP x360
