Give your HP Elite x2 1012 an extra layer of protection wherever the day takes you with the stylish, business-class HP Elite x2 102 Protective Case.
Assemble in a snap
Simply insert your tablet into the form-fitting, soft-lined case, which has cutouts for all the tablet's ports and inputs so you can stay connected, plus the kickstand so you can use it on a desk or table. -
Add a keyboard
Get additional productivity with the optional HP Travel or Advanced Keyboards, which are fully functional with the tablet in the case. -
Be comfortable
Carry the case by hand with integrated, removable hand strap or the included shoulder strap. -
World-class support
Rest easy with a one-year limited warranty.
- HP Protective Case - notebook shield case
- Product Type
- Notebook shield case
- Location
- Upper
- Product Material
- Polyurethane, polycarbonate
- 30.6 cm x 1.46 cm x 21.96 cm
- 298 g
- Notebook Compatibility
- 12"
- Removable shoulder strap, adjustable shoulder strap, camera lens cutout, removable hand strap, port cut-outs, logo cutout
- Carrying Strap
- Hand strap, shoulder carrying strap
- Designed For
- HP Elite x2 1012 G1
- Product Type
- Location
- Upper
- Product Material
- 30.6 cm
- 1.46 cm
- 21.96 cm
- 298 g
- 12"
- Carrying Strap
- Designed For
