Push your computing boundaries with the HP Z840 Workstation and keep up with your biggest projects. Built for high-end computing and visualization, the HP Z840 delivers outstanding performance in one of the industry's most expandable chassis. Primed to perform, the HP Z840 allows you to achieve the performance you need with the ability to support two processors for up to 36 total processor cores in one system.
Powerful processing
Achieve the performance you need with the ability to support two next generation Intel Xeon processors for up to 36 total processor cores in one system. -
Geared up graphics
Take productivity up a notch with the ability to do more thanks to NVIDIA professional graphics cards in 2D or 3D. -
See the difference
Get serious about graphics and reach peak productivity with access to a breadth of AMD professional graphics from entry to high-end 3D. -
Powerhouse ports
Maximize your time and increase your capabilities with USB and SATA ports, plus lightning-fast data transfers using optional Thunderbolt 2 technology. -
A new design to fit your needs
A new tool-free chassis boasts low acoustics, dual integrated Gb Ethernet, aluminum side panels, handles for lifting, and is 5U rack mountable-all in an elegant industrial design. -
Set a new performance curve for your HP Z840
Reduce boot up, calculation, and graphics response and revolutionize how your HP Z840 handles large files with the HP Z Turbo Drive, a remarkably fast and innovative storage solution.
- HP Workstation Z840 - tower - Xeon E5-2620V4 2.1 GHz - vPro - 16 GB - HDD 1 TB
- Workstation - tower
- Platform Technology
- Intel vPro Platform
- Height (Rack Units)
- 5U
- Localisation
- Processor
- 1 x Intel Xeon E5-2620V4 / 2.1 GHz (, up to 3 GHz, (8-core)
- Processor Socket
- LGA2011-v3 Socket
- Cache Memory
- 20 MB
- Cache Per Processor
- 20 MB
- RAM
- 16 GB (installed) / 256 GB (max) - DDR4 SDRAM - ECC - PC4-17000
- Storage Controller
- SAS-2 (SAS 6Gb/s); RAID (SATA 6Gb/s)
- Hard Drive
- HDD 1 TB - SATA 6Gb/s - 7200 rpm
- Optical Storage
- DVD SuperMulti
- Graphics Controller
- No graphics
- Networking
- 1GbE
- Power
- AC 120/230 V (50/60 Hz)
- OS Provided
- Microsoft Windows 7 Professional 64-bit Edition (downgrade from Windows 10 Pro 64-bit) + Windows 10 Pro 64-bit Licence
- Black, hematite
- 20.32 cm x 52.58 cm x 44.45 cm
- 21.1 kg
- Limited warranty - parts and labour - 3 years - on-site
- Workstation
- Product Form Factor
- Tower - 5U
- Embedded Security
- Trusted Platform Module (TPM 1.2) Security Chip
- Black, hematite
- Localisation
Processor / Chipset
- CPU
- Intel Xeon E5-2620V4
- Clock Speed
- 2.1 GHz
- Max Turbo Speed
- 3 GHz
- Number of Cores
- 8-core
- CPU Qty
- 1
- Max CPU Qty
- 2
- CPU Upgradability
- Upgradable
- CPU Socket
- LGA2011-v3 Socket
- Chipset Type
- Intel C612
Cache Memory
- Installed Size
- 20 MB
- 20 MB
RAM
- Installed Size
- 16 GB / 256 GB (max)
- Technology
- DDR4 SDRAM - ECC
- Effective Memory Speed
- 1600 MHz
- Rated Memory Speed
- 2133 MHz
- Memory Specification Compliance
- PC4-17000
- Form Factor
- DIMM 288-pin
- Slots
- 16 (Total) / 14 (empty)
- Registered
- Configuration Features
- 2 x 8 GB
- RAM Supported
- 256 GB registered - ECC , 2 TB Load-Reduced - ECC
Hard Drive
- HDD
- Capacity
- 1 x 1 TB
- Interface Type
- SATA 6Gb/s
- Spindle Speed
- 7200 rpm
Storage Controller
- 1 x SAS-2
- Controller Interface Type
- SAS 6Gb/s
- Channel Qty
- 8
- RAID Level
- RAID 0, RAID 1, RAID 10
Storage Controller (2nd)
- 1 x RAID
- SATA 6Gb/s
- Channel Qty
- 6
- RAID Level
- RAID 0, RAID 1, RAID 5, RAID 10
Optical Storage
- DVD±RW (±R DL) / DVD-RAM DVD SuperMulti - SATA
Monitor
- Monitor Type
- None.
Graphics Controller
- Graphics Processor
- No graphics
Audio Output
- High Definition Audio
Input Device
- Mouse
Mouse
- Technology
- Laser
- Interface
- USB
- Ethernet Ports
- 2 x Gigabit Ethernet
- Ethernet Controller
- Intel I218-LM, I210-AT
- Data Link Protocol
- Wake on LAN (WoL), PXE support, auto-uplink (auto MDI/MDI-X)
- IEEE 802.3, IEEE 802.3u, IEEE 802.3i, IEEE 802.3z, IEEE 802.1Q, IEEE 802.3ab, IEEE 802.1p, IEEE 802.3x, IEEE 802.1as, IEEE 802.3ap, IEEE 802.3az
- Bays
- 1 (total) / 0 (free) x external 5.25" Slim Line , 2 (total) / 2 (free) x external 5.25" , 4 (total) / 3 (free) x internal 3.5"
- Slots
- 2 (total) / 1 (free) x CPU , 16 (total) / 14 (free) x DIMM 288-pin , 1 (total) / 1 (free) x PCIe 3.0 x4 , 2 (total) / 2 (free) x PCIe 3.0 x16 , 1 (total) / 1 (free) x PCIe 3.0 x8 (2 processors must be installed) , 1 (total) / 1 (free) x PCIe 3.0 x16 (2 processors must be installed) , 1 (total) / 1 (free) x PCIe 2.0 x1 , 1 (total) / 1 (free) x PCIe 2.0 x4 (PCIe 3.0 x8 mode with 2 processors)
- 8 x USB 3.0 (4 front, 4 rear) , 2 x USB 2.0 , 1 x PS/2 mouse , 1 x PS/2 keyboard , 2 x LAN (Gigabit Ethernet) , 1 x audio line-in , 1 x microphone (1 in front) , 1 x audio line-out , 1 x headphones/microphone (1 in front) , 1 x serial
- Included Accessories
- HP Single Processor Air Cooling Kit
- Theft/Intrusion Protection
- Security Slot Type
- Kensington security slot
- RoHS, WEEE, ACPI 4.0
- Power supply
- Voltage Required
- Power Provided
- 1125 Watt
- Efficiency
- 90%
- Power Factor Correction
- Yes (active)
Operating System / Software
- OS Provided
- Microsoft Windows 7 Professional 64-bit Edition (available through downgrade rights from Windows 10 Pro 64-bit) + Windows 10 Pro 64-bit Licence - English
- 20.32 cm
- 52.58 cm
- 44.45 cm
- 21.1 kg
- 5 °C
- 35 °C
- 8 - 85% (non-condensing)
