HP Workstation Z840 Xeon E5-2620V4 16GB 1TB Windows 10 Pro
Quicklinx: C9QGWS00 Mfr#: T4K63ET#ABU
  • Xeon
  • Microsoft Windows 7 Professional 64-bit Edition
Push your computing boundaries with the HP Z840 Workstation and keep up with your biggest projects. Built for high-end computing and visualization, the HP Z840 delivers outstanding performance in one of the industry's most expandable chassis. Primed to perform, the HP Z840 allows you to achieve the performance you need with the ability to support two processors for up to 36 total processor cores in one system.
  • Powerful processing
    Achieve the performance you need with the ability to support two next generation Intel Xeon processors for up to 36 total processor cores in one system.
  • Geared up graphics
    Take productivity up a notch with the ability to do more thanks to NVIDIA professional graphics cards in 2D or 3D.
  • See the difference
    Get serious about graphics and reach peak productivity with access to a breadth of AMD professional graphics from entry to high-end 3D.
  • Powerhouse ports
    Maximize your time and increase your capabilities with USB and SATA ports, plus lightning-fast data transfers using optional Thunderbolt 2 technology.
  • A new design to fit your needs
    A new tool-free chassis boasts low acoustics, dual integrated Gb Ethernet, aluminum side panels, handles for lifting, and is 5U rack mountable-all in an elegant industrial design.
  • Set a new performance curve for your HP Z840
    Reduce boot up, calculation, and graphics response and revolutionize how your HP Z840 handles large files with the HP Z Turbo Drive, a remarkably fast and innovative storage solution.
HP Workstation Z840 - tower - Xeon E5-2620V4 2.1 GHz - vPro - 16 GB - HDD 1 TB
Workstation - tower
Platform Technology
Intel vPro Platform
Height (Rack Units)
5U
1 x Intel Xeon E5-2620V4 / 2.1 GHz (, up to 3 GHz, (8-core)
Processor Socket
LGA2011-v3 Socket
Cache Memory
20 MB
Cache Per Processor
20 MB
RAM
16 GB (installed) / 256 GB (max) - DDR4 SDRAM - ECC - PC4-17000
Storage Controller
SAS-2 (SAS 6Gb/s); RAID (SATA 6Gb/s)
Hard Drive
HDD 1 TB - SATA 6Gb/s - 7200 rpm
Optical Storage
DVD SuperMulti
Graphics Controller
No graphics
1GbE
OS Provided
Microsoft Windows 7 Professional 64-bit Edition (downgrade from Windows 10 Pro 64-bit) + Windows 10 Pro 64-bit Licence
Black, hematite
20.32 cm x 52.58 cm x 44.45 cm
21.1 kg
Limited warranty - parts and labour - 3 years - on-site
Platform Technology
Intel vPro Platform
Workstation
Product Form Factor
Tower - 5U
Embedded Security
Trusted Platform Module (TPM 1.2) Security Chip
Black, hematite
Processor / Chipset
CPU
Clock Speed
2.1 GHz
Max Turbo Speed
3 GHz
Number of Cores
8-core
CPU Qty
1
Max CPU Qty
2
CPU Upgradability
Upgradable
CPU Socket
LGA2011-v3 Socket
Chipset Type
Intel C612
Cache Memory
Installed Size
20 MB
Cache Per Processor
20 MB
RAM
Installed Size
16 GB / 256 GB (max)
DDR4 SDRAM - ECC
Effective Memory Speed
1600 MHz
Rated Memory Speed
2133 MHz
Memory Specification Compliance
PC4-17000
DIMM 288-pin
Slots
16 (Total) / 14 (empty)
Registered
Configuration Features
2 x 8 GB
RAM Supported
256 GB registered - ECC , 2 TB Load-Reduced - ECC
Hard Drive
HDD
1 x 1 TB
Interface Type
SATA 6Gb/s
Spindle Speed
7200 rpm
Storage Controller
1 x SAS-2
Controller Interface Type
SAS 6Gb/s
Channel Qty
8
RAID Level
RAID 0, RAID 1, RAID 10
Storage Controller (2nd)
1 x RAID
SATA 6Gb/s
Channel Qty
6
RAID Level
RAID 0, RAID 1, RAID 5, RAID 10
Optical Storage
DVD±RW (±R DL) / DVD-RAM DVD SuperMulti - SATA
Monitor
Monitor Type
None.
Graphics Controller
Graphics Processor
No graphics
Audio Output
High Definition Audio
Input Device
Mouse
Mouse
Laser
USB
Ethernet Ports
2 x Gigabit Ethernet
Ethernet Controller
Intel I218-LM, I210-AT
Wake on LAN (WoL), PXE support, auto-uplink (auto MDI/MDI-X)
IEEE 802.3, IEEE 802.3u, IEEE 802.3i, IEEE 802.3z, IEEE 802.1Q, IEEE 802.3ab, IEEE 802.1p, IEEE 802.3x, IEEE 802.1as, IEEE 802.3ap, IEEE 802.3az
Bays
1 (total) / 0 (free) x external 5.25" Slim Line , 2 (total) / 2 (free) x external 5.25" , 4 (total) / 3 (free) x internal 3.5"
Slots
2 (total) / 1 (free) x CPU , 16 (total) / 14 (free) x DIMM 288-pin , 1 (total) / 1 (free) x PCIe 3.0 x4 , 2 (total) / 2 (free) x PCIe 3.0 x16 , 1 (total) / 1 (free) x PCIe 3.0 x8 (2 processors must be installed) , 1 (total) / 1 (free) x PCIe 3.0 x16 (2 processors must be installed) , 1 (total) / 1 (free) x PCIe 2.0 x1 , 1 (total) / 1 (free) x PCIe 2.0 x4 (PCIe 3.0 x8 mode with 2 processors)
8 x USB 3.0 (4 front, 4 rear) , 2 x USB 2.0 , 1 x PS/2 mouse , 1 x PS/2 keyboard , 2 x LAN (Gigabit Ethernet) , 1 x audio line-in , 1 x microphone (1 in front) , 1 x audio line-out , 1 x headphones/microphone (1 in front) , 1 x serial
HP Single Processor Air Cooling Kit
Theft/Intrusion Protection
Security Slot Type
Kensington security slot
RoHS, WEEE, ACPI 4.0
Power supply
Power Provided
1125 Watt
Efficiency
90%
Power Factor Correction
Yes (active)
Operating System / Software
OS Provided
Microsoft Windows 7 Professional 64-bit Edition (available through downgrade rights from Windows 10 Pro 64-bit) + Windows 10 Pro 64-bit Licence - English
20.32 cm
52.58 cm
44.45 cm
21.1 kg
5 °C
35 °C
8 - 85% (non-condensing)
