HP Workstation Z6 G4 MT Xeon 4108 32GB 1TB Windows 10 Pro
Quicklinx: DVCYWS00 Mfr#: 2WU44ET#ABU
Processor Type: Xeon Silver
Operating System: Windows 10 Pro
Installed Memory: 32GB
Hard Drive Capacity: 1TB
Storage Type: HDD
Hurry, only 3 left in stock!
£1,591.76 ex VAT
£1,910.11 inc VAT
No matter what the future holds, you'll have all the performance you need. Ideal for VFX and rendering, this workhorse offers a wide range of processing power and the flexibility to upgrade components over time.
  • Designed to grow with you
    Invest only in the technology you need today, and easily upgrade in the future. Scale up with a broad range of configurations from single or dual processors to multiple graphics cards.
  • Relentless power
    Take on demanding workloads with high-powered processors, professional graphics and 384 GB of memory. Experience seamless performance during graphics-intensive work, such as visual effects and design visualization.
  • HP's most secure workstations
    Advanced security features come standard on every Z6. Rest assured your device, identity and data are safe with security software like HP Client Security Suite and HP Sure Start, the industry's first self-healing BIOS with intrusion detection.
HP Workstation Z6 G4 - MT - Xeon Silver 4108 1.8 GHz - 32 GB - 1 TB
Workstation - mini tower
Platform Technology
Intel vPro Technology
Height (Rack Units)
4U
1 x Intel Xeon Silver 4108 / 1.8 GHz (3 GHz) (8-core)
Processor Socket
FCLGA3647 Socket
Processor Main Features
Hyper-Threading Technology, Intel Turbo Boost Technology 2
Cache Memory
11 MB
Cache Per Processor
11 MB
RAM
32 GB (installed) / 384 GB (max) - DDR4 SDRAM - ECC - PC4-21333
Storage Controller
SATA (SATA 6Gb/s)
Hard Drive
1 x 1 TB - SATA 6Gb/s - 7200 rpm
Optical Storage
DVD-Writer
Graphics Controller
No graphics
Audio Output
Stereo
GigE
OS Provided
Windows 10 Pro
16.9 cm x 46.5 cm x 44.5 cm
13.1 kg
Limited warranty - parts and labour - 3 years - on-site
Platform Technology
Workstation
Product Form Factor
Mini tower - 4U
Built-in Devices
Speaker
Embedded Security
Trusted Platform Module (TPM 2.0) Security Chip
Processor / Chipset
CPU
Max Turbo Speed
3 GHz
Number of Cores
8-core
CPU Qty
1
Max CPU Qty
2
CPU Upgradability
Upgradable
CPU Socket
FCLGA3647 Socket
Chipset Type
Intel C622
Cache Memory
Installed Size
11 MB
Cache Per Processor
11 MB
RAM
Installed Size
32 GB / 384 GB (max)
DDR4 SDRAM - ECC
Effective Memory Speed
2400 MHz
Rated Memory Speed
2666 MHz
Memory Specification Compliance
PC4-21333
DIMM 288-pin
Slots
12 (Total) / 10 (empty)
Registered, slots 7 - 12 are available in two-processor configuration only, non-uniform memory architecture
Configuration Features
2 x 16 GB
Hard Drive
HDD
1 x 1 TB
Interface Type
SATA 6Gb/s
Spindle Speed
7200 rpm
Storage Controller
SATA
Controller Interface Type
SATA 6Gb/s
Channel Qty
6
RAID Level
RAID 0, RAID 1, RAID 5, RAID 10
Optical Storage
DVD-Writer DVD-Writer
Monitor
Monitor Type
None.
Graphics Controller
Graphics Processor
No graphics
Audio Output
Sound Output Mode
Stereo
High Definition Audio
Interface (Bus) Type
PCI Express 3.0
Ethernet Ports
2 x Gigabit Ethernet
Ethernet Controller
Intel I219-LM
Wake on LAN (WoL), PXE 2.1 support
Bays
1 (total) / 1 (free) x external 5.25" Slim Line , 2 (total) / 2 (free) x external 5.25" , 2 (total) / 1 (free) x internal 2.5" / 3.5" shared
Slots
3 (total) / 3 (free) x PCIe 3.0 x4 , 2 (total) / 2 (free) x PCIe 3.0 x16 , 1 (total) / 1 (free) x PCIe 3.0 x8 , 2 (total) / 2 (free) x M.2 Card
1 x headphones/microphone (1 in front) , 10 x USB 3.1 Gen 1 - Type A (4 front, 6 rear) (one of them is charging) , 1 x PS/2 mouse , 2 x LAN (Gigabit Ethernet) - RJ-45 , 1 x audio line-in , 1 x audio line-out , PS/2 keyboard
Theft/Intrusion Protection
Security lock slot (cable lock sold separately), padlock loop
Security Slot Type
Kensington security slot
RoHS, WEEE, ACPI 5.0, low halogen
Power supply
Nominal Voltage
Efficiency
90%
Power Factor Correction
Yes (active)
Operating System / Software
OS Provided
Windows 10 Pro English
16.9 cm
46.5 cm
44.5 cm
13.1 kg
5 °C
35 °C
10 - 85% (non-condensing)
HP Workstation Z6 G4 MT Xeon 4108 32GB 1TB Windows 10 Pro Bundle deal on HP Workstation Z6 G4 MT Xeon 4108 32GB 1TB Windows 10 Pro
£1,690.93
Storage Type: HDD
Processor Model: 4108
Type: Workstation
Case Style: Tower
Display: not included
Optical Storage: DVD-Writer
Brand: HP
Price Range Ex VAT: 1500+
