HP Workstation Z440 Xeon E5-1603V4 8GB 1TB Windows 10 Pro
Quicklinx: C9PSWS00 Mfr#: T4K76ET#ABU
  • Xeon
  • Microsoft Windows 7 Professional 64-bit Edition
Take your business to the next level of performance, expandability, and no compromise reliability in one complete package. Featuring a perfect mix of HP Z DNA in a performance workstation package with up to 8 discrete processor cores, up to 128 GB of RAM, and multiple storage and PCIe configuration options.
  • Get the job done fast
    Cross items off your to-do list fast. Achieve massive computational performance with a single processor personal workstation delivering support for up to 8 cores of processing power. Add in powerful graphics and performance features like optional Thunderbolt 2, HP Z Turbo Drive, and HP Remote Graphics Software, and you get a world-class workstation experience that never slows you down.
  • Customize it to grow with you
    When your job requires more, the HP Z440 Workstation, with its sleek 4U form factor, tool-less design, and built in handles make it simple to expand. Easily configure memory, storage, graphics, and more to suit your needs.
  • Position for the future
    Protect your investment and make downtime a thing of the past. Get no-compromise reliability and a standard 3/3/3 limited warranty from the HP Z440 Workstation.
HP Workstation Z440 - MT - Xeon E5-1603V4 2.8 GHz - 8 GB - HDD 1 TB
Workstation - mini tower
Platform Technology
Intel vPro Technology
Height (Rack Units)
4U
1 x Intel Xeon E5-1603V4 / 2.8 GHz (Quad-Core)
Processor Socket
LGA2011-v3 Socket
Cache Memory
10 MB
Cache Per Processor
10 MB
RAM
8 GB (installed) / 128 GB (max) - DDR4 SDRAM - ECC
Storage Controller
SATA (SATA 6Gb/s)
Hard Drive
HDD 1 TB - SATA 6Gb/s - 7200 rpm
Optical Storage
DVD SuperMulti
Card Reader
15 in 1
Graphics Controller
No graphics
GigE
OS Provided
Microsoft Windows 7 Professional 64-bit Edition (downgrade from Windows 10 Pro 64-bit) + Windows 10 Pro 64-bit Licence
Jack black
16.891 cm x 44.47 cm x 43.18 cm
11 kg
Pricing Type
Promo
Limited warranty - parts and labour - 3 years - on-site
Platform Technology
Workstation
Product Form Factor
Mini tower - 4U
Built-in Devices
Speaker
Embedded Security
Trusted Platform Module (TPM 1.2) Security Chip
Jack black
Processor / Chipset
CPU
Number of Cores
Quad-Core
CPU Qty
1
Max CPU Qty
1
CPU Upgradability
Upgradable
CPU Socket
LGA2011-v3 Socket
Chipset Type
Intel C612
Cache Memory
Installed Size
10 MB
Cache Per Processor
10 MB
RAM
Installed Size
8 GB / 128 GB (max)
DDR4 SDRAM - ECC
Effective Memory Speed
2133 MHz
DIMM 288-pin
Slots
8 (Total) / 6 (empty)
Registered
Configuration Features
2 x 4 GB
Hard Drive
HDD
1 x 1 TB
Interface Type
SATA 6Gb/s
Spindle Speed
7200 rpm
Storage Controller
1 x SATA
Controller Interface Type
SATA 6Gb/s
Channel Qty
6
RAID Level
RAID 0, RAID 1, RAID 10
Optical Storage
DVD±RW (±R DL) / DVD-RAM DVD SuperMulti - SATA
Card Reader
15 in 1 card reader
Supported Flash Memory Cards
CompactFlash Card type I, CompactFlash Card type II, Memory Stick, Memory Stick PRO, Microdrive, SD Memory Card, Memory Stick Duo, Memory Stick PRO Duo, SDHC Memory Card, Memory Stick PRO-HG Duo, SDXC Memory Card, Memory Stick Select, SDHC UHS-II Memory Card
Monitor
Monitor Type
None.
Graphics Controller
Graphics Processor
No graphics
Audio Output
High Definition Audio
Input Device
Mouse
Mouse
Laser
USB
Interface (Bus) Type
PCI Express 1.1 x1
Ethernet Controller
Intel I218-LM
Wake on LAN (WoL), PXE support, auto-uplink (auto MDI/MDI-X)
IEEE 802.3, IEEE 802.3u, IEEE 802.3i, IEEE 802.3z, IEEE 802.1Q, IEEE 802.3ab, IEEE 802.1p, IEEE 802.3x, IEEE 802.1as, IEEE 802.3az
Bays
1 (total) / 0 (free) x external 5.25" Slim Line , 2 (total) / 2 (free) x external 5.25" , 2 (total) / 1 (free) x internal 3.5"
Slots
8 (total) / 6 (free) x DIMM 288-pin , 1 (total) / 0 (free) x CPU , 1 (total) / 1 (free) x PCIe 2.0 x1 - half-length, full-height , 2 (total) / 2 (free) x PCIe 3.0 x16 - full-length, full-height , 1 (total) / 1 (free) x PCIe 2.0 x4 - full-length, full-height , 1 (total) / 1 (free) x PCIe 3.0 x8 - full-length, full-height , 1 (total) / 1 (free) x PCI - full-length, full-height
8 x USB 3.0 (4 front, 4 rear) , 1 x headphones/microphone (1 in front) , 1 x microphone (1 in front) , 1 x audio line-in , 1 x audio line-out , 2 x USB 2.0 , 1 x PS/2 keyboard , 1 x PS/2 mouse , 1 x LAN (Gigabit Ethernet) - RJ-45
HP Processor Air Cooling Kit
Theft/Intrusion Protection
Security Slot Type
Kensington security slot
ACPI, RoHS, WEEE
Pricing Type
Promo
Power supply
Nominal Voltage
Power Provided
700 Watt
80 PLUS Certification
80 PLUS
Efficiency
90%
Power Factor Correction
Yes (active)
Operating System / Software
OS Provided
Microsoft Windows 7 Professional 64-bit Edition (available through downgrade rights from Windows 10 Pro 64-bit) + Windows 10 Pro 64-bit Licence - English
Software
HP Remote Graphics Software 7.1
16.891 cm
44.47 cm
43.18 cm
11 kg
5 °C
35 °C
8 - 85% (non-condensing)
