HP Workstation Z440 Xeon E5-1603V4 8GB 1TB HDD Windows 10 Home
Quicklinx: CH47WS00 Mfr#: Y3Y35ET#ABU
  • Xeon
Take your business to the next level of performance, expandability, and no compromise reliability in one complete package. The HP Z440 features a perfect mix of HP Z DNA in a performance workstation with powerful processor, spacious RAM, and multiple storage and PCIe configuration options. Here's to more power to you with the HP Z440 Workstation.
Get the job done fast
Cross items off your to-do list fast. Achieve massive computational performance with a single processor personal workstation delivering support for up to 8 cores of processing power. Add in powerful graphics and performance features like optional Thunderbolt™ 21, HP Z Turbo Drive, and HP Remote Graphics Software, and you get a world-class workstation experience that never slows you down.
Customize it to grow with you
When your job requires more, the HP Z440 Workstation, with its sleek 4U form factor, tool-less design, and built in handles make it simple to expand. Easily configure memory, storage, graphics, and more to suit your needs.
Position for the future
Protect your investment and make downtime a thing of the past. Get no-compromise reliability and a standard 3/3/3 limited warranty from the HP Z440 Workstation.
Primed to perform
Achieve the performance you need with next generation Intel® Xeon® processors for up to 8 processor cores in one system.
Graphics pro
Get serious about graphics and reach peak productivity with access to a breadth of AMD professional graphics from entry to high-end 3D.
See everything clearly
Take productivity up a notch with the ability to do more thanks to NVIDIA® professional graphics cards in 2D or 3D.
High-power ports
Maximize your time and increase your capabilities with USB and SATA ports, plus lightning-fast data transfers using optional Thunderbolt™ 2 technology.
A chassis that meets any challenge
A brand new tool-free chassis boasts low acoustics, single integrated Gb Ethernet and more.
Set a new performance curve for your HP Z440
Reduce boot up, calculation, and graphics response and revolutionize how your HP Z440 handles large files with the HP Z Turbo Drive, a remarkably fast and innovative storage solution.
More power to you
You’ll never run out of juice with the 700W Power Supply with two power cables for high-power professional graphics.
See every angle
Take multitasking to a new level with support for up to eight displays.
Your personal system engineer
Optimize this HP Z440 for peak performance. HP Performance Advisor configures your system with updated settings and drivers to help maximize performance.
  • Primed to perform
    Achieve the performance you need with next generation Intel Xeon processors for up to 8 processor cores in one system.
  • Graphics pro
  • See everything clearly
    Take productivity up a notch with the ability to do more thanks to NVIDIA professional graphics cards in 2D or 3D.
  • High-power ports
    Maximize your time and increase your capabilities with USB and SATA ports, plus lightning-fast data transfers using optional Thunderbolt 2 technology.
  • A chassis that meets any challenge
  • Set a new performance curve for your HP Z440
HP Workstation Z440 - MT - Xeon E5-1603V4 2.8 GHz - vPro - 8 GB - HDD 1 TB
Workstation - mini tower
Platform Technology
Intel vPro Platform
Height (Rack Units)
4U
1 x Intel Xeon E5-1603V4 / 2.8 GHz (Quad-Core)
Processor Socket
LGA2011-v3 Socket
Cache Memory
10 MB
Cache Per Processor
10 MB
RAM
8 GB (installed) / 128 GB (max) - DDR4 SDRAM - ECC - PC4-17000
Storage Controller
SATA (SATA 6Gb/s)
Hard Drive
HDD 1 TB - SATA 6Gb/s - 7200 rpm
Optical Storage
DVD SuperMulti
Card Reader
15 in 1
Graphics Controller
No graphics
1GbE
OS Provided
Windows 10 Home Single Language 64-bit Edition
Software Included
Cyberlink PowerDVD, CyberLink Power2Go, HP Performance Advisor, Foxit PhantomPDF Express, HP Remote Graphics Software 7.1
Jack black
16.891 cm x 44.47 cm x 43.18 cm
11 kg
Limited warranty - parts and labour - 3 years - on-site
Platform Technology
Intel vPro Platform
Workstation
Product Form Factor
Mini tower - 4U
Embedded Security
Trusted Platform Module (TPM 1.2) Security Chip
Jack black
Processor / Chipset
CPU
Clock Speed
2.8 GHz
Number of Cores
Quad-Core
CPU Qty
1
Max CPU Qty
1
CPU Upgradability
Upgradable
CPU Socket
LGA2011-v3 Socket
Chipset Type
Intel C612
Cache Memory
Installed Size
10 MB
Cache Per Processor
10 MB
RAM
Installed Size
8 GB / 128 GB (max)
DDR4 SDRAM - ECC
Effective Memory Speed
2133 MHz
Rated Memory Speed
2133 MHz
Memory Specification Compliance
PC4-17000
DIMM 288-pin
Slots
8 (Total) / 6 (empty)
Registered, quad channel memory architecture
Configuration Features
2 x 4 GB
Hard Drive
HDD
1 x 1 TB
Interface Type
SATA 6Gb/s
Spindle Speed
7200 rpm
Storage Controller
1 x SATA
Controller Interface Type
SATA 6Gb/s
Channel Qty
6
RAID Level
RAID 0, RAID 1, RAID 10
Optical Storage
DVD±RW (±R DL) / DVD-RAM DVD SuperMulti - SATA
Card Reader
15 in 1 card reader
Monitor
Monitor Type
None.
Graphics Controller
Graphics Processor
No graphics
Audio Output
High Definition Audio
Input Device
Mouse
Mouse
Laser
USB
Interface (Bus) Type
PCI Express 1.1 x1
Ethernet Controller
Intel I218-LM
Wake on LAN (WoL), PXE support, auto-uplink (auto MDI/MDI-X)
IEEE 802.3, IEEE 802.3u, IEEE 802.3i, IEEE 802.3z, IEEE 802.1Q, IEEE 802.3ab, IEEE 802.1p, IEEE 802.3x, IEEE 802.1as, IEEE 802.3az
Bays
1 (total) / 0 (free) x external 5.25" Slim Line , 2 (total) / 2 (free) x external 5.25" , 2 (total) / 1 (free) x internal 3.5"
Slots
8 (total) / 6 (free) x DIMM 288-pin , 1 (total) / 0 (free) x CPU , 1 (total) / 1 (free) x PCIe 2.0 x1 - half-length, full-height , 2 (total) / 2 (free) x PCIe 3.0 x16 - full-length, full-height , 1 (total) / 0 (free) x PCIe 2.0 x4 - full-length, full-height , 1 (total) / 1 (free) x PCIe 3.0 x8 - full-length, full-height , 1 (total) / 1 (free) x PCI - full-length, full-height
8 x USB 3.0 (4 front, 4 rear) , 1 x headphones/microphone (1 in front) , 1 x microphone (1 in front) , 1 x audio line-in , 1 x audio line-out , 2 x USB 2.0 , 1 x PS/2 keyboard , 1 x PS/2 mouse , 1 x LAN (Gigabit Ethernet) - RJ-45
HP Processor Air Cooling Kit
Theft/Intrusion Protection
Security Slot Type
Kensington security slot
RoHS, WEEE, ACPI 4.0
Power supply
Power Provided
700 Watt
80 PLUS Certification
80 PLUS
Efficiency
90%
Power Factor Correction
Yes (active)
Operating System / Software
OS Provided
Windows 10 Home Single Language 64-bit Edition English
Software
16.891 cm
44.47 cm
43.18 cm
11 kg
5 °C
35 °C
8 - 85% (non-condensing)
