HP Workstation Z440 Intel Xeon E5-1603V3 8GB 1TB HDD Windows 7 Professional (64-bit)
Quicklinx: C7ZGWS00 Mfr#: T4K26ET#ABU
Processor Type: Xeon
Operating System: Microsoft Windows 7 Professional 64-bit Edition
Installed Memory: 8GB
Hard Drive Capacity: 1TB
Storage Type: HDD
  • Xeon
  • Microsoft Windows 7 Professional 64-bit Edition
£912.87 ex VAT
£1,095.44 inc VAT
Take your business to the next level of performance, expandability, and no compromise reliability in one complete package. Featuring a perfect mix of HP Z DNA in a performance workstation package with up to 8 discrete processor cores, up to 128 GB of RAM, and multiple storage and PCIe configuration options.
  • Get the job done fast
    Cross items off your to-do list fast. Achieve massive computational performance with a single processor personal workstation delivering support for up to 8 cores of processing power. Add in powerful graphics and performance features like optional Thunderbolt 2, HP Z Turbo Drive, and HP Remote Graphics Software, and you get a world-class workstation experience that never slows you down.
  • Customize it to grow with you
    When your job requires more, the HP Z440 Workstation, with its sleek 4U form factor, tool-less design, and built in handles make it simple to expand. Easily configure memory, storage, graphics, and more to suit your needs.
  • Position for the future
    Protect your investment and make downtime a thing of the past. Get no-compromise reliability and a standard 3/3/3 limited warranty from the HP Z440 Workstation.
HP Workstation Z440 - MT - Xeon E5-1603V3 2.8 GHz - 8 GB - 1 TB - UK
Workstation - mini tower
Platform Technology
Intel vPro Technology
Height (Rack Units)
4U
1 x Intel Xeon E5-1603V3 / 2.8 GHz (Quad-Core)
Processor Socket
LGA2011-v3 Socket
Cache Memory
10 MB
Cache Per Processor
10 MB
RAM
8 GB (installed) / 128 GB (max) DDR4 SDRAM - ECC - PC4-17000
Storage Controller
SATA (SATA 6Gb/s)
Hard Drive
1 x 1 TB - SATA 6Gb/s - 7200 rpm
Optical Storage
DVD SuperMulti
Card Reader
15 in 1
Graphics Controller
No graphics
GigE
Keyboard
OS Provided
Microsoft Windows 7 Professional 64-bit Edition (downgrade from Windows 10 Pro 64-bit) + Windows 10 Pro 64-bit Licence
Jack black
16.891 cm x 44.47 cm x 43.18 cm
11 kg
Limited warranty - parts and labour - 3 years - on-site
Platform Technology
Workstation
Product Form Factor
Mini tower - 4U
Built-in Devices
Speaker, solenoid hood lock
Embedded Security
Trusted Platform Module (TPM 1.2) Security Chip
Jack black
Processor / Chipset
CPU
Number of Cores
Quad-Core
CPU Qty
1
Max CPU Qty
1
CPU Upgradability
Upgradable
CPU Socket
LGA2011-v3 Socket
Chipset Type
Intel C612
Cache Memory
Installed Size
10 MB
Cache Per Processor
10 MB
RAM
Installed Size
8 GB / 128 GB (max)
DDR4 SDRAM - ECC
Effective Memory Speed
2133 MHz
Rated Memory Speed
2133 MHz
Memory Specification Compliance
PC4-17000
DIMM 288-pin
Slots
8 (Total) / 7 (empty)
Registered
Configuration Features
1 x 8 GB
Hard Drive
HDD
1 x 1 TB
Interface Type
SATA 6Gb/s
Spindle Speed
7200 rpm
Storage Controller
1 x SATA
Controller Interface Type
SATA 6Gb/s
Channel Qty
6
RAID Level
RAID 0, RAID 1, RAID 10
Optical Storage
DVD SuperMulti - SATA
Card Reader
15 in 1 card reader
Monitor
Monitor Type
None.
Graphics Controller
Graphics Processor
No graphics
Audio Output
High Definition Audio
Input Device
Mouse, keyboard
Keyboard
USB
Localization & Layout
Mouse
Laser
USB
Interface (Bus) Type
PCI Express 1.1 x1
Ethernet Controller
Intel I218-LM
Wake on LAN (WoL), PXE support, auto-uplink (auto MDI/MDI-X)
IEEE 802.3, IEEE 802.3u, IEEE 802.3i, IEEE 802.3z, IEEE 802.1Q, IEEE 802.3ab, IEEE 802.1p, IEEE 802.3x, IEEE 802.1as, IEEE 802.3az
Bays
1 (total) / 0 (free) x external 5.25" Slim Line , 2 (total) / 1 (free) x external 5.25" , 2 (total) / 1 (free) x internal 3.5"
Slots
8 (total) / 7 (free) x DIMM 288-pin , 1 (total) / 0 (free) x CPU , 1 (total) / 1 (free) x PCIe 2.0 x1 - half-length, full-height , 2 (total) / 2 (free) x PCIe 3.0 x16 - full-length, full-height , 1 (total) / 1 (free) x PCIe 2.0 x4 - full-length, full-height , 1 (total) / 1 (free) x PCIe 3.0 x8 - full-length, full-height , 1 (total) / 1 (free) x PCI - full-length, full-height
8 x USB 3.0 (4 front, 4 rear) , 1 x headphones (1 in front) , 1 x microphone (1 in front) , 1 x audio line-in , 1 x audio line-out , 2 x USB 2.0 , 1 x PS/2 keyboard , 1 x PS/2 mouse , 1 x LAN (Gigabit Ethernet) , 1 x DisplayPort , 1 x DVI-I (dual link)
HP Single Processor Air Cooling Kit
Power-on password, USB port control, audio ports control, network port control, Setup Password, handle
Theft/Intrusion Protection
Security Slot Type
Kensington security slot
RoHS, WEEE, ACPI 4.0
Power supply
Nominal Voltage
Power Provided
700 Watt
80 PLUS Certification
80 PLUS
Efficiency
90%
Power Factor Correction
Yes (active)
Operating System / Software
OS Provided
Microsoft Windows 7 Professional 64-bit Edition (available through downgrade rights from Windows 10 Pro 64-bit) + Windows 10 Pro 64-bit Licence - English
16.891 cm
44.47 cm
43.18 cm
11 kg
5 °C
35 °C
8 - 85% (non-condensing)
Storage Type: HDD
Processor Model: E5-1603V3
Type: Workstation
Case Style: Mini tower
Display: no
Optical Storage: DVD±RW (±R DL) / DVD-RAM
Brand: HP
Price Range Ex VAT: 750 - 1000
