Perfect for engineering, visualization and Machine Learning, HP's most popular workstation delivers disruptive performance for a wide spectrum of applications. With a choice of Intel Xeon or Core X processors, and support for dual extreme graphics, you get all you need, nothing more.
Operating Systems
Support your unique user needs with a choice of Windows 10 Pro for Workstations 64 or Linux operating systems. -
Professional Performance
Run demanding professional apps with the newest generation Intel Xeon processors available with up to 18 cores for powerful performance and productivity. -
Intel Core X-Series processors
Experience disruptive price-performance on multi-threaded applications, or combined workflows such as simulation based design, with Intel Core X-Series processors: the high-performance single-socket processors from Intel . -
Graphics
Get serious about graphics and reach peak productivity with access to a breadth of NVIDIA and AMD professional graphics from entry to high-end 3D. -
Storage
Install pro-grade storage hardware and elevate your storage-bound apps without sacrificing standard PCIe slots. -
Functional Design
The simply stunning design features front and rear handles, so you can easily relocate your system.
- HP Workstation Z4 G4 - MT - Xeon W-2125 4 GHz - vPro - 16 GB - SSD 512 GB - UK
- Workstation - mini tower
- Platform Technology
- Intel vPro Platform
- Height (Rack Units)
- 4U
- Localisation
- Processor
- 1 x Intel Xeon W-2125 / 4 GHz (, up to 4.5 GHz, (Quad-Core)
- Processor Socket
- LGA2066 Socket
- Processor Main Features
- Hyper-Threading Technology, Intel Turbo Boost Technology 2
- Cache Memory
- 8.25 MB
- Cache Per Processor
- 8.25 MB
- RAM
- 16 GB (installed) / 256 GB (max) - DDR4 SDRAM - ECC
- Storage Controller
- SATA (SATA 6Gb/s)
- Hard Drive
- SSD 512 GB - PCI Express 3.0 x4 - M.2 2280 - HP Z Turbo Drive
- Optical Storage
- No optical drive
- Card Reader
- Graphics Controller
- No graphics
- Networking
- 1GbE
- Keyboard
- UK
- Power
- AC 120/230 V (50/60 Hz)
- OS Provided
- Windows 10 Pro 64-bit Edition
- Black
- 16.9 cm x 44.5 cm x 38.6 cm
- 10.2 kg
- Limited warranty - parts and labour - 3 years - on-site
- Workstation
- Product Form Factor
- Mini tower - 4U
- Embedded Security
- Trusted Platform Module (TPM 2.0) Security Chip
- Black
- Localisation
Processor / Chipset
- CPU
- Intel Xeon W-2125
- Clock Speed
- 4 GHz
- Max Turbo Speed
- 4.5 GHz
- Number of Cores
- Quad-Core
- CPU Qty
- 1
- Max CPU Qty
- 1
- CPU Upgradability
- Upgradable
- CPU Socket
- LGA2066 Socket
- Chipset Type
- Intel C422
Cache Memory
- Installed Size
- 8.25 MB
- 8.25 MB
RAM
- Installed Size
- 16 GB / 256 GB (max)
- Technology
- DDR4 SDRAM - ECC
- Effective Memory Speed
- 2666 MHz
- Rated Memory Speed
- 2666 MHz
- Form Factor
- DIMM 288-pin
- Slots
- 8 (Total) / 7 (empty)
- Registered, quad channel memory architecture
- Configuration Features
- 1 x 16 GB
Hard Drive
- SSD - M.2 2280
- Capacity
- 1 x 512 GB
- Interface Type
- HP Z Turbo Drive
Storage Controller
- 1 x SATA
- Controller Interface Type
- SATA 6Gb/s
- Channel Qty
- 6
- RAID Level
- RAID 0, RAID 1, RAID 10
Optical Storage
- No optical drive
Card Reader
- Card reader
Monitor
- Monitor Type
- None.
Graphics Controller
- Graphics Processor
- No graphics
Audio Output
- High Definition Audio
Input Device
- Mouse, keyboard
Keyboard
- Keyboard Name
- HP Business Slim Keyboard
- Interface
- USB
- Localization & Layout
- UK
Mouse
- Technology
- Optical
- Interface
- USB
- Ethernet Controller
- Intel I219-V
- Data Link Protocol
- Wake on LAN (WoL), PXE support
- Bays
- 2 (total) / 2 (free) x external 5.25" , 2 (total) / 2 (free) x internal 3.5"
- Slots
- 2 (total) / 2 (free) x PCIe 3.0 x16 , 2 (total) / 2 (free) x PCIe 3.0 x4 , 1 (total) / 1 (free) x PCIe 3.0 x8 , 2 (total) / 1 (free) x M.2 Card
- 9 x USB 3.1 Gen 1 (5 front, 4 rear) , 1 x headphones/microphone , 2 x USB 2.0 , 1 x audio line-in , 1 x audio line-out , 1 x PS/2 keyboard , 1 x PS/2 mouse , 1 x LAN (Gigabit Ethernet)
- Included Accessories
- HP Z4 CPU Cooling Solution
- Theft/Intrusion Protection
- Security Slot Type
- Kensington security slot
- ACPI, RoHS, FIPS 140-2, Common Criteria EAL4+, WEEE 2002/96/EC, ISO 11469, ISO 1043
- Power supply
- Voltage Required
- Power Provided
- 1000 Watt
- 80 PLUS Certification
- 80 PLUS
- Efficiency
- 90%
- Power Factor Correction
- Yes (active)
Operating System / Software
- OS Provided
- Windows 10 Pro 64-bit Edition English
- 16.9 cm
- 44.5 cm
- 38.6 cm
- 10.2 kg
- Shipping Width
- 31.4 cm
- Shipping Depth
- 56.3 cm
- Shipping Height
- 57.2 cm
- 5 °C
- 35 °C
- 10 - 85% (non-condensing)
Warranties (1)
HP Care Pack Next Business Day Hardware Support with Defective Media Retention - 3 years - on-site | In Stock | £33.73 |
Monitors (4)
HP DreamColour 31.1" 4096x2160 10ms 2xHDMI 2xDisplayPort USB-C LED Monitor | In Stock | £2,821.06 |
HP E 24" G4 WUXGA 1920 x 1200 LED Backlit Monitor | In Stock | £144.44 |
HP Z24f G3 24"1920x1080 5ms HDMI DisplayPort IPS LED Monitor | In Stock | £213.20 |
HP Z24n G3 24" 1920x1200 5ms HDMI DisplayPort IPS LED Monitor | In Stock | £223.10 |
Other bundles (2)
HPE DisplayPort To VGA Adapter | In Stock | £13.72 |
HPE DisplayPort DVI-D Adapter | In Stock | £13.23 |
