HP Workstation Z240 Intel Core i7-6700 16GB 512GB Windows 10 Professional
Quicklinx: CFKSWS00 Mfr#: J9C07ET#ABU
  • Core i7
  • Microsoft Windows 7 Professional 64-bit Edition
HP's entry level workstations just got better. The HP Z240 with two amazingly versatile form factors, packs the performance, features, and reliability of a workstation into the price point of a desktop PC.
• Windows 7 Professional 64 (license and media for Windows 10 Pro 64 included)
• Intel® Core™ i7-6700 with Intel HD Graphics 530 (3.4 GHz, up to 4 GHz with Intel Turbo Boost, 8 MB cache, 4 cores)
• 16 GB and HP Z Turbo Drive 512GB SSD
• 3 year Next Business Day onsite Warranty
• Ships with HP Performance Advisor and HP Remote Graphics Software
Powered to manage your challenges
Powerful processors, graphics, memory, and two optional ultra-fast HP Z Turbo Drives[4] make the HP Z240 a true workstation-class solution. Handle your growing and complex workloads with performance for any stage in your work process.
Small price, big possibilities
The essential features of the HP Z240 Tower easily support your workload with slots and ports to spare. When you’re ready for workstation class features, like professional ISV certifications, the HP Z240 Tower is the right first step.
Priced for your budget
HP’s most affordable workstation allows you to customize your experience while still balancing your IT budget. HP reliability, thorough testing, and ISV certification means your HP Z240 is designed as a long-term budget friendly solution.
  • Choose the OS for you
    Support your unique user needs with a choice of Windows 10 Pro or Linux operating systems.
  • Better Package. Bigger Punch
    Get more performance, expandability and flexibility in the chassis the world loves.
  • Powerful performance
    Achieve the performance you need with your choice of next generation Intel Xeon processors or Intel Core processors.
  • Ultra-fast storage
    Handle large files, reduce work time and increase performance with the optional HP Z Turbo Drive.
  • Work smarter
    Up to 64 GB DDR4 ECC memory helps provide no compromise capacity, performance, and reliability.
  • Geared up graphics
    Ignite productivity with NVIDIA professional graphics cards in 2D or 3D.
HP Workstation Z240 - MT - Core i7 6700 3.4 GHz - vPro - 16 GB - SSD 512 GB
Workstation - mini tower
Platform Technology
Intel vPro Platform
1 x Intel Core i7 (6th Gen) 6700 / 3.4 GHz (, up to 4 GHz, (Quad-Core)
Processor Socket
LGA1151 Socket
Processor Main Features
Hyper-Threading Technology, Intel Turbo Boost Technology 2, Intel Smart Cache
Cache Memory
8 MB
Cache Per Processor
8 MB
RAM
16 GB (installed) / 64 GB (max) - DDR4 SDRAM - PC4-17000
Storage Controller
SATA (SATA 6Gb/s)
Hard Drive
SSD 512 GB - PCI Express 3.0 x4 - PCI Express - HP Z Turbo Drive G2
Optical Storage
DVD SuperMulti
Graphics Controller
GigE
OS Provided
Microsoft Windows 7 Professional 64-bit Edition (downgrade from Windows 10 Pro 64-bit) + Windows 10 Pro 64-bit Licence
17 cm x 44.2 cm x 39.9 cm
8.6 kg
Pricing Type
Promo
Limited warranty - parts and labour - 3 years - on-site
Platform Technology
Intel vPro Platform
Workstation
Product Form Factor
Mini tower
Embedded Security
Trusted Platform Module (TPM 1.2) Security Chip
Processor / Chipset
CPU
Clock Speed
3.4 GHz
Max Turbo Speed
4 GHz
Number of Cores
Quad-Core
CPU Qty
1
Max CPU Qty
1
CPU Upgradability
Upgradable
CPU Socket
LGA1151 Socket
Chipset Type
Intel C236
Cache Memory
Installed Size
8 MB
Cache Per Processor
8 MB
RAM
Installed Size
16 GB / 64 GB (max)
DDR4 SDRAM
Effective Memory Speed
2133 MHz
Rated Memory Speed
2133 MHz
Memory Specification Compliance
PC4-17000
DIMM 288-pin
Slots
4 (Total) / 2 (empty)
Registered, dual channel memory architecture
Configuration Features
2 x 8 GB
RAM Supported
64 GB registered - ECC , 64 GB unbuffered - non-ECC
Hard Drive
SSD - PCI Express
1 x 512 GB
Interface Type
PCI Express 3.0 x4
HP Z Turbo Drive G2
Storage Controller
1 x SATA
Controller Interface Type
SATA 6Gb/s
Channel Qty
4
RAID Level
RAID 0, RAID 1
Optical Storage
DVD±RW (±R DL) / DVD-RAM DVD SuperMulti - SATA
Monitor
Monitor Type
None.
Graphics Controller
Graphics Processor
Video Interfaces
DVI, DisplayPort
Max Monitors Supported
3
Audio Output
High Definition Audio
Ethernet Controller
Intel I219-LM
Wake on LAN (WoL), PXE support
IEEE 802.3, IEEE 802.3u, IEEE 802.3i, IEEE 802.3z, IEEE 802.1Q, IEEE 802.3ab, IEEE 802.1p, IEEE 802.1as, IEEE 802.3az
Bays
2 (total) / 2 (free) x external 5.25" x 1/2H , 1 (total) / 0 (free) x external 5.25" Slim Line , 2 (total) / 2 (free) x internal 3.5" x 1/3H , 1 (total) / 1 (free) x internal 2.5" x 1/8H
Slots
1 (total) / 0 (free) x CPU , 4 (total) / 2 (free) x DIMM 288-pin , 1 (total) / 1 (free) x PCIe 3.0 x16 - full-length, full-height , 1 (total) / 1 (free) x PCIe 3.0 x1 - full-length, full-height , 1 (total) / 1 (free) x PCIe 3.0 x16 - full-length, full-height (x4 mode) , 1 (total) / 0 (free) x PCIe 3.0 x4 - full-length, full-height , 1 (total) / 1 (free) x M.2 Card (x4 mode) , 1 (total) / 0 (free) x M.2 Card (on PCI Express card)
6 x USB 3.0 (2 front, 4 rear) , 4 x USB 2.0 (2 front, 2 rear) (one of them is Always On) , 1 x headphones/microphone (1 in front) , 1 x headphones (1 in front) , 2 x DisplayPort , 1 x DVI-I , 1 x PS/2 keyboard , 1 x PS/2 mouse , 1 x LAN (Gigabit Ethernet) , 1 x audio line-in , 1 x audio line-out , 1 x microphone
Theft/Intrusion Protection
Security Slot Type
Kensington security slot
RoHS, WEEE, ACPI 4.0
Pricing Type
Promo
Power supply
Power Provided
400 Watt
Efficiency
92%
Power Factor Correction
Yes (active)
Operating System / Software
OS Provided
Microsoft Windows 7 Professional 64-bit Edition (available through downgrade rights from Windows 10 Pro 64-bit) + Windows 10 Pro 64-bit Licence - English
17 cm
44.2 cm
39.9 cm
8.6 kg
5 °C
35 °C
8 - 85% (non-condensing)
