HP Workstation Z240 - Intel Core i7-6700 16GB 256GB SSD 1TB HDD
Quicklinx: CH3XWS00 Mfr#: T4K65ET#ABU
Processor Type: Core i7
Operating System: Microsoft Windows 7 Professional 64-bit Edition
Installed Memory: 16GB, 16GB
Hard Drive Capacity: 1.256TB
Storage Type: SSD
  • Core i7
  • Microsoft Windows 7 Professional 64-bit Edition
£1,759.47 ex VAT
£2,111.36 inc VAT
HP's entry level workstations just got better. The HP Z240 with two amazingly versatile form factors, packs the performance, features, and reliability of a workstation into the price point of a desktop PC.
Powered to manage your challenges
Powerful processors, graphics, memory, and two optional ultra-fast HP Z Turbo Drives make the HP Z240 a true workstation-class solution. Handle your growing and complex workloads with performance for any stage in your work process.
Small price, big possibilities
The essential features of the HP Z240 Tower easily support your workload with slots and ports to spare. When you're ready for workstation class features, like professional ISV certifications, the HP Z240 Tower is the right first step.
Priced for your budget
HP's most affordable workstation allows you to customize your experience while still balancing your IT budget. HP reliability, thorough testing, and ISV certification means your HP Z240 is designed as a long-term budget friendly solution.
Choose the OS for you
Support your unique user needs with a choice of Windows 10 Pro or Linux® operating systems.
Better Package. Bigger Punch
Get more performance, expandability and flexibility in the chassis the world loves.
Powerful performance
Achieve the performance you need with your choice of next generation Intel® Xeon® processors or Intel® Core™ processors.
Ultra-fast storage
Handle large files, reduce work time and increase performance with the optional HP Z Turbo Drive.
Work smarter
Up to 64 GB DDR4 ECC memory helps provide no compromise capacity, performance, and reliability.
Geared up graphics
Ignite productivity with NVIDIA® professional graphics cards in 2D or 3D.
See the difference
Access AMD professional graphics including high-end 3D on Tower configurations.
Clean and cool
Help internal components stay clean and cool with a removable and cleanable dust filter.
  • Powered to manage your challenges
  • Small price, big possibilities
  • Priced for your budget
HP Workstation Z240 - MT - Core i7 6700 3.4 GHz - 16 GB - 1.256 TB - UK
Workstation - mini tower
1 x Intel Core i7 (6th Gen) 6700 / 3.4 GHz (4 GHz) (Quad-Core)
Processor Socket
LGA1151 Socket
Processor Main Features
Hyper-Threading Technology, Intel Turbo Boost Technology 2, Intel Smart Cache
Cache Memory
8 MB
Cache Per Processor
8 MB
RAM
16 GB (installed) / 64 GB (max) - DDR4 SDRAM - non-ECC - PC4-17000
Storage Controller
SATA (SATA 6Gb/s)
Hard Drive
1 x SSD 256 GB - PCI Express 3.0 x4 - PCI Express - HP Turbo Drive G2
Hard Drive (2nd)
1 x 1 TB - SATA 6Gb/s - 7200 rpm
Optical Storage
DVD SuperMulti
Card Reader
Graphics Controller
PCIe 3.0 x16 - NVIDIA Quadro M2000
Video Memory
4 GB GDDR5 SDRAM
GigE
Keyboard
OS Provided
Microsoft Windows 7 Professional 64-bit Edition (downgrade from Windows 10 Pro 64-bit) + Windows 10 Pro 64-bit Licence
17 cm x 44.2 cm x 39.9 cm
8.6 kg
Workstation
Product Form Factor
Mini tower
Built-in Devices
Speaker
Embedded Security
Trusted Platform Module (TPM 1.2) Security Chip
Processor / Chipset
CPU
Max Turbo Speed
4 GHz
Number of Cores
Quad-Core
CPU Qty
1
Max CPU Qty
1
CPU Upgradability
Upgradable
CPU Socket
LGA1151 Socket
Chipset Type
Intel C236
Cache Memory
Installed Size
8 MB
Cache Per Processor
8 MB
RAM
Installed Size
16 GB / 64 GB (max)
Effective Memory Speed
2133 MHz
Rated Memory Speed
2133 MHz
Memory Specification Compliance
PC4-17000
DIMM 288-pin
Slots
4 (Total) / 2 (empty)
Unbuffered, dual channel memory architecture
Configuration Features
2 x 8 GB
Hard Drive
SSD - PCI Express
1 x 256 GB
Interface Type
PCI Express 3.0 x4
HP Turbo Drive G2
Hard Drive (2nd)
HDD
Interface Class
Serial ATA
1 x 1 TB
Interface Type
SATA 6Gb/s
Spindle Speed
7200 rpm
Native Command Queuing (NCQ)
Storage Controller
1 x SATA
Controller Interface Type
SATA 6Gb/s
Channel Qty
4
RAID Level
RAID 0, RAID 1
Optical Storage
DVD SuperMulti - SATA
Card Reader
Card reader
Supported Flash Memory Cards
SD Memory Card, SDHC Memory Card, SDXC Memory Card
Monitor
Monitor Type
None.
Graphics Controller
Interface Type
PCIe 3.0 x16
Graphics Processor
NVIDIA Quadro M2000
Video Memory
4 GB GDDR5 SDRAM
Video Interfaces
DVI, DisplayPort
Max Monitors Supported
4
Audio Output
High Definition Audio
Input Device
Mouse, keyboard
Keyboard
USB
Localization & Layout
Mouse
Laser
USB
Ethernet Controller
Intel I219-LM
Wake on LAN (WoL), PXE support
IEEE 802.3, IEEE 802.3u, IEEE 802.3i, IEEE 802.3z, IEEE 802.1Q, IEEE 802.3ab, IEEE 802.1p, IEEE 802.1as, IEEE 802.3az
Bays
2 (total) / 2 (free) x external 5.25" x 1/2H , 1 (total) / 0 (free) x external 5.25" Slim Line , 2 (total) / 1 (free) x internal 3.5" x 1/3H , 1 (total) / 1 (free) x internal 2.5" x 1/8H
Slots
1 (total) / 0 (free) x CPU , 4 (total) / 2 (free) x DIMM 288-pin , 1 (total) / 0 (free) x PCIe 3.0 x16 - full-length, full-height , 1 (total) / 1 (free) x PCIe 3.0 x1 - full-length, full-height , 1 (total) / 0 (free) x PCIe 3.0 x16 - full-length, full-height (x4 mode) , 1 (total) / 1 (free) x PCIe 3.0 x4 - full-length, full-height , 1 (total) / 1 (free) x M.2 Card (x4 mode) , 1 (total) / 0 (free) x M.2 Card (on PCI Express card)
6 x USB 3.0 (2 front, 4 rear) , 4 x USB 2.0 (2 front, 2 rear) (one of them is Always On) , 1 x headphones/microphone (1 in front) , 1 x headphones (1 in front) , 2 x DisplayPort , 1 x DVI-I , 1 x PS/2 keyboard , 1 x PS/2 mouse , 1 x LAN (Gigabit Ethernet) , 1 x audio line-in , 1 x audio line-out , 1 x microphone
Theft/Intrusion Protection
Security Slot Type
Kensington security slot
RoHS, WEEE, ACPI 4.0
Power supply
Nominal Voltage
Power Provided
400 Watt
Efficiency
92%
Power Factor Correction
Yes (active)
Operating System / Software
OS Provided
Microsoft Windows 7 Professional 64-bit Edition (available through downgrade rights from Windows 10 Pro 64-bit) + Windows 10 Pro 64-bit Licence - English
Software
Windows 7 Professional 64-bit recovery DVD
17 cm
44.2 cm
39.9 cm
8.6 kg
5 °C
35 °C
8 - 85% (non-condensing)
HP Workstation Z240 - Intel Core i7-6700 16GB 256GB SSD 1TB HDD Bundle deal on HP Workstation Z240 - Intel Core i7-6700 16GB 256GB SSD 1TB HDD
£1,941.63
saving £8.33
£1,858.64
Storage Type: SSD
Processor Model: I7-6700
Type: Workstation
Case Style: Mini tower
Optical Storage: DVD±RW (±R DL) / DVD-RAM
Brand: HP
Price Range Ex VAT: 1500+
