Turn up the value. The HP S6500 is a portable speaker that combines great audio with impressive features. Stream your favorite sounds for up to 10 hours, and enjoy high-quality audio anywhere.
Stylish sound
Spread the sound around with a crisp top-firing audio driver. With soft-touch paint in black or white, this beauty looks as good as it sounds. -
Packed with features
Connect with a 10 m (30 ft) Bluetooth range or plug in your favorite device. Built-on buttons keep you in control, and the long-lasting battery keeps you moving for up to 10 hours. -
Backed by HP
Your device comes fully supported by HP. Get a 2 years limited warranty included.
- HP S6500 - speaker - for portable use - wireless
- Product Type
- Speaker - for portable use
- Localisation
- English / Europe
- Speaker Type
- Active
- Continuous Power
- 2 Watt
- Peak Power
- 2.8 Watt
- Frequency Response
- 200 - 12000 Hz
- Amplifier
- Integrated
- Bluetooth
- Soft touch black
- Power Options
- USB charging
- Battery
- Speaker battery rechargeable
- 7.74 cm x 8.32 cm x 8.02 cm
- 270 g
- 2-year warranty
- Designed For
- HP 20, 22, 24, 460; Pavilion 24, 27, 590, 595, TP01; Pavilion Laptop 13, 14, 15, 17
- Product Type
- Enclosure Colour
- Soft touch black
- Localisation
- English / Europe
Speaker System
- Speaker Type
- Active
- Continuous Power
- 2 Watt
- Peak Power
- 2.8 Watt
- 200 - 12000 Hz
- Amplifier
- Integrated
- Bluetooth
- Transmission Range
- 10 m
- Controls
- Power on/off, volume, play/pause
- Connector Type
- Audio line-in (mini-phone stereo 3.5 mm)
- Included Accessories
- USB cable
- Power Source
- Battery
- Options
- USB charging
- Rechargeable
- Run Time (Up To)
- 10 hour(s)
- 7.74 cm
- 8.32 cm
- 8.02 cm
- 270 g
- Shipping Width
- 13 cm
- Shipping Depth
- 10.8 cm
- Shipping Height
- 9.8 cm
- Shipping Weight
- 0.4 kg
- Limited warranty - 2 years
- Designed For
- HP 20-c400ng, 22-c0004na, 22-c0014nl, 22-c0015ng, 22-c0016ng, 22-c0017ng, 22-c0035ns, 22-c0051ns, 22-c0082nf, 22-c0211ng, 22-c1004ns, 24-f0023ng, 24-f0024ng, 24-f0025ng, 24-f0040na, 24-f0045ns, 24-f0056ns, 24-f0061ns, 24-f0077ns, 24-f0137c, 24-f1004nf, 24-f1017nf, 24-f1907ng, 24-f1908ng, 460-p214nf , HP Pavilion 24-xa0031ng, 24-xa0032ng, 24-xa0033ng, 24-xa0035ng, 24-xa0040ng, 24-xa0050ng, 24-xa0087nf, 24-xa0108nf, 24-xa0772nz, 27-xa0012ng, 27-xa0014ng, 27-xa0015ng, 27-xa0018ng, 27-xa0019ng, 27-xa0105no, 27-xa0106nf, 27-xa0107nf, 27-xa0244nz, 27-xa0884nz, 27-xa0906nz, 27-xa0992nz, 590-a0043nf, 590-a0056nf, 590-p0040no, 590-p0067nf, 590-p0117cb, 590-p0127cb, 590-p0509ng, 595-p0020nl, 595-p0068nl, TP01-0004ng, TP01-0006ng, TP01-0008ng, TP01-0009ng, TP01-0010ng, TP01-0012ng, TP01-0014ns, TP01-0026no, TP01-0040, TP01-0050, TP01-0070, TP01-0332nz, TP01-0334nz, TP01-0355nd, TP01-0442nz , HP Pavilion Laptop 13-an0031wm, 13-an0054tu, 13-an0904ng, 13-an1006nf, 13-an1010nr, 13-an1230ng, 13-an1241no, 14-ce0005ns, 14-ce0525na, 14-ce0594na, 14-ce1023nf, 14-ce1509na, 14-ce2010nl, 14-ce2014nl, 14-ce2015nl, 14-ce2016nf, 14-ce2016nl, 14-ce2021nl, 14-ce2500sa, 14-ce3003ns, 14-ce3005ns, 14-ce3010ng, 14-ce3011ng, 14-ce3040ng, 14-ce3716nd, 15-bc403nb, 15-bc501nf, 15-bc504ns, 15-bc506ns, 15-bc508na, 15-bc511nf, 15-bc518ns, 15-bc519ns, 15-bc520ns, 15-bc521ns, 15-cs1010nl, 15-cs2006nf, 15-cs2007nf, 15-cs2015nf, 15-cs2022ns, 15-cs2023nl, 15-cs2025nl, 15-cs2026nl, 15-cs2040tx, 15-cs2093nl, 15-cs2098nl, 15-cs2105nl, 15-cs3001ng, 15-cs3001ns, 15-cs3001nz, 15-cs3003ng, 15-cs3004ng, 15-cs3006ns, 15-cs3007ns, 15-cs3008ng, 15-cs3010nr, 15-cs3012ns, 15-cs3076nr, 15-cs3077nr, 15-cs3079nr, 15-cs3100nd, 15-cs3400nz, 15-cs3500nd, 15-cs3600nd, 15-cs3600nz, 15-cs3706nz, 15-cs3710ng, 15-cs3906nz, 15-cs3966nz, 15-cs3996nz, 15-cw0015nf, 15-cw0999nb, 15-cw1000nc, 15-cw1000nl, 15-cw1006nf, 15-cw1007nf, 15-cw1016nf, 15-cw1076nr, 15-cw1222ng, 17-ab483ng
