HP Wireless Premium Keyboard
Quicklinx: FZJ0WS00 Mfr#: Z9N41AA#ABU
1 on order, delivery delayed
£50.26 ex VAT
£60.31 inc VAT
Boost your productivity and work comfortably at your desk or across the room with the elegant, redesigned, anodized aluminum-trimmed HP Wireless Premium Keyboard.
  • Pretty and pretty smart
    Optimize productivity with a space-saving slim profile and ultra-quiet, low-profile scissor keys that foster focus, easy travel, and accurate typing. Get comfortable with adjustable slope, and breathe easy with a keyboard that resists minor spills.
  • Link-5 connectivity
    Work away from your PC with the Link-5 USB nano-receiver that also becomes a wireless hub for up to four additional Link-5 accessories so you can conserve USB ports on your PC.
  • Stay charged
    Conserve power with an on/off switch and avoid surprises with a convenient LED that alerts you when the battery is low. Charge up while you work by plugging the keyboard's micro-USB cable into any USB port on your PC.
HP Premium - keyboard - UK - anodised aluminium trimmed Input Device
Keyboard
2.4 GHz
Wireless Receiver
Nano USB wireless receiver
Wireless
Localization and Layout
Keys Qty
110
Hot Keys Function
On/off switch
Numeric Keypad
Anodised aluminium trimmed
43.3 cm x 14.1 cm x 1.18 cm
656.1 g
1-year warranty
HP Z1 G8; Elite Slice G2; EliteBook 835 G8, 835 G9, 845 G8, 845 G9, 855 G8, 865 G9; EliteBook x360; EliteDesk 80X G6, 80X G8; EliteOne 800 G6, 800 G8; Engage One Pro; Pro Mobile Thin Client mt440 G3; ProDesk 405 G6; ProOne 400 G5, 440 G5; Workstation Z1 G5, Z1 G6, Z2, Z2 G5, Z2 G8; ZCentral 4R
Keyboard
2.4 GHz
Max Operating Distance
Up to 10 m
Wireless Receiver
Wireless
Keys Qty
110
Hot Keys Function
On/off switch
Region
United Kingdom
Keyboard Technology
Scissors
Numeric keypad
43.3 cm
14.1 cm
1.18 cm
656.1 g
Cable Length
1.8 m
Micro-USB to USB cable
CSA, UL, BSMI, cUL, CB, EMC, FCC Part 15, cCSAus, SRRC, NCC, RCM
Microsoft Windows 7, Windows 10, Windows 8.x
Rechargeable
Installed Qty
1
Lithium Ion
Limited warranty - 1 year
HP Z1 G8 , HP Elite Slice for Meeting Rooms G2 for Skype Room Systems, Slice G2, Slice G2 Audio Ready with Microsoft Teams Rooms, Slice G2 Partner Ready with Microsoft Teams Rooms, Slice G2 with Intel Unite, Slice G2 with Microsoft Teams Rooms , HP EliteBook 835 G8 Notebook, 835 G9 Notebook, 845 G8 Notebook, 845 G9 Notebook, 855 G8 Notebook, 865 G9 Notebook , HP EliteBook x360 1030 G8 Notebook, 1040 G8 Notebook , HP EliteDesk 705 G3, 705 G4, 800 G4, 800 G5, 800 G6, 800 G8, 805 G6, 805 G8 , HP EliteOne 1000 G2, 800 G3, 800 G5, 800 G6, 800 G8 , HP Engage One Pro , HP Pro Mobile Thin Client mt440 G3 , HP ProDesk 405 G6, 600 G3, 600 G4, 600 G5 , HP ProOne 400 G4, 400 G5, 440 G5 , HP Workstation Z1 G5 Entry, Z1 G6 Entry, Z2 G4, Z2 G5, Z2 G8, Z2 Mini G4 Entry, Z2 Mini G4 High Performance, Z2 Mini G4 Performance, Z2 Mini G5 , HP ZCentral 4R
