HP Wireless Mobile Mouse (Comfort Grip)
Quicklinx: 9RB9WS00 Mfr#: H2L63AA
Type: Keyboard
Wired / Wireless: Wireless
Compatibility: PC
More than 50 in stock
£26.00 ex VAT
£31.20 inc VAT
The HP Comfort Grip Wireless Mouse features a 30-month battery life and a bold, modern design that integrates seamlessly with HP Business Notebooks.
  • Use with either hand
    The asymmetric design suits both left- and right-handers.
  • Scroll
    Smoothly with the four-way tilt wheel, which lets you navigate right/left in addition to up/down.
  • Program
    Two easy-access buttons (upper left) to launch apps, control volume, navigate, zoom, or launch Web sites.
  • Add style
    Add style to your desk with the high-tech piano-black finish, blue LED, and contoured edge.
  • Monitor the battery
    Monitor the battery life via convenient button and LED; save battery life with the on/off button on the bottom.
  • Clean fast
    there's no mouse ball.
HP Wireless Comfort - mouse - 2.4 GHz
Mouse
Wireless - 2.4 GHz
6.71 cm x 10.69 cm x 3.86 cm
122.5 g
Wireless Receiver
USB wireless receiver
2 x AA type
Microsoft Windows 7, Microsoft Windows Vista
HP 24X G7, 340 G7, 470 G8; Chromebook 11 G9, 11MK G9, 14 G7; Chromebook x360; Chromebox Enterprise G3, G3; Elite x2; EliteBook x360; Mobile Thin Client mt32; Pro c640 G2, c645; ProBook 44X G8, 45X G8, 635; ProBook x360; ZBook Power G8, Studio G8; ZBook Firefly 14 G8, 15 G8; ZBook Fury 15 G8, 17 G8
Mouse
Wireless Receiver
6.71 cm
10.69 cm
3.86 cm
122.5 g
Input Device
Wireless
2.4 GHz
1 x USB - 4 pin USB Type A
AA type
Installed Qty
2
HP 240 G8, 245 G6, 245 G7, 245 G8, 246 G7, 250 G7, 250 G8, 255 G7, 255 G8, 340 G5, 340 G7, 340S G7, 348 G5, 470 G7, 470 G8 , HP Chromebook 11 G6, 11 G7, 11 G8, 11 G9, 11A G6, 11A G8, 11MK G9, 14 G5, 14 G6, 14 G7, 14A G5 , HP Chromebook Enterprise 14 G6 , HP Chromebook Enterprise x360 14E G1 , HP Chromebook x360 11 G2, 11 G3, 11 G4, 11MK G3, 14 G1 , HP Chromebox Enterprise G3, G3 , HP Elite c1030 Chromebook, c1030 Chromebook Enterprise , HP Elite Dragonfly , HP Elite x2 G8 , HP EliteBook x360 1030 G3, 1030 G4, 1030 G7, 1030 G8, 1040 G5, 1040 G6, 1040 G7, 1040 G8, 830 G5, 830 G6, 830 G7, 830 G8 , HP Mobile Thin Client mt22, mt32, mt45, mt46 , HP MX12 Retail Solution , HP Pro c640 Chromebook, c640 G2 Chromebook, c640 G2 Chromebook Enterprise, c645 Chromebook, c645 Chromebook Enterprise , HP ProBook 430 G5, 430 G6, 430 G7, 430 G8, 440 G6, 440 G7, 440 G8, 445 G6, 445 G7, 445 G8, 445r G6, 450 G5, 450 G6, 450 G7, 450 G8, 455 G5, 455 G6, 455 G7, 455 G8, 455r G6, 470 G5, 630 G8, 635 Aero G7, 635 Aero G8, 640 G4, 640 G5, 640 G8, 645 G4, 650 G4, 650 G5, 650 G8 , HP ProBook x360 11 G3, 11 G4, 11 G5, 11 G6, 11 G7, 435 G7, 435 G8, 440 G1 , HP Spectre x360 15-ch006tx , HP Stream Pro 11 G4 (Education Edition), 11 G5 , HP ZBook 14u G5 Mobile Workstation, 14u G6 Mobile Workstation, 15 G5 Mobile Workstation, 15 G6 Mobile Workstation, 15u G5 Mobile Workstation, 15u G6 Mobile Workstation, 15v G5 Mobile Workstation, 17 G5 Mobile Workstation, 17 G6 Mobile Workstation, Create G7, Power G7 Mobile Workstation, Power G8 Mobile Workstation, Studio G5 Mobile Workstation, Studio G7 Mobile Workstation, Studio G8 Mobile Workstation, Studio x360 G5 Mobile Workstation , HP ZBook Firefly 14 G7 Mobile Workstation, 14 G8 Mobile Workstation, 15 G7 Mobile Workstation, 15 G8 Mobile Workstation , HP ZBook Fury 15 G7 Mobile Workstation, 15 G8 Mobile Workstation, 17 G7 Mobile Workstation, 17 G8 Mobile Workstation , HP ZBook x2 G4 Detachable Workstation
Type: Keyboard
Compatibility: PC
Brand: HP
Stock Status: In stock
