HP Wireless Mobile Mouse (Comfort Grip)
Quicklinx: 9RB9WS00 Mfr#: H2L63AA
Type: Keyboard
Wired / Wireless: Wireless
Compatibility: PC
34 in stock
£18.30 ex VAT
£21.96 inc VAT
The HP Comfort Grip Wireless Mouse features a 30-month battery life and a bold, modern design that integrates seamlessly with HP Business Notebooks.
  • Use with either hand
    The asymmetric design suits both left- and right-handers.
  • Scroll
    Smoothly with the four-way tilt wheel, which lets you navigate right/left in addition to up/down.
  • Program
    Two easy-access buttons (upper left) to launch apps, control volume, navigate, zoom, or launch Web sites.
  • Add style
    Add style to your desk with the high-tech piano-black finish, blue LED, and contoured edge.
  • Monitor the battery
    Monitor the battery life via convenient button and LED; save battery life with the on/off button on the bottom.
  • Clean fast
    there's no mouse ball.
HP Wireless Comfort - mouse - 2.4 GHz
Mouse
Wireless - 2.4 GHz
6.71 cm x 10.69 cm x 3.86 cm
122.5 g
Wireless Receiver
USB wireless receiver
2 x AA type
Microsoft Windows 7, Microsoft Windows Vista
HP 245 G7, 340S G7, 34X G5, 470 G7; Chromebook 11 G7, 11A G6, 14 G6, 14A G5; Chromebook Enterprise x360; Chromebook x360; Elite Dragonfly; EliteBook x360; Mobile Thin Client mt45; ProBook 430 G7, 440 G7, 445r G6, 450 G7, 455r G6, 640 G5, 650 G5; ProBook x360; ZBook 14u G6, 15 G6, 15u G6, 17 G6
Mouse
Wireless Receiver
6.71 cm
10.69 cm
3.86 cm
122.5 g
Input Device
Wireless
2.4 GHz
1 x USB - 4 pin USB Type A
AA type
Installed Qty
2
OMEN by HP Pro Mobile Workstation , HP 240 G6, 245 G6, 245 G7, 250 G4, 250 G5, 250 G6, 250 G7, 255 G4, 255 G5, 255 G6, 255 G7, 340 G5, 340S G7, 348 G5, 470 G7 , HP Chromebook 11 G4, 11 G5, 11 G6, 11 G7, 11A G6, 13 G1, 14 G4, 14 G5, 14 G6, 14A G5 , HP Chromebook Enterprise x360 14E G1 , HP Chromebook x360 11 G1 (Education Edition), 11 G2, 11 G3, 14 G1 , HP Elite Dragonfly , HP Elite x2 1011 G1, 1012 G2 , HP EliteBook , HP EliteBook Folio 1020 G1, 1040 G1 , HP EliteBook x360 1030 G2, 1030 G3, 1030 G4, 1040 G5, 1040 G6, 830 G5, 830 G6 , HP ElitePad 1000 G2 , HP Mobile Thin Client mt45 , HP MX12 Retail Solution , HP Pro Tablet 610 G1 , HP Pro x2 612 G2 , HP ProBook 11 G1 (Education Edition), 430 G3, 430 G4, 430 G5, 430 G6, 430 G7, 440 G3, 440 G4, 440 G5, 440 G6, 440 G7, 445 G6, 445r G6, 450 G1, 450 G2, 450 G3, 450 G4, 450 G5, 450 G6, 450 G7, 455 G3, 455 G4, 455 G5, 455 G6, 455r G6, 470 G3, 470 G4, 470 G5, 640 G1, 640 G2, 640 G3, 640 G4, 640 G5, 645 G2, 645 G3, 645 G4, 650 G1, 650 G2, 650 G3, 650 G4, 650 G5, 655 G2, 655 G3 , HP ProBook x360 11 G2, 11 G3, 11 G4, 11 G5, 440 G1 , HP Spectre Pro x360 G2 , HP Spectre x360 15-ch006tx , HP Stream Pro 11 G3, 11 G4 (Education Edition), 11 G5 , HP x2 210 , HP x360 310 G2 , HP ZBook 14 G2 Mobile Workstation, 14u G4 Mobile Workstation, 14u G5 Mobile Workstation, 14u G6 Mobile Workstation, 15 G2 Mobile Workstation, 15 G3 Mobile Workstation, 15 G4 Mobile Workstation, 15 G5 Mobile Workstation, 15 G6 Mobile Workstation, 15 Mobile Workstation, 15u G2 Mobile Workstation, 15u G3 Mobile Workstation, 15u G4 Mobile Workstation, 15u G5 Mobile Workstation, 15u G6 Mobile Workstation, 15v G5 Mobile Workstation, 17 G3 Mobile Workstation, 17 G4 Mobile Workstation, 17 G5 Mobile Workstation, 17 G6 Mobile Workstation, 17 Mobile Workstation, Studio G3 Mobile Workstation, Studio G4 Mobile Workstation, Studio G5 Mobile Workstation, Studio x360 G5 Mobile Workstation , HP ZBook x2 G4 Detachable Workstation
Type: Keyboard
Compatibility: PC
Brand: HP
Price Range Ex VAT: 0 - 50
