HP Wireless Charger For Elite x3
Quicklinx: CD3MWS00 Mfr#: W9A82AA
£36.71 ex VAT
£44.05 inc VAT
Reduce your cable clutter and save time spent searching for the right adapter with the always-ready, always-on, HP Elite x3 Wireless Charger, which uses Qi inductive charging technology to wirelessly charge your HP Elite x3.
No connectors required
Simply set your HP Elite x3 securely on the top of the HP Elite x3 Wireless Charger to charge its battery, and the Qi inductive charging technology does the rest. A handy LED confirms the HP Elite x3 is charging.
Efficient power
Power the charger with the same USB-C™ power adapter that ships with your HP Elite x3.
Use it wherever you work
Take the lightweight, compact Charger with you in your bag when you’re working on the go, or leave it unobtrusively on your desk for wireless charging in the office.
World-class support
Rest easy with a one-year limited warranty.
  • No connectors required
  • Efficient power
    Power the charger with the same USB-C power adapter that ships with your HP Elite x3.
  • Use it wherever you work
    Take the lightweight, compact Charger with you in your bag when you're working on the go, or leave it unobtrusively on your desk for wireless charging in the office.
  • World-class support
HP - wireless charging stand
Wireless charging stand
0.1 kg
HP Graphite
16.188 cm x 8.3 cm x 0.8 cm
1-year warranty
Elite x3
HP Graphite
Limited warranty - 1 year
16.188 cm
8.3 cm
0.8 cm
0.1 kg
HP Elite x3
Brand: HP
Price Range Ex VAT: 0 - 50
