Be productive longer than with standard battery solutions with the HP VI04XL Long Life Notebook Battery, which has up to a three-year lifespan to help lower your total cost of ownership. Help reduce your overall battery waste by using fewer batteries over the life of the notebook.
Better run time
Use this long-life battery with select HP 400 Series Notebook PCs to keep working between charges, or carry one as a backup when you can't stop to plug in. -
Smart design
Get longer battery life in a thin design that integrates into the notebook's sleek profile. -
Award-winning support
Rest easy with a three-year parts replacement limited warranty.
- HP VI04XL - laptop battery - Li-Ion - 3000 mAh
- Laptop battery
- 226 g
- Battery
- Long life - Lithium Ion 4-cell - 3000 mAh
- 3.242 cm x 27.48 cm x 2.078 cm
- Designed For
- ProBook 440 G2, 445 G2, 450 G2, 455 G2
- Laptop battery
- Long life
- Technology
- 4-cell Lithium Ion
- Voltage Provided
- 14.8 V
- Capacity
- 3000 mAh
- 3.242 cm
- 27.48 cm
- 2.078 cm
- 226 g
- Shipping Width
- 29 cm
- Shipping Depth
- 23 cm
- Shipping Height
- 4.5 cm
- Designed For
- HP ProBook 440 G2, 445 G2, 450 G2, 455 G2
