HP VH22 Monitor 21.5 Inch
Quicklinx: CH3PWS00 Mfr#: X0N05AA#ABU
Diagonal Size: 21.5in
Max Resolution: 1920 x 1080
Response Time: 5ms
Speakers: None
Interfaces: DisplayPort, DVI, VGA (HD-15)
£104.80 ex VAT
£125.76 inc VAT
Invest wisely, boost productivity, and work comfortably with the business-class HP VH22 55 cm (21.5") Display, which has Full HD resolution, four-way adjustable comfort, and connectivity for your legacy and current technology.
Adjustable, personalized comfort features
Breeze through your day and achieve optimal productivity when you set the height, tilt, and swivel for the way you work best. If you want to work vertically, you can even pivot the display head 90 degrees.
Ample screen size enhanced by Full HD resolution
Enjoy striking views of your everyday content on the 55 cm (21.5") diagonal panel with sharp 1920 x 1080 Full HD resolution.
Flexible, simple connectivity
Get the essential ports you need and want with a VGA connector for legacy compatibility and DVI and DisplayPort for your newer technology.
HP vh22 - LED monitor - Full HD (1080p) - 21.5"
LED-backlit LCD monitor - 21.5"
Panel Type
TN
Aspect Ratio
16:9
Native Resolution
Pixel Pitch
0.248 mm
Brightness
250 cd/m²
Contrast Ratio
1000:1 / 5000000:1 (dynamic)
Response Time
5 ms (On/Off)
Colour Support
16.7 million colours
Input Connectors
DVI-D, VGA, DisplayPort
Display Position Adjustments
Screen Coating
Anti-glare
50.76 cm x 19.29 cm x 44.64 cm
4.5 kg
English / United Kingdom
Environmental Standards
TCO Certified Displays 7, ENERGY STAR Qualified
Plug and Play, TUV S, WHQL, CB, CCC, cTUVus, TUV Bauart, CEL Grade 1, DIN ISO 9241-307, CoC, low halogen
1-year warranty
Display Type
Diagonal Size
21.5"
Viewable Size
21.5"
Panel Type
TN
Aspect Ratio
16:9
Native Resolution
Pixel Pitch
0.248 mm
Pixel Per Inch
102
Brightness
250 cd/m²
Contrast Ratio
Colour Support
Response Time
5 ms (On/Off)
Vertical Refresh Rate
50 - 76 Hz
Horizontal Refresh Rate
24 - 80 kHz
Horizontal Viewing Angle
170
Vertical Viewing Angle
160
Screen Coating
Anti-glare
Backlight Technology
WLED
Colour Temperature
6500K
OSD Languages
Chinese (traditional), Chinese (simplified), English, German, French, Italian, Portuguese, Spanish, Dutch, Japanese
HDCP, 72% colour gamut, Mercury free, arsenic-free glass
50.76 cm x 19.29 cm x 44.64 cm - with stand
4.5 kg
VGA , DVI-D (HDCP) , DisplayPort (HDCP)
Mechanical
Tilt Angle
-5/+25
Swivel Angle
360
Rotation Angle
90
Height Adjustment
100 mm
VESA Mounting Interface
100 x 100 mm
Security lock slot (cable lock sold separately), detachable stand
1 x VGA cable - 1.8 m , 1 x DVI cable - 1.8 m , 1 x power cable - 1.9 m
Backlight Life
30,000 hours
Security Slot Type
Kensington security slot
28.5 Watt
Power Consumption Stand by
0.5 Watt
Power Consumption Sleep
0.38 Watt
Included Software
Display drivers, HP Display Assistant
Dimensions & Weight Details
Without stand - width: 50.76 cm - depth: 4.82 cm - height: 44.64 cm - weight: 2.8 kg , With stand - width: 50.76 cm - depth: 19.29 cm - height: 44.64 cm - weight: 4.5 kg
ENERGY STAR Certified
TCO Certified
Limited warranty - parts and labour - 1 year
5 °C
35 °C
20 - 80% (non-condensing)
HP VH22 Monitor 21.5 Inch Bundle deal on HP VH22 Monitor 21.5 Inch
£203.97
Response Time: 5ms
Speakers: None
Interfaces: DVI
Interfaces: VGA (HD-15)
Brand: HP
Price Range Ex VAT: 100 - 150
