HP V270 27" 1920x1080 5ms VGA DVI HDMI IPS LED Monitor
Quicklinx: FBRLWS00 Mfr#: 3PL17AA#ABU
Diagonal Size: 27in
Max Resolution: 1920 x 1080
Response Time: 5ms
Speakers: None
Interfaces: VGA (HD-15), DVI, HDMI
£135.56 ex VAT
£162.67 inc VAT
Increase productivity and enjoy expansive Full HD views on the HP V270 27-inch Monitor. The narrow bezels, spacious screen and flexible connectivity are optimal for maximum workplace efficiency at an economical price point.
  • Expansive Views
    See more with the generous 27-inch diagonal screen and narrow bezels making it easier for you to maximize productivity while creating a stylish workspace with the large, sleek bezel design.
  • Vibrant presentation features
    See more with the generous 27-inch diagonal screen and narrow bezels making it easier for you to maximize productivity and create a stylish workspace.
  • Flexible connectivity and an efficient workspace
    Utilize optimal connectivity options through VGA, DVI, and HDMI inputs while freeing up valuable desk space with the integrated 100-mm VESA pattern to directly attach select HP PCs to the back of the monitor or mount the display on a wall or to an arm or stand.
HP V270 - LED monitor - Full HD (1080p) - 27"
LED-backlit LCD monitor - 27"
Panel Type
IPS
Aspect Ratio
16:9
Native Resolution
Pixel Pitch
0.3114 mm
Brightness
300 cd/m²
Contrast Ratio
1000:1 / 10000000:1 (dynamic)
Response Time
5 ms (grey-to-grey)
Input Connectors
HDMI, DVI-D, VGA
Display Position Adjustments
Tilt
Screen Coating
Anti-glare
62.02 cm x 23.99 cm x 44.26 cm
5.2 kg
English / United Kingdom
Environmental Standards
ENERGY STAR Qualified
Plug and Play, VCCI, BSMI, WHQL, CB, CCC, PSB, KCC, WEEE, MEPS, KC, CECP, CEL, CEL Grade 1, ISC, SEPA
Display Type
Diagonal Size
27"
Panel Type
IPS
Aspect Ratio
16:9
Native Resolution
Pixel Pitch
0.3114 mm
Pixel Per Inch
81.6
Brightness
300 cd/m²
Contrast Ratio
Response Time
5 ms (grey-to-grey)
Vertical Refresh Rate
50 - 60 Hz
Horizontal Refresh Rate
30 - 80 kHz
Horizontal Viewing Angle
178
Vertical Viewing Angle
178
Screen Coating
Anti-glare
Backlight Technology
WLED
Colour Temperature
6500K
OSD Languages
Chinese (traditional), Chinese (simplified), Brazilian Portuguese, English, German, French, Italian, Spanish, Dutch, Japanese
HDCP, 72% NTSC colour gamut, Low Blue Light Mode, Mercury free, arsenic free
62.02 cm x 23.99 cm x 44.26 cm - with stand
5.2 kg
VGA , DVI-D (HDCP) , HDMI (HDCP)
Mechanical
Tilt
Tilt Angle
-5/+20
VESA Mounting Interface
100 x 100 mm
Security lock slot (cable lock sold separately), detachable stand
1 x VGA cable - 1.8 m
Backlight Life
30,000 hours
Security Slot Type
Kensington security slot
31 Watt
Power Consumption (Typical)
31 Watt
Power Consumption Sleep
0.5 Watt
Dimensions & Weight Details
With stand - width: 62.02 cm - depth: 23.99 cm - height: 44.26 cm - weight: 5.2 kg , Without stand - width: 62.02 cm - depth: 4.51 cm - height: 36.22 cm - weight: 4.7 kg
Shipping Width
69.5 cm
Shipping Depth
13.6 cm
Shipping Height
45.5 cm
Shipping Weight
6.5 kg
ENERGY STAR Certified
5 °C
35 °C
20 - 80% (non-condensing)
FBRL HP Care Pack Next Business Day Hardware Support Extended Service Agreement 3 Yrs On-Site for Monitor In Stock £30.10
Diagonal Size: 27in
Response Time: 5ms
Speakers: None
Interfaces: DVI
Interfaces: HDMI
Brand: HP
