HP V214a 20.7" 1920x1080 5ms HDMI VGA LED Monitor
Quicklinx: D2WJWS00 Mfr#: 1FR84AT#ABU
Enjoy impressive Full HD presentation features with integrated audio on the V214a 52.57 cm (20.7 inch) Monitor. The convenient connectivity, adaptability, and affordable price point are ideal for office use.
  • Crisp presentation features
    Experience a vibrant Full HD 1920 x 1080 resolution image on an ample 52.57 cm (20.7") diagonal screen with a quick 5ms response rate.
  • Efficient, adaptable workspace
    Create a clean, efficient workspace by directly attaching select HP PCs to the back of the monitor- perfect for small spaces, or use the VESA pattern to mount the display on a wall or to an arm or stand.
  • Easy connectivity and audio
    Conveniently utilize the VGA and HDMI ports for centralized connectivity, and experience integrated sound with the built in dual 1-watt speakers for your projects' audio needs.
HP V214a - LED monitor - Full HD (1080p) - 20.7"
LED-backlit LCD monitor - 20.7"
Energy Class
Class A
Energy Consumption per Year
28 kWh
Power Consumption (On mode)
19 W
Panel Type
TN
Aspect Ratio
16:9
Native Resolution
Pixel Pitch
0.2385 mm
Brightness
200 cd/m²
Contrast Ratio
600:1 / 5000000:1 (dynamic)
Response Time
5 ms (On/Off)
Colour Support
16.7 million colours
Colour Gamut
72% NTSC
Input Connectors
HDMI, VGA
Display Position Adjustments
Tilt
Screen Coating
Anti-glare
Voltage
48.94 cm x 19.7 cm x 36.27 cm
3 kg
English / United Kingdom
Environmental Standards
ENERGY STAR Qualified
Plug and Play, CSA, UL, TUV GS, WHQL, CB, FCC, ISO 9241-307, WEEE, ICES, TUV LBL
1-year warranty
Display Type
Energy Class
Class A
28 kWh
Diagonal Size
20.7"
Panel Type
TN
Aspect Ratio
16:9
Native Resolution
Pixel Pitch
0.2385 mm
Pixel Per Inch
108
Brightness
200 cd/m²
Contrast Ratio
Colour Support
Colour Gamut
72% NTSC
Response Time
5 ms (On/Off)
Vertical Refresh Rate
60 Hz
Horizontal Refresh Rate
80 kHz
Horizontal Viewing Angle
90
Vertical Viewing Angle
65
Screen Coating
Anti-glare
Backlight Technology
WLED
Colour Temperature
6500K
OSD Languages
Chinese (traditional), Chinese (simplified), English, German, French, Italian, Portuguese, Spanish, Japanese
HDCP, On-screen Digital Controls, Mercury free, 72% NTSC colour gamut
3 kg
Audio
Speakers
Output Power / Channel
1 Watt
VGA , HDMI (HDCP) , Audio line-in
Mechanical
Tilt
Tilt Angle
-5/+11
Security lock slot (cable lock sold separately), detachable stand, VESA interface support
1 x VGA cable - 1.5 m , 1 x audio cable - 1.8 m
Backlight Life
30,000 hours
Security Slot Type
Kensington security slot
Input Voltage
19 W
Power Consumption (Typical)
23 Watt
Power Consumption Stand by
0.5 Watt
Dimensions & Weight Details
Without stand - width: 48.94 cm - depth: 4.8 cm - height: 30.06 cm - weight: 2.6 kg , With stand - width: 48.94 cm - depth: 19.7 cm - height: 36.27 cm - weight: 3 kg
Sustainability Information
ENERGY STAR Certified
Limited warranty - 1 year
5 °C
35 °C
20 - 80% (non-condensing)
