HP V214a 1920 x108 LED 20.7" Monitor
Quicklinx: DC5QWS00 Mfr#: 1FR84AA#ABU
Diagonal Size: 20.7in
Max Resolution: 1920 x 1080
Response Time: 5ms
Speakers: Speaker(s)
Interfaces: HDMI, VGA (HD-15)
Hurry, only 1 left in stock!
£79.54 ex VAT
£95.44 inc VAT
This work and multimedia monitor won't burden your budget. The HP V214a features a stylish, narrow profile design, compact size and an incredibly low price. Its dynamic contrast of 5,000,000:1 and a typical 5ms response means it maintains sharpness even in faster scenes of movies and games. Due to the anti-reflective surface, the experience won't be spoiled with glares, which you will appreciate on sunny days.
  • Crisp presentation features
    Experience a vibrant Full HD 1920 x 1080 resolution image on an ample 52.57 cm (20.7") diagonal screen with a quick 5ms response rate.
  • Efficient, adaptable workspace
    Create a clean, efficient workspace by directly attaching select HP PCs to the back of the monitor- perfect for small spaces, or use the VESA pattern to mount the display on a wall or to an arm or stand.
  • Easy connectivity and audio
    Conveniently utilize the VGA and HDMI ports for centralized connectivity, and experience integrated sound with the built in dual 1-watt speakers for your projects' audio needs.
HP V214a - LED monitor - Full HD (1080p) - 20.7"
LED-backlit LCD monitor - 20.7"
Energy Class
Class A
Energy Consumption per Year
28 kWh
Power Consumption (On mode)
19 W
Panel Type
TN
Aspect Ratio
16:9
Native Resolution
Pixel Pitch
0.2385 mm
Brightness
200 cd/m²
Contrast Ratio
600:1 / 5000000:1 (dynamic)
Response Time
5 ms (On/Off)
Colour Support
16.7 million colours
Input Connectors
HDMI, VGA
Display Position Adjustments
Tilt
Screen Coating
Anti-glare
48.94 cm x 19.7 cm x 36.27 cm
3 kg
English / United Kingdom
Environmental Standards
ENERGY STAR Qualified
Plug and Play, CSA, UL, TUV GS, WHQL, CB, FCC, ISO 9241-307, WEEE, ICES, TUV LBL
1-year warranty
Display Type
Energy Class
Class A
28 kWh
19 W
Diagonal Size
20.7"
Viewable Size
20.7"
Panel Type
TN
Aspect Ratio
16:9
Native Resolution
Pixel Pitch
0.2385 mm
Pixel Per Inch
108
Brightness
200 cd/m²
Contrast Ratio
Colour Support
Response Time
5 ms (On/Off)
Vertical Refresh Rate
50 - 60 Hz
Horizontal Refresh Rate
30 - 80 kHz
Horizontal Viewing Angle
90
Vertical Viewing Angle
65
Screen Coating
Anti-glare
Backlight Technology
WLED
Colour Temperature
6500K
OSD Languages
Chinese (traditional), Chinese (simplified), English, German, French, Italian, Portuguese, Spanish, Japanese
HDCP, 72% NTSC colour gamut, On-screen Digital Controls, Low Blue Light Mode, Mercury free, arsenic-free glass
48.94 cm x 19.7 cm x 36.27 cm - with stand
3 kg
Audio
Speakers - stereo
Output Power / Channel
1 Watt
VGA , HDMI (HDCP) , Audio line-in
Mechanical
Tilt
Tilt Angle
-5/+11
VESA Mounting Interface
100 x 100 mm
Security lock slot (cable lock sold separately), detachable stand, VESA interface support
1 x VGA cable - 1.5 m , 1 x audio cable - 1.8 m
Backlight Life
30,000 hours
Security Slot Type
Kensington security slot
23 Watt
Power Consumption Stand by
0.5 Watt
Dimensions & Weight Details
Without stand - width: 48.94 cm - depth: 4.8 cm - height: 30.06 cm - weight: 2.6 kg , With stand - width: 48.94 cm - depth: 19.7 cm - height: 36.27 cm - weight: 3 kg
ENERGY STAR Certified
Limited warranty - 1 year
5 °C
35 °C
20 - 80% (non-condensing)
HP V214a 1920 x108 LED 20.7 Bundle deal on HP V214a 1920 x108 LED 20.7" Monitor
£178.71
Response Time: 5ms
Interfaces: HDMI
Interfaces: VGA (HD-15)
Brand: HP
Price Range Ex VAT: 50 - 100
