Enjoy stunning Full HD presentation of your visuals and quality, integrated speakers with the stylish HP v213a 20.7" diagonal monitor, a budget-friendly display that's just right for everyday business.
Spectacular world of color
Enjoy crisp, clear views with Full HD 1920 x 1080 resolution and 5 ms response time on an ample 20.7-inch diagonal screen. -
Create an efficient workspace
Attach your HP Desktop Mini or select Thing Client directly behind the display for an affordable, compact, integrated workspace that's perfect for small spaces. Or, use the integrated VESA mount to place the display on a wall or stand. -
Easy connectivity
Get legacy compatibility with a VGA connector, or use DVI to connect to your newer technology.
- HP v213a - LED monitor - Full HD (1080p) - 20.7"
- LED-backlit LCD monitor - 20.7"
- Panel Type
- TN
- Aspect Ratio
- 16:9
- Native Resolution
- Full HD (1080p) 1920 x 1080 at 60 Hz
- Pixel Pitch
- 0.238 mm
- Brightness
- 200 cd/m²
- Contrast Ratio
- 600:1 / 5000000:1 (dynamic)
- Response Time
- 5 ms (On/Off)
- Input Connectors
- DVI-D, VGA
- Tilt
- Screen Coating
- Anti-glare
- Voltage
- AC 120/230 V (50/60 Hz)
- Black
- 48.94 cm x 19.76 cm x 36.27 cm
- 3 kg
- Localisation
- English / United Kingdom
- Environmental Standards
- ENERGY STAR Qualified
- Plug and Play, TUV GS, VCCI, CB, CCC, FCC, WEEE, CEL, EAC, ISO9241-307
- 1-year warranty
- Display Type
- Diagonal Size
- 20.7"
- Panel Type
- TN
- Aspect Ratio
- 16:9
- Native Resolution
- Pixel Pitch
- 0.238 mm
- Brightness
- 200 cd/m²
- Contrast Ratio
- Response Time
- 5 ms (On/Off)
- Horizontal Viewing Angle
- 90
- Vertical Viewing Angle
- 65
- Screen Coating
- Anti-glare
- Backlight Technology
- LED backlight
- HDCP, On-screen Digital Controls, Mercury free, arsenic-free glass
- Black
- 48.94 cm x 19.76 cm x 36.27 cm - with stand
- 3 kg
Audio
- Speakers
- Output Power / Channel
- 1 Watt
- VGA , DVI-D (HDCP) , Audio line-in
Mechanical
- Tilt
- Tilt Angle
- -5/+11
- Security lock slot (cable lock sold separately), detachable stand
- Cables Included
- 1 x VGA cable , 1 x audio cable
- Localisation
- Input Voltage
- Power Consumption (Typical)
- 28 Watt
- Power Consumption Stand by
- 0.5 Watt
- Included Software
- Drivers & Utilities
- Dimensions & Weight Details
- With stand - width: 48.94 cm - depth: 19.76 cm - height: 36.27 cm - weight: 3 kg , Without stand - width: 48.94 cm - depth: 4.8 cm - height: 30.06 cm
Sustainability Information
- ENERGY STAR Certified
- Limited warranty - parts and labour - 1 year
- 5 °C
- 35 °C
- 20 - 80%
