HP V213a 52.57 cm (20.7") Monitor
Quicklinx: C7X4WS00 Mfr#: W3L13AT#ABU
Enjoy stunning Full HD presentation of your visuals and quality, integrated speakers with the stylish HP v213a 20.7" diagonal monitor, a budget-friendly display that's just right for everyday business.
  • Spectacular world of color
    Enjoy crisp, clear views with Full HD 1920 x 1080 resolution and 5 ms response time on an ample 20.7-inch diagonal screen.
  • Create an efficient workspace
    Attach your HP Desktop Mini or select Thing Client directly behind the display for an affordable, compact, integrated workspace that's perfect for small spaces. Or, use the integrated VESA mount to place the display on a wall or stand.
  • Easy connectivity
    Get legacy compatibility with a VGA connector, or use DVI to connect to your newer technology.
HP v213a - LED monitor - Full HD (1080p) - 20.7"
LED-backlit LCD monitor - 20.7"
Panel Type
TN
Aspect Ratio
16:9
Native Resolution
Pixel Pitch
0.238 mm
Brightness
200 cd/m²
Contrast Ratio
600:1 / 5000000:1 (dynamic)
Response Time
5 ms (On/Off)
Input Connectors
DVI-D, VGA
Display Position Adjustments
Tilt
Screen Coating
Anti-glare
Voltage
48.94 cm x 19.76 cm x 36.27 cm
3 kg
English / United Kingdom
Environmental Standards
ENERGY STAR Qualified
Plug and Play, TUV GS, VCCI, CB, CCC, FCC, WEEE, CEL, EAC, ISO9241-307
1-year warranty
Display Type
Diagonal Size
20.7"
Panel Type
TN
Aspect Ratio
16:9
Native Resolution
Pixel Pitch
0.238 mm
Brightness
200 cd/m²
Contrast Ratio
Response Time
5 ms (On/Off)
Horizontal Viewing Angle
90
Vertical Viewing Angle
65
Screen Coating
Anti-glare
Backlight Technology
LED backlight
HDCP, On-screen Digital Controls, Mercury free, arsenic-free glass
48.94 cm x 19.76 cm x 36.27 cm - with stand
3 kg
Audio
Speakers
Output Power / Channel
1 Watt
VGA , DVI-D (HDCP) , Audio line-in
Mechanical
Tilt
Tilt Angle
-5/+11
Security lock slot (cable lock sold separately), detachable stand
1 x VGA cable , 1 x audio cable
Input Voltage
Power Consumption (Typical)
28 Watt
Power Consumption Stand by
0.5 Watt
Included Software
Drivers & Utilities
Dimensions & Weight Details
With stand - width: 48.94 cm - depth: 19.76 cm - height: 36.27 cm - weight: 3 kg , Without stand - width: 48.94 cm - depth: 4.8 cm - height: 30.06 cm
Sustainability Information
ENERGY STAR Certified
Limited warranty - parts and labour - 1 year
5 °C
35 °C
20 - 80%
