The affordable LED business display designed for every day. Get quality presentation features at a price point that doesn't break the bank. This sleek, thin-profile LED monitor delivers 1600x900 resolution, VGA input and audio support in a space-saving 49,4 cm (19.45') diagonal screen size. Enjoy business-class brightness, contrast, and clarity in an environmentally responsible design that's easy on the wallet.
Affordable, stylish, and compact
Get a stylish and budget-friendly design that complements HP PCs and has a small footprint that leaves plenty of room on the desk. The internal power supply helps keep your workspace tidy.Quickly and easily connect to your media and devices with VGA input and audio support. -
Business-class content presentation in an efficient screen size
Step up to a 49,4 cm (19.45') diagonal screen that offers ample screen space for everything you do every day.Enjoy crisp, clear views of your content with 16:9 aspect ratio, 3 M:1 dynamic contrast ratio, 200 nits of brightness and 5 ms on/off response time. Get easy device connectivity from the VGA input. -
Adjustable tilt positioning
Make yourself comfortable with adjustable tilt stand. -
Designed with the environment in mind and backed by HP support
Be a better environmental consumer with a monitor that has mercury-free LED display backlights.Get worldwide service and support from a standard, one-year limited HP warranty.
- HP V201a - LED monitor - 19.45"
- LED-backlit LCD monitor - 19.45"
- Aspect Ratio
- 16:9
- Native Resolution
- 1600 x 900
- Pixel Pitch
- 0.27 mm
- Brightness
- 200 cd/m²
- Contrast Ratio
- 600:1 / 3000000:1 (dynamic)
- Response Time
- 5 ms (On/Off)
- Tilt
- Voltage
- AC 120/230 V (50/60 Hz)
- Black
- 46.8 cm x 19 cm x 35.53 cm
- 2.8 kg
- Localisation
- English / United Kingdom
- Plug and Play
- 1-year warranty
- Display Type
- Diagonal Size
- 19.45"
- Aspect Ratio
- 16:9
- Native Resolution
- 1600 x 900
- Pixel Pitch
- 0.27 mm
- Brightness
- 200 cd/m²
- Contrast Ratio
- Response Time
- 5 ms (On/Off)
- Horizontal Viewing Angle
- 90
- Vertical Viewing Angle
- 50
- Backlight Technology
- LED backlight
- Anti-glare, Mercury free
- Black
- 46.8 cm x 19 cm x 35.53 cm - with stand
- 2.8 kg
- VGA , Audio line-in
Mechanical
- Tilt
- Tilt Angle
- -5/+15
- Cables Included
- 1 x VGA cable , 1 x audio cable
- Plug and Play
- Localisation
- Power Supply
- Internal
- Input Voltage
- Power Consumption (Typical)
- 19 Watt
- Power Consumption Stand by
- 0.5 Watt
- Included Software
- HP Display Assistant
- Dimensions & Weight Details
- Without stand - width: 46.8 cm - depth: 4.69 cm - height: 28.87 cm
- Limited warranty - parts and labour - 1 year
- 5 °C
- 35 °C
- 20 - 80% (non-condensing)
