Product
HP V201a 19.45" 1600x900 5ms VGA LED Backlit Monitor
Quicklinx: BKQHWS00 Mfr#: F8C55AA#ABU
The affordable LED business display designed for every day. Get quality presentation features at a price point that doesn't break the bank. This sleek, thin-profile LED monitor delivers 1600x900 resolution, VGA input and audio support in a space-saving 49,4 cm (19.45') diagonal screen size. Enjoy business-class brightness, contrast, and clarity in an environmentally responsible design that's easy on the wallet.
  • Affordable, stylish, and compact
    Get a stylish and budget-friendly design that complements HP PCs and has a small footprint that leaves plenty of room on the desk. The internal power supply helps keep your workspace tidy.Quickly and easily connect to your media and devices with VGA input and audio support.
  • Business-class content presentation in an efficient screen size
    Step up to a 49,4 cm (19.45') diagonal screen that offers ample screen space for everything you do every day.Enjoy crisp, clear views of your content with 16:9 aspect ratio, 3 M:1 dynamic contrast ratio, 200 nits of brightness and 5 ms on/off response time. Get easy device connectivity from the VGA input.
  • Adjustable tilt positioning
    Make yourself comfortable with adjustable tilt stand.
  • Designed with the environment in mind and backed by HP support
    Be a better environmental consumer with a monitor that has mercury-free LED display backlights.Get worldwide service and support from a standard, one-year limited HP warranty.
HP V201a - LED monitor - 19.45"
LED-backlit LCD monitor - 19.45"
Aspect Ratio
16:9
Native Resolution
1600 x 900
Pixel Pitch
0.27 mm
Brightness
200 cd/m²
Contrast Ratio
600:1 / 3000000:1 (dynamic)
Response Time
5 ms (On/Off)
Display Position Adjustments
Tilt
46.8 cm x 19 cm x 35.53 cm
2.8 kg
English / United Kingdom
Plug and Play
1 year warranty
Display Type
Diagonal Size
19.45"
Viewable Size
19.45"
Aspect Ratio
16:9
Native Resolution
1600 x 900
Pixel Pitch
0.27 mm
Brightness
200 cd/m²
Contrast Ratio
Response Time
5 ms (On/Off)
Horizontal Viewing Angle
90
Vertical Viewing Angle
50
Backlight Technology
LED backlight
Anti-glare, Mercury free
46.8 cm x 19 cm x 35.53 cm - with stand
2.8 kg
VGA , Audio line-in
Mechanical
Tilt
Tilt Angle
-5/+15
1 x VGA cable , 1 x audio cable
Plug and Play
Power Supply
Internal
19 Watt
Power Consumption Stand by
0.5 Watt
Included Software
HP Display Assistant
Dimensions & Weight Details
Without stand - width: 46.8 cm - depth: 4.69 cm - height: 28.87 cm
Limited warranty - parts and labour - 1 year
5 °C
35 °C
20 - 80% (non-condensing)
