HP v196 18.5" LED Monitor 1366x768
Quicklinx: C9DGWS00 Mfr#: V5J61AT#ABU
Diagonal Size: 18.5in
Max Resolution: 1366 x 768
Response Time: 5ms
Speakers: None
Interfaces: DVI, VGA (HD-15)
More than 50 in stock
£68.00 ex VAT
£81.60 inc VAT
Get quality presentation features at a price point that doesn't break the bank with the HP V197 47 cm (18.5") Monitor, a sleek, thin-profile monitor in a compact, space-saving screen size with an unbelievably low price point.
  • Business-class presentation features
    Enjoy crisp, clear views of your documents and e-mail with 1366 x 768 resolution, 5M:1 dynamic contrast ratio, and 5 ms response time on an 47 cm (18.5") inch diagonal screen. Quickly and easily connect to your devices with DVI and VGA inputs.
  • Create an efficient workspace
    Mount your HP Desktop Mini 260 directly behind the display for an integrated, affordable all-in-one that's perfect for small spaces. Or, use the integrated VESA mount to place the display on a wall or stand.
  • Designed with the environment in mind
    Reduce power consumption and help lower your costs with an intelligent, energy-efficient design that is ENERGY STAR certified and EPEAT Silver registered. The display also includes mercury-free display backlights and arsenic-free display glass.
HP v197 - LED monitor - 18.5"
LED-backlit LCD monitor - 18.5"
Panel Type
TN
Aspect Ratio
16:9
Native Resolution
1366 x 768 at 60 Hz
Pixel Pitch
0.3 mm
Brightness
200 cd/m²
Contrast Ratio
600:1 / 5000000:1 (dynamic)
Response Time
5 ms (On/Off)
Input Connectors
DVI-D, VGA
Display Position Adjustments
Tilt
Screen Coating
Anti-glare
44.14 cm x 21.81 cm x 33.86 cm
2.6 kg
English / United Kingdom
Environmental Standards
ENERGY STAR Qualified
Plug and Play, TUV, GS, CB, CCC
1-year warranty
Display Type
Diagonal Size
18.5"
Viewable Size
18.5"
Panel Type
TN
Aspect Ratio
16:9
Native Resolution
1366 x 768 at 60 Hz
Pixel Pitch
0.3 mm
Brightness
200 cd/m²
Contrast Ratio
Response Time
5 ms (On/Off)
Horizontal Viewing Angle
90
Vertical Viewing Angle
65
Screen Coating
Anti-glare
Backlight Technology
LED backlight
HDCP, Mercury free, arsenic-free glass
44.14 cm x 21.81 cm x 33.86 cm - with stand
2.6 kg
VGA (HDCP) , DVI-D (HDCP)
Mechanical
Tilt
Tilt Angle
-5/+22
1 x VGA cable
17 Watt
Power Consumption Stand by
0.5 Watt
Included Software
HP Display Assistant
Dimensions & Weight Details
With stand - width: 44.14 cm - depth: 21.81 cm - height: 33.86 cm - weight: 2.6 kg , Without stand - width: 44.14 cm - depth: 4.54 cm - height: 27.77 cm
ENERGY STAR Certified
Limited warranty - parts and labour - 1 year
5 °C
35 °C
20 - 80%
HP v196 18.5 Bundle deal on HP v196 18.5" LED Monitor 1366x768
£167.17
Response Time: 5ms
Speakers: None
Interfaces: DVI
Interfaces: VGA (HD-15)
Brand: HP
Price Range Ex VAT: 50 - 100
