HP V194 18.5" 1336x768 5ms VGA LED Monitor
Quicklinx: FBQ8WS00 Mfr#: 5YR89AT#ABU
Diagonal Size: 18.5in
Max Resolution: 1366 x 768
Response Time: 5ms
Interfaces: VGA (HD-15)
£70.96 ex VAT
£85.15 inc VAT
Get quality presentation features at a price point that doesn't break the bank with the HP V194 18.5-inch Monitor, a sleek, thin-profile monitor in a compact, space-saving screen size with an unbelievably low price point.
  • Business-class presentation features
    Enjoy crisp, clear views of your documents and e-mail with 1366 x 768 resolution, 5M:1 dynamic contrast ratio, and 5 ms response time on an 18.5-inch diagonal screen. Quickly and easily connect to your devices with a VGA input.
  • Create an efficient, smart setup
    Attach your HP Desktop Mini, HP Chromebox, or select HP Thin Client directly behind the display for an integrated, affordable workspace that's perfect for small spaces. Or, use the integrated VESA mount to place the display on a wall or stand.
  • Designed with the environment in mind
    Reduce power consumption and help lower your costs with an intelligent, energy-efficient design that is ENERGY STAR certified and EPEAT Silver registered. The display also includes mercury-free display backlights and arsenic-free display glass.
HP V194 - LED monitor - 18.5"
LED-backlit LCD monitor - 18.5"
Panel Type
TN
Aspect Ratio
16:9
Native Resolution
1366 x 768 at 60 Hz
Pixel Pitch
0.3 mm
Brightness
200 cd/m²
Contrast Ratio
600:1 / 5000000:1 (dynamic)
Response Time
5 ms (On/Off)
Input Connectors
VGA
Display Position Adjustments
Tilt
Screen Coating
Anti-glare
44.14 cm x 21.81 cm x 33.86 cm
2.6 kg
English / United Kingdom
Environmental Standards
ENERGY STAR Qualified
Plug and Play, TUV, TUV GS, VCCI, BSMI, NOM, TUV S, CB, CCC, PSB, FCC, ETL, KCC, ICES, KC, CECP, CEL, EPA, ISC, SEPA
1-year warranty
Display Type
Diagonal Size
18.5"
Viewable Size
18.5"
Panel Type
TN
Aspect Ratio
16:9
Native Resolution
1366 x 768 at 60 Hz
Pixel Pitch
0.3 mm
Brightness
200 cd/m²
Contrast Ratio
Response Time
5 ms (On/Off)
Horizontal Viewing Angle
90
Vertical Viewing Angle
65
Screen Coating
Anti-glare
Backlight Technology
LED backlight
Mercury free, arsenic free
44.14 cm x 21.81 cm x 33.86 cm - with stand
2.6 kg
VGA
Mechanical
Tilt
Tilt Angle
-5/+22
VESA Mounting Interface
1 x VGA cable
Security Slot Type
Kensington security slot
AC 120/230 V
15 Watt
Power Consumption Stand by
0.5 Watt
Dimensions & Weight Details
Without stand - width: 44.14 cm - depth: 4.54 cm - height: 27.77 cm , With stand - width: 44.14 cm - depth: 21.81 cm - height: 33.86 cm - weight: 2.6 kg
ENERGY STAR Certified
Limited warranty - parts and labour - 1 year
5 °C
35 °C
20 - 80%
Response Time: 5ms
Brand: HP
Price Range Ex VAT: 50 - 100
