HP V193 18.5" 1366x768 5ms VGA LED Monitor
Quicklinx: B01SWS00 Mfr#: G9W86AT#ABU
Get quality presentation features at a price point that doesn't break the bank with the HP V193 47,0 cm (18.5") LED Backlit Monitor, a sleek, thin-profile monitor in a compact, space-saving screen size with an unbelievably low price point.
  • Business-class presentation features
    Enjoy crisp, clear views of your documents and e-mail with 1366 x 768 resolution, 5M:1 dynamic contrast ratio, and 5 ms response time on an 47,0 cm (18.5") diagonal screen. Quickly and easily connect to your devices with a VGA input.
  • Affordable, stylish, and compact
    Make a good impression and leave plenty of room on the desk with a design that complements HP PCs and has a small footprint. The internal power supply also helps keep your workspace tidy.
  • Designed with the environment in mind
    Reduce power consumption and help lower your costs with an intelligent, energy-efficient design that is ENERGY STAR qualified and EPEAT Silver registered. The display also includes mercury-free display backlights and arsenic-free display glass.
HP v193 - LED monitor - 18.5"
LED-backlit LCD monitor - 18.5"
Panel Type
TN
Aspect Ratio
16:9
Native Resolution
1366 x 768 at 60 Hz
Pixel Pitch
0.3 mm
Brightness
200 cd/m²
Contrast Ratio
600:1 / 5000000:1 (dynamic)
Response Time
5 ms (On/Off)
Colour Support
16.7 million colours
Colour Gamut
72%
Input Connectors
VGA
Display Position Adjustments
Tilt
Voltage
44.14 cm x 18.9 cm x 33.86 cm
2.7 kg
English / United Kingdom
Environmental Standards
ENERGY STAR Qualified
Plug and Play, TUV, TUV GS, VCCI, BSMI, NOM, TUV S, CB, CCC, PSB, FCC, ETL, KCC, ICES, KC, CECP, EPA, CEL Grade 1, ISC
1-year warranty
Display Type
Diagonal Size
18.5"
Panel Type
TN
Aspect Ratio
16:9
Native Resolution
1366 x 768 at 60 Hz
Pixel Pitch
0.3 mm
Brightness
200 cd/m²
Contrast Ratio
Colour Support
Colour Gamut
72%
Response Time
5 ms (On/Off)
Vertical Refresh Rate
50 - 60 Hz
Horizontal Refresh Rate
24 - 70 kHz
Video Bandwidth
110 MHz
Horizontal Viewing Angle
90
Vertical Viewing Angle
65
Backlight Technology
WLED
Colour Temperature
6500K
Controls & Adjustments
Brightness, contrast, colour balance
OSD Languages
Chinese (traditional), Chinese (simplified), English, German, French, Italian, Portuguese, Spanish, Dutch, Japanese
Anti-glare
44.14 cm x 18.9 cm x 33.86 cm - with stand
2.7 kg
VGA
Mechanical
Tilt
Tilt Angle
-5/+20
VESA Mounting Interface
100 x 100 mm
Security lock slot (cable lock sold separately), detachable stand
1 x VGA cable - 1.5 m
Backlight Life
30,000 hours
Power Supply
Internal
Input Voltage
Power Consumption (Typical)
17 Watt
Power Consumption Stand by
0.5 Watt
Dimensions & Weight Details
Without stand - width: 44.14 cm - depth: 4.54 cm - height: 27.77 cm - weight: 2.4 kg , With stand - width: 44.14 cm - depth: 18.9 cm - height: 33.86 cm - weight: 2.7 kg
Sustainability Information
ENERGY STAR Certified
Limited warranty - 1 year
5 °C
35 °C
20 - 80% (non-condensing)
