Get quality presentation features at a price point that doesn't break the bank with the HP V193 47,0 cm (18.5") LED Backlit Monitor, a sleek, thin-profile monitor in a compact, space-saving screen size with an unbelievably low price point.
Business-class presentation features
Enjoy crisp, clear views of your documents and e-mail with 1366 x 768 resolution, 5M:1 dynamic contrast ratio, and 5 ms response time on an 47,0 cm (18.5") diagonal screen. Quickly and easily connect to your devices with a VGA input. -
Affordable, stylish, and compact
Make a good impression and leave plenty of room on the desk with a design that complements HP PCs and has a small footprint. The internal power supply also helps keep your workspace tidy. -
Designed with the environment in mind
Reduce power consumption and help lower your costs with an intelligent, energy-efficient design that is ENERGY STAR qualified and EPEAT Silver registered. The display also includes mercury-free display backlights and arsenic-free display glass.
- HP v193 - LED monitor - 18.5"
- LED-backlit LCD monitor - 18.5"
- Panel Type
- TN
- Aspect Ratio
- 16:9
- Native Resolution
- 1366 x 768 at 60 Hz
- Pixel Pitch
- 0.3 mm
- Brightness
- 200 cd/m²
- Contrast Ratio
- 600:1 / 5000000:1 (dynamic)
- Response Time
- 5 ms (On/Off)
- Colour Support
- 16.7 million colours
- Colour Gamut
- 72%
- Input Connectors
- VGA
- Tilt
- Voltage
- AC 120/230 V (50/60 Hz)
- Black
- 44.14 cm x 18.9 cm x 33.86 cm
- 2.7 kg
- Localisation
- English / United Kingdom
- Environmental Standards
- ENERGY STAR Qualified
- Plug and Play, TUV, TUV GS, VCCI, BSMI, NOM, TUV S, CB, CCC, PSB, FCC, ETL, KCC, ICES, KC, CECP, EPA, CEL Grade 1, ISC
- 1-year warranty
- Display Type
- Diagonal Size
- 18.5"
- Panel Type
- TN
- Aspect Ratio
- 16:9
- Native Resolution
- Pixel Pitch
- 0.3 mm
- Brightness
- 200 cd/m²
- Contrast Ratio
- Colour Support
- Colour Gamut
- 72%
- Response Time
- 5 ms (On/Off)
- Vertical Refresh Rate
- 50 - 60 Hz
- Horizontal Refresh Rate
- 24 - 70 kHz
- Video Bandwidth
- 110 MHz
- Horizontal Viewing Angle
- 90
- Vertical Viewing Angle
- 65
- Backlight Technology
- WLED
- Colour Temperature
- 6500K
- Controls & Adjustments
- Brightness, contrast, colour balance
- OSD Languages
- Chinese (traditional), Chinese (simplified), English, German, French, Italian, Portuguese, Spanish, Dutch, Japanese
- Anti-glare
- Black
- 44.14 cm x 18.9 cm x 33.86 cm - with stand
- 2.7 kg
- VGA
Mechanical
- Tilt
- Tilt Angle
- -5/+20
- VESA Mounting Interface
- 100 x 100 mm
- Security lock slot (cable lock sold separately), detachable stand
- Cables Included
- 1 x VGA cable - 1.5 m
- Backlight Life
- 30,000 hours
- Localisation
- Power Supply
- Internal
- Input Voltage
- Power Consumption (Typical)
- 17 Watt
- Power Consumption Stand by
- 0.5 Watt
- Dimensions & Weight Details
- Without stand - width: 44.14 cm - depth: 4.54 cm - height: 27.77 cm - weight: 2.4 kg , With stand - width: 44.14 cm - depth: 18.9 cm - height: 33.86 cm - weight: 2.7 kg
Sustainability Information
- ENERGY STAR Certified
- Limited warranty - 1 year
- 5 °C
- 35 °C
- 20 - 80% (non-condensing)
