HP USB Business Speakers V2
Quicklinx: CYRLWS00 Mfr#: N3R89AA
Quickly and easily add stereo sound to your workspace with HP USB Business Speakers v2, a set of stylish desktop speakers powered by your PC's USB port.
  • Simple setup
    Connect the included cables to any USB port and headphone or lineout port on your PC, then position the speakers wherever you need them.
  • Intuitive features
    Turn the speakers on and adjust the volume with a conveniently-located top knob on the right speaker. The white LED confirms power.
  • Supported by HP
    Rest easy with a one-year limited warranty.
HP USB Business speakers v2 - speakers - for PC
Speakers - for PC
System Components
2 speakers
Speaker Type
Active
Nominal Output Power (Total)
4 Watt
Audio System Peak Power (Total)
4.6 Watt
Frequency Response
200 - 20000 Hz
Amplifier
Integrated
Speaker System Details
2 x speaker 2 Watt - 200 - 20000 Hz - 4 Ohm
Power Options
USB powered
6.95 cm x 8.95 cm x 17 cm
550 g
1-year warranty
HP 260 G2, 260 G3, 280 G3, 290 G1; Desktop Pro A G2; Elite Slice for Meeting Rooms G2, Slice G2; EliteDesk 705 G1, 705 G3, 705 G4, 800 G2, 800 G4, 800 G5; ProDesk 400 G1, 400 G2, 400 G2.5, 400 G3, 400 G4, 400 G5, 400 G6, 405 G1, 405 G2, 405 G4, 490 G3, 600 G1, 600 G3, 600 G4; Workstation Z1 G5
Speakers - for PC
Enclosure Colour
Grille Colour
Speaker System
System Components
2 speakers
Speaker Type
Active
Audio System Continuous Power (Total)
4 Watt
4.6 Watt
Frequency Response
200 - 20000 Hz
Amplifier
Integrated
Controls
Power on/off, volume
Speakers Included
2 x speaker - 2 Watt - 200 - 20000 Hz - 4 Ohm - wired
Connector Type
Audio line-in (mini-phone stereo 3.5 mm)
Software kit
Power Source
USB
Options
USB powered
6.95 cm
8.95 cm
17 cm
550 g
Limited warranty - 1 year
HP 260 G2, 260 G3, 280 G3, 290 G1 , HP Desktop Pro A G2 , HP Elite Slice for Meeting Rooms G2 for Skype Room Systems, Slice G2 Audio Ready with Microsoft Teams Rooms, Slice G2 Partner Ready with Microsoft Teams Rooms, Slice G2 with Intel Unite, Slice G2 with Microsoft Teams Rooms , HP EliteDesk 705 G1, 705 G3, 705 G4, 800 G2, 800 G4, 800 G5 , HP ProDesk 400 G1, 400 G2, 400 G2.5, 400 G3, 400 G4, 400 G5, 400 G6, 405 G1, 405 G2, 405 G4, 490 G3, 600 G1, 600 G3, 600 G4 , HP Workstation Z1 G5 Entry
