Product
HP USB 3.0 TO GIGABIT ADAPTER
Clearance!
Clearance
Quicklinx: CHXHWS00 Mfr#: N7P47AA
More than 50 in stock
£21.56 ex VAT
£25.87 inc VAT
Convert your notebook's high-speed USB 3.0 connection to a fast 10/100/1000 Ethernet connection with the USB 3.0 to Giga LAN Adapter.
Forego wireless
Get reliable connectivity from a wired Ethernet connection to corporate networks and the Internet.
Easy to use
Connect the USB end of the adapter to any USB 3.0 or USB 2.0 port on your notebook and the Ethernet connector to your Ethernet cable (sold separately)—there are no drivers to download because they’re preinstalled.
World-class support.
Rest easy with a one-year limited warranty.
  • Forego wireless
  • Easy to use
    Connect the USB end of the adapter to any USB 3.0 or USB 2.0 port on your notebook and the Ethernet connector to your Ethernet cable (sold separately)-there are no drivers to download because they're preinstalled.
  • World-class support
HP - network adapter
Network adapter
External
Interface (Bus) Type
SuperSpeed USB 3.0
Ports
Gigabit Ethernet
6.1 cm x 2 cm x 1.4 cm
19 g
GigE
Data Transfer Rate
1 Gbps
Google Chrome OS, Microsoft Windows 7 / 8 (32/64 bits)
1 year warranty
Chromebook 14 G4, 14 G5; DesignJet T1700, T1700dr, T1708, T1708dr, T730, T830, Z6, Z6dr, Z9+, Z9+dr; Elite x2; EliteBook 1030 G1, 1040 G4; EliteBook Revolve 810 G3; EliteBook x360; Pro x2; ProBook 430 G5, 440 G5, 450 G5, 455 G5, 470 G5; Spectre Pro x360 G2; Stream Pro 11 G3, 11 G4; x2
Network adapter
External
SuperSpeed USB 3.0
Ports
Gigabit Ethernet
Wired
Gigabit Ethernet
Data Transfer Rate
1 Gbps
1 x 1000Base-T - RJ-45 - female
6.1 cm
2 cm
1.4 cm
19 g
Limited warranty - 1 year
HP Chromebook 14 G4, 14 G5 , HP DesignJet T1700, T1700 PostScript, T1700dr, T1700dr PostScript, T1708, T1708 PostScript, T1708dr, T1708dr PostScript, T730, T830, Z6 PostScript, Z6dr, Z6dr PostScript with V-Trimmer, Z9+ PostScript, Z9+dr, Z9+dr PostScript , HP Elite x2 1012 G1, 1012 G2, 1013 G3 , HP EliteBook 1030 G1, 1040 G4 , HP EliteBook Revolve 810 G3 Tablet , HP EliteBook x360 1012 G2, 1030 G2 , HP Pro x2 612 G2 , HP ProBook 430 G5, 440 G5, 450 G5, 455 G5, 470 G5 , HP Spectre Pro x360 G2 , HP Stream Pro 11 G3, 11 G4 (Education Edition) , HP x2 210 G2
Brand: HP
Price Range Ex VAT: 0 - 50
