HP Ultra Slim Docking Station - 2013
Quicklinx: 9C4TWS00 Mfr#: D9Y32ET#ABU
Device Type: Laptop
Device Screen Size: [N/A]
£167.21 ex VAT
£200.65 inc VAT
Designed exclusively for ultraslim HP EliteBook Notebook PCs, the HP UltraSlim Docking Station expands display, network, and device connectivity so you can be more productive throughout the day-all through a simple one-click slide-in side dock.
Get high-speed connectivity to the USB devices you use most with four USB 3.0 ports, which reduce the time required for data transmission (vs. USB 2.0), are backward compatible with USB 2.0, and bi-directional.
HP UltraSlim Docking Station 2013 - docking station - VGA, 2 x DP
Docking station
Video Interfaces
VGA, 2 x DP
36.8 cm x 10.7 cm x 4.4 cm
760 g
English / United Kingdom
Power adapter - external 65 Watt
EliteBook 735 G5, 735 G6, 745 G4, 745 G5, 745 G6, 755 G4, 755 G5, 820 G4, 830 G5, 830 G6, 840 G4, 840 G5, 840 G6, 840r G4, 850 G4, 850 G5, 850 G6; Mobile Thin Client mt45; ProBook 640 G5, 64X G3, 64X G4, 650 G4, 650 G5, 65X G3; Spectre x360; ZBook 14u G4, 14u G5, 14u G6, 15u G4, 15u G5, 15u G6
Docking station
36.8 cm
10.7 cm
4.4 cm
760 g
4 x SuperSpeed USB 3.0 - 9 pin USB Type A , 2 x audio / video - DisplayPort - 20 pin DisplayPort , 1 x network - Ethernet - RJ-45 , 1 x display / video - VGA - 15 pin D-Sub (DB-15) , 1 x audio - line-In - mini-phone stereo 3.5 mm , 1 x audio - line-out - mini-phone stereo 3.5 mm
Charging via USB, LED indicator, 2 security lock slots (cable lock sold separately)
Security Slot Type
Kensington security slot
Power Provided
65 Watt
35 °C
HP EliteBook 1030 G1, 1040 G3, 720 G1, 720 G2, 725 G2, 725 G3, 725 G4, 735 G5, 735 G6, 740 G1, 740 G2, 745 G2, 745 G3, 745 G4, 745 G5, 745 G6, 750 G1, 750 G2, 755 G2, 755 G3, 755 G4, 755 G5, 820 G1, 820 G2, 820 G3, 820 G4, 830 G5, 830 G6, 840 G1, 840 G2, 840 G3, 840 G4, 840 G5, 840 G6, 840r G4, 850 G1, 850 G2, 850 G3, 850 G4, 850 G5, 850 G6 , HP EliteBook Folio 1020 G1, 1040 G1, 1040 G2, 9470m, 9480m , HP EliteBook Revolve 810 G1 Tablet, 810 G2 Tablet, 810 G3 Tablet , HP Mobile Thin Client mt45 , HP Pro x2 612 G1 , HP ProBook 640 G2, 640 G3, 640 G4, 640 G5, 645 G2, 645 G3, 645 G4, 650 G2, 650 G3, 650 G4, 650 G5, 655 G2, 655 G3 , HP Spectre x360 15-ch006tx , HP ZBook 14 G2 Mobile Workstation, 14 Mobile Workstation, 14u G4 Mobile Workstation, 14u G5 Mobile Workstation, 14u G6 Mobile Workstation, 15u G2 Mobile Workstation, 15u G3 Mobile Workstation, 15u G4 Mobile Workstation, 15u G5 Mobile Workstation, 15u G6 Mobile Workstation
9C4T HP Docking Station Cable Lock In Stock £38.22
9C4T HP Care Pack Advanced Unit Exchange Hardware Support Extended Service Agreement 3 Years Shipment In Stock £15.64
Device Type: Laptop
Brand: HP
