HP Ultra Slim Docking Station - 2013
Quicklinx: 9C4TWS00 Mfr#: D9Y32ET#ABU
Designed exclusively for ultraslim HP EliteBook Notebook PCs, the HP UltraSlim Docking Station expands display, network, and device connectivity so you can be more productive throughout the day-all through a simple one-click slide-in side dock.
Get high-speed connectivity to the USB devices you use most with four USB 3.0 ports, which reduce the time required for data transmission (vs. USB 2.0), are backward compatible with USB 2.0, and bi-directional.
HP UltraSlim Docking Station 2013 - docking station - VGA, 2 x DP
Docking station
Video Interfaces
VGA, 2 x DP
36.8 cm x 10.7 cm x 4.4 cm
760 g
English / United Kingdom
Power adapter - external 65 Watt Power Provided
Docking station
36.8 cm
10.7 cm
4.4 cm
760 g
4 x SuperSpeed USB 3.0 - 9 pin USB Type A , 2 x audio / video - DisplayPort - 20 pin DisplayPort , 1 x network - Ethernet - RJ-45 , 1 x display / video - VGA - 15 pin D-Sub (DB-15) , 1 x audio - line-In - mini-phone stereo 3.5 mm , 1 x audio - line-out - mini-phone stereo 3.5 mm
Charging via USB, LED indicator, 2 security lock slots (cable lock sold separately)
Security Slot Type
Kensington security slot
Power Provided
65 Watt
35 °C
