HP U160 Portable 15.6" Monitor
Quicklinx: 90THWS00 Mfr#: D4T56AT#ABU
Adding a second screen to your notebook just got radically simpler with the lightweight HP U160 39,6 cm (15.6') LED Backlit Monitor. Increase your productivity with a portable companion display that quickly opens into its own tilt-adjustable stand and easily connects to your notebook with one USB cable. Share presentations across a table or desk wherever you work. The adjustable stand quickly converts back into a carrying case so you can stow and go.
  • Increase productivity with a companion display for your notebook
    The super light and thin HP U160 companion display sets up and folds down in a snap, and connects to any notebook with a USB 2.0 port.Ample 39,6 cm (15.6') diagonal screen size, 16:9 widescreen aspect ratio, contrast ratio, and brightness aligns with most traditional notebook screens-without the weight and bulk of carrying a second notebook.
  • Designed for easy portability
    The integrated flip & fold case deploys the monitor quickly, doubles as a stand, and helps protect the display while stored.Lightweight and thin, the modern design slides easily into your notebook carrying case right beside your notebook so you can take it with you wherever you work.The included USB cord stores easily into a built-in pocket on the case for quick accessibility.
  • Ideal for on-the-go presentations
    Expand your screen real-estate so you can show and share presentations without crowding around a single notebook screen.Easy setup doesn't require a second power cord-get up and running quickly with the single USB cord (included) and work at a desk in the office or in a hotel room, restaurant, lobby, or public meeting space.
  • Earn your environmental stripes
    The intelligent, energy-efficient design is built with the environment in mind to help you reduce power consumption.Mercury-Free LED backlighting, BFR/PVC-free design, arsenic-free display glass and recyclable packaging are just a few of the environmentally conscious details built into the display.
  • Peace of mind, with HP
    HP protection includes a 3-year parts, labor, and onsite service standard limited warranty.Select optional HP Care Pack Services to extend service contracts beyond the standard warranties.
HP U160 - LED monitor - 15.6" - Smart Buy
LED-backlit LCD monitor - 15.6"
Panel Type
TN
Aspect Ratio
16:9
Native Resolution
1366 x 768 at 60 Hz
Pixel Pitch
0.252 mm
Brightness
180 cd/m²
Contrast Ratio
500:1
Response Time
12 ms
Colour Support
262,144 colours
Colour Gamut
60%
Input Connectors
USB
Display Position Adjustments
Tilt
Screen Coating
Anti-glare
37.7 cm x 2.6 cm x 27.85 cm
1.54 kg
English / United Kingdom
Manufacturer Selling Program
HP Smart Buy
Environmental Standards
ENERGY STAR Qualified
Plug and Play, VCCI, C-Tick, BSMI, GOST, cUL, SABS, SASO, CB, CCC, PSB, FCC, C-ETL, RoHS, IEC 60950-1, KCC, WEEE, Green Mark, ICES, S Mark, TUV Bauart, KC, CECP, CEL, Nordic Ecolabel, GOST-R 50377-1992, NOM-019-SCFI-1998
Display Type
Diagonal Size
15.6"
Panel Type
TN
Aspect Ratio
16:9
Native Resolution
1366 x 768 at 60 Hz
Pixel Pitch
0.252 mm
Brightness
180 cd/m²
Contrast Ratio
500:1
Colour Support
262,144 colours
Colour Gamut
60%
Response Time
12 ms
Vertical Refresh Rate
60 Hz
Horizontal Refresh Rate
47.712 kHz
Video Bandwidth
76.4 MHz
Horizontal Viewing Angle
90
Vertical Viewing Angle
65
Screen Coating
Anti-glare
Backlight Technology
LED backlight
Colour Temperature
6500K
37.7 cm x 2.6 cm x 27.85 cm - with stand
1.54 kg
USB 2.0
Mechanical
Tilt
Tilt Angle
+15/+45
1 x USB power splitter cable - 1.5 m
Backlight Life
15,000 hours
HP Smart Buy
Power Consumption (Typical)
5 Watt
Included Software
Drivers & Utilities
Microsoft Windows 7 Professional (32/64 bits)
Dimensions & Weight Details
With stand - width: 37.7 cm - depth: 2.6 cm - height: 27.85 cm - weight: 1.54 kg , Without stand - width: 37.5 cm - depth: 1.45 cm - height: 27.13 cm
Sustainability Information
ENERGY STAR Certified
5 °C
35 °C
20 - 80% (non-condensing)
