HP Thunderbolt Docking Station 120W
Quicklinx: DRGQWS00 Mfr#: 2UK37ET#abu
Reinvent docking and boost productivity with our most versatile Thunderbolt dock, the small, sophisticated HP Thunderbolt Dock G2. Designed for workspace flexibility and network manageability, it delivers USB-C device connectivity and optional integrated audio.
  • Command your workspace from a single Thunderbolt 3 (USB-C) connection
    Connect the included cable to your notebook to access a wired network, data, video, and charging with a dock that supports both HP and non-HP Thunderbolt and USB-C notebooks.
  • Reset your perception
    Reclaim your work area with this space-saving centerpiece that helps create a clean desk. Its elegant, black, rounded design with smooth accents changes everything you thought you knew about docks.
  • Manage your enterprise fleet like a boss
    Help IT easily secure and remotely manage a wide range of HP notebooks and the dock with advanced network manageability features built into the dock, including WoL and MAC address pass-through in all power states and PXE Boot.
HP Thunderbolt Dock G2 - docking station - VGA, DP, 2 x DP - 10Mb LAN
Docking station
Video Interfaces
VGA, DP, 2 x DP
9.8 cm x 9.8 cm x 6.9 cm
800 g
English / United Kingdom
Ethernet
Power adapter 120 Watt Power Provided
1-year warranty
Docking station
9.8 cm
9.8 cm
6.9 cm
800 g
Ethernet
3 x SuperSpeed USB 3.0 - 9 pin USB Type A , 1 x USB-C , 1 x headphone/microphone combo jack - mini-phone 3.5 mm , 1 x display / video / USB - Thunderbolt , 1 x network - Ethernet - RJ-45 , 1 x display / video - DisplayPort - 24 pin USB-C , 1 x display / video - VGA - 15 pin HD D-Sub (HD-15) , 2 x audio / video - DisplayPort - 20 pin DisplayPort
1 x USB-C cable - 70 cm
Security lock slot (cable lock sold separately), charging via USB, LED indicator
Security Slot Type
Kensington security slot
Power adapter
Power Provided
120 Watt
Limited warranty - 1 year
35 °C
