HP Thunderbolt Docking Station 120W
Quicklinx: DRGQWS00 Mfr#: 2UK37ET#abu
Type: Docking Stations
Colour: Black
More than 50 in stock
£184.47 ex VAT
£221.36 inc VAT
Reinvent docking and boost productivity with our most versatile Thunderbolt dock, the small, sophisticated HP Thunderbolt Dock G2. Designed for workspace flexibility and network manageability, it delivers USB-C device connectivity and optional integrated audio.
  • Command your workspace from just one USB-C connection
    Connect a single USB-C cable to your notebook to access a wired network, data, video, and charging with a dock that supports both HP and non-HP Thunderbolt and USB-C notebooks.
  • Reset your perception
    Reclaim your work area with this space-saving centerpiece that helps create a clean desk. Its elegant, black, rounded design with smooth accents changes everything you thought you knew about docks.
  • Manage your enterprise fleet like a boss
    Help IT easily secure and remotely manage a wide range of HP notebooks and the dock with advanced network manageability features built into the dock, including WoL and MAC Address Pass-Through in all power states and PXE Boot.
  • Maximize your multi-tasking
    See every color and detail of your projects with a superfast connection to dual external 4K displays as soon as you plug your notebook into the dock.
  • Now hear this
    Take calls without a headset with our first Thunderbolt dock with an audio conferencing solution. The optional HP TB Dock Audio Module attaches vertically to the dock with no cabling.
  • Lock it down
    Secure the base dock to a desk, table or your notebook through the lock slot with an optional HP lock.
HP Thunderbolt Dock G2 - docking station - VGA, DP, 2 x DP
Docking station
Video Interfaces
VGA, DP, 2 x DP
9.8 cm x 9.8 cm x 6.9 cm
800 g
English / United Kingdom
Ethernet
Power adapter 120 Watt
1-year warranty
Elite x2; EliteBook 735 G5, 735 G6, 745 G5, 745 G6, 755 G5, 830 G5, 840 G6, 840r G4, 850 G5, 850 G6; EliteBook x360; Mobile Thin Client mt45; ProBook 430 G6, 445r G6, 44X G6, 455r G6, 45X G5, 45X G6, 640 G5, 64X G4, 650 G4, 650 G5; ProBook x360; Spectre x360; ZBook 14u G5, 14u G6, 15u G5, 15u G6
Docking station
9.8 cm
9.8 cm
6.9 cm
800 g
Ethernet
3 x SuperSpeed USB 3.0 - 9 pin USB Type A , 1 x USB-C , 1 x headphone/microphone combo jack - mini-phone 3.5 mm , 1 x display / video / USB - Thunderbolt , 1 x network - Ethernet - RJ-45 , 1 x display / video - DisplayPort - 24 pin USB-C , 1 x display / video - VGA - 15 pin HD D-Sub (HD-15) , 2 x audio / video - DisplayPort - 20 pin DisplayPort
1 x USB-C cable - 70 cm
Security lock slot (cable lock sold separately), charging via USB, LED indicator
Security Slot Type
Kensington security slot
Power adapter
Power Provided
120 Watt
Limited warranty - 1 year
35 °C
HP Elite x2 1012 G1, 1012 G2, 1013 G3, G4 , HP EliteBook 1040 G4, 735 G5, 735 G6, 745 G5, 745 G6, 755 G5, 830 G5, 840 G5, 840 G6, 840r G4, 850 G5, 850 G6 , HP EliteBook Folio 1020 G2, G1 , HP EliteBook x360 1012 G2, 1020 G2, 1030 G2, 1030 G3, 1030 G4, 1040 G5, 1040 G6, 830 G5, 830 G6 , HP Mobile Thin Client mt45 , HP Pro x2 612 G2 , HP ProBook 430 G4, 430 G5, 430 G6, 440 G4, 440 G5, 440 G6, 445 G6, 445r G6, 450 G5, 450 G6, 455 G5, 455 G6, 455r G6, 470 G5, 640 G4, 640 G5, 645 G4, 650 G4, 650 G5 , HP ProBook x360 440 G1 , HP Spectre x360 15-ch006tx , HP ZBook 14u G5 Mobile Workstation, 14u G6 Mobile Workstation, 15u G5 Mobile Workstation, 15u G6 Mobile Workstation
HP Thunderbolt Docking Station 120W Bundle deal on HP Thunderbolt Docking Station 120W
£283.64
Colour: Black
Brand: HP
Price Range Ex VAT: 150 - 300
