Reinvent docking and boost productivity with our most versatile Thunderbolt dock, the small, sophisticated HP Thunderbolt Dock 120W G2 with Audio Module. Designed for workspace flexibility and network manageability, it delivers USB-C device connectivity and audio.
Command your workspace from just one USB-C connection
Connect a single USB-C cable to your notebook to access a wired network, data, video, and charging with a dock that supports both HP and non-HP Thunderbolt and USB-C notebooks. -
Reset your perception
Reclaim your work area with this space-saving centerpiece that helps create a clean desk. Its elegant, black, rounded design with smooth accents changes everything you thought you knew about docks. -
Manage your enterprise fleet like a boss
Help IT easily secure and remotely manage a wide range of HP notebooks and the dock with advanced network manageability features built into the dock, including WoL and MAC Address Pass-Through in all power states and PXE Boot. -
Maximize your multi-tasking
See every color and detail of your projects with a superfast connection to dual external 4K displays as soon as you plug your notebook into the dock. -
Now hear this
Take calls without a headset with the included Audio Module that attaches vertically to the dock with no cabling. -
Lock it down
Secure the base dock to a desk, table or your notebook through the lock slot with an optional HP lock.
- HP Thunderbolt Dock G2 with Audio Module - docking station - USB-C - VGA, 2 x DP - 1GbE
- Product Type
- Docking station
- Docking Interface
- USB-C
- Video Interfaces
- VGA, 2 x DP
- 9.8 cm x 11.4 cm x 9.8 cm
- 910 g
- Black
- Localisation
- English / United Kingdom
- Audio Output
- Speaker(s) - stereo
- Networking
- Gigabit Ethernet
- Power
- Power adapter 120 Watt Power Provided
- 1-year warranty
- Product Type
- Docking station
- 9.8 cm
- 11.4 cm
- 9.8 cm
- 910 g
- Enclosure Colour
- Black
- Localisation
Video
- Max Resolution Details
- 5120 x 2880 - 60 Hz (DisplayPort or Thunderbolt or USB-C (DisplayPort 1.3 Thunderbolt host))
Audio
- Audio Output
- Speaker(s)
- Sound Output Mode
- Stereo
- Data Link Protocol
- 1 x USB-C with Power Delivery (15 W) , 1 x SuperSpeed USB 3.0 (powered) - 9 pin USB Type A , 1 x audio - headphones/microphone - mini-phone 3.5 mm , 1 x Thunderbolt , 1 x USB-C / DisplayPort with Power Delivery (15 W) , 2 x audio / video - DisplayPort - 20 pin DisplayPort , 1 x display / video - VGA - 15 pin HD D-Sub (HD-15) , 2 x SuperSpeed USB 3.0 - 9 pin USB Type A , 1 x network - RJ-45
- Input Device
- Two microphones
- Cables Included
- 1 x USB-C cable - 70 cm
- Security lock slot (cable lock sold separately), wake on LAN, LED indicator, volume control, MAC address pass-through, 4 monitor support, pick up / accept / hold call control, microphone mute control, hang up / decline call control
- Security Slot Type
- Kensington security slot
- Power Device
- Power adapter
- Power Provided
- 120 Watt
- OS Required
- Apple MacOS, Google Chrome OS, Microsoft Windows 7 / 10
- Limited warranty - 1 year
- 0 °C
- 35 °C
