Your basket is empty
HP Thin Client/USDT Mount Kit
Quicklinx: 9R9GWS00 Mfr#: E5J35AA
Attach your HP Thin Client or USDT PC to the back of select HP Z Displays and maintain optimal ergonomic adjustability with the HP Thin Client Mount Kit.
HP thin client to monitor mounting kit
Thin client to monitor mounting kit
Package Content
Monitor stand
11.1 cm x 57.78 cm x 23.53 cm
445 g
HP Elite 8300, t5740, t5740e, t5740w; EliteDesk 800 G1; Flexible Thin Client t520, t610 PLUS; Workstation Z2 Mini G3 Entry, Z2 Mini G3 Performance; Z Display Z24i, Z27i, Z30i; Zero Client t310
Package Content
Monitor stand
11.1 cm
57.78 cm
23.53 cm
445 g
24.3 cm x 12 cm x 7 cm / 0.6 kg
HP t5740, t5740e, t5740w , HP EliteDesk 800 G1 , HP Flexible Thin Client t520, t610 PLUS , HP Workstation Z2 Mini G3 Entry, Z2 Mini G3 Performance , HP Z Display Z24i, Z27i, Z30i , HP Zero Client t310 , HP Compaq Elite 8300
