HP t820 Flexible Thin Client Intel Core i5-4570S 4GB 16GB Windows Embedded 8 Standard x64
Quicklinx: BCY1WS00 Mfr#: F0U80EA#ABU
Processor Type: Core i5
Operating System: Windows Embedded 8 Standard x64 Edition
Installed Memory: 4GB
Hard Drive Capacity: 32GB
Storage Type: SSD
  • Core i5
£724.78 ex VAT
£869.73 inc VAT
HP's most powerful thin client is the full-featured solution to boost efficiency and performance. Get a responsive, smooth desktop experience from a superfast processor. Robust security options deliver superior data protection. Enable cost-effective, remote IT management – and simplify deployments – with the flexibility of a multi-protocol environment. Multiple monitors expand multitasking.
  • Fast or faster – your choice
    Propel performance with powerhouse processing. Work smoother and quicker, with two superfast CPUs to choose from - and brilliant, seamless graphics.Count on powerful performance fast enough for the most demanding applications – the Intel Core i5 processor delivers accelerated graphic rendering and multimedia.When demanding applications need strong performance and a seamless multimedia experience choose the Intel Pentium processor.
  • Keep business classified
    Keep your business data safe – lock down sensitive information and meet compliance standards with robust encryption and security options, including fiber NIC, TPM, and Intel vPro technology.
  • The versatility of virtual
    Give IT the advantage of flexibility with a multi-protocol environment. Simplify deployment and manageability – and enable a seamless desktop experience – with the versatility of client virtualization.Improve network performance and the end-user experience with HP Velocity software.Count on a seamless IT experience with the flexibility of a multi-protocol environment – Citrix, Microsoft, VMware or HP Remote Graphics Software.
  • Business productivity
    Outstanding multitasking efficiency. Enterprise-class monitor support of up to three Full HD monitors (1920 x 1200), or two 30-inch diagonal monitors (2560 x 1600).Don't stop with the thin client. Create a complete solution that's supported by HP. Choose from a full suite of HP displays, accessories, and software.Realize real savings while reducing operating expenses. From less downtime and fewer automatic updates to decreased hardware and operating costs – it adds up to a lower total cost of ownership.
  • Manageability
    Make it simple to consolidate configurations and speed up deployments with HP Easy Tools – the solution to get new locations up and running even faster.Simplify remote device management – empower IT staff to make the most of their resources. Remotely control thousands of thin client devices to help reduce the need for hardware and software maintenance and upgrades.
HP Flexible t820 - tower - Core i5 4570S 2.9 GHz - 4 GB - 32 GB
Thin client - tower
Platform Technology
Intel vPro Technology
1 x Intel Core i5 (4th Gen) 4570S / 2.9 GHz (3.6 GHz) (Quad-Core)
Cache Memory
6 MB
Cache Per Processor
6 MB
RAM
4 GB (installed) / 16 GB (max) - DDR3 SDRAM - non-ECC - PC3-12800
Flash Memory
16 GB
Hard Drive
1 x SSD 32 GB - SATA 6Gb/s
Optical Storage
No optical drive
Graphics Controller
Intel HD Graphics 4600 Dynamic Video Memory Technology
Audio Output
Stereo - integrated
GigE
OS Provided
6.6 cm x 25.4 cm x 25.2 cm
3.1 kg
Limited warranty - 3 years
Platform Technology
Thin client
Recommended Use
Small business, corporate business
Product Form Factor
Tower
Built-in Devices
Speaker, solenoid hood lock
Embedded Security
Trusted Platform Module (TPM 1.2) Security Chip
Processor / Chipset
CPU
Max Turbo Speed
3.6 GHz
Number of Cores
Quad-Core
CPU Qty
1
Max CPU Qty
1
CPU Upgradability
Upgradable
Chipset Type
Intel Q87 Express
Cache Memory
Installed Size
6 MB
Cache Per Processor
6 MB
RAM
Installed Size
4 GB / 16 GB (max)
Effective Memory Speed
1600 MHz
Rated Memory Speed
1600 MHz
Memory Specification Compliance
PC3-12800
SO-DIMM 204-pin
Slots
2 (Total)
Flash Memory
Flash Memory
16 GB
Hard Drive
SSD
1 x 32 GB
Interface Type
SATA 6Gb/s
Optical Storage
No optical drive
Monitor
Monitor Type
None.
Graphics Controller
Integrated
Graphics Processor
Video Interfaces
VGA, DisplayPort
HDCP compatible
Max Monitors Supported
3
Audio Output
Integrated
Sound Output Mode
Stereo
Max Sampling Rate
192 kHz
High Definition Audio
Input Device
Mouse, keyboard
Keyboard
Keyboard Name
HP Standard Keyboard
USB
Ethernet Controller
Intel I217-LM
Remote Management Protocol
ASF 2.0
Wake on LAN (WoL), PXE support, auto-uplink (auto MDI/MDI-X)
IEEE 802.2, IEEE 802.3, IEEE 802.3u, IEEE 802.1Q, IEEE 802.3ab, IEEE 802.1p, IEEE 802.11d, IEEE 802.11i, Wi-Fi CERTIFIED, IEEE 802.11h, IEEE 802.11e, IEEE 802.3az
Slots
1 (total) / 0 (free) x mSATA , 2 SO-DIMM 204-pin , 1 (total) / 0 (free) x PCIe Mini Card , 1 (total) / 1 (free) x MXM
6 x USB 2.0 (2 front, 4 rear) , 4 x USB 3.0 (2 front, 2 rear) , 1 x PS/2 keyboard , 1 x PS/2 mouse , 1 x VGA , 2 x DisplayPort , 1 x audio line-out/headphones (1 in front) , 1 x audio line-in/microphone (1 in front) , 1 x audio line-in , 1 x audio line-out , 1 x LAN (Gigabit Ethernet)
Power-on password, USB port control, Setup Password
Theft/Intrusion Protection
RoHS, WEEE
TAA Compliant
Power adapter
Nominal Voltage
Power Provided
135 Watt
Efficiency
87%
Operating System / Software
OS Provided
Software
Citrix ICA, Microsoft RDP, Microsoft Firewall, HP Universal Print Driver, HP ThinState Tools, Citrix XenDesktop Standard Edition, Microsoft Windows Media Player 12, HP Easy Tools, File Based Write Filter, Enhanced Write Filter, HP Device Manager, Microsoft Internet Explorer 9.0, HP TeemTalk Terminal Emulator 7.3, LogOn Manager, Citrix HDX, HP Velocity, HP Remote Graphics Software 6, Microsoft RemoteFX, Citrix Receiver 4.0, VMware Horizon View 5.3, HP Cloud Connection Manager
6.6 cm
25.4 cm
25.2 cm
3.1 kg
10 °C
35 °C
10 - 90% (non-condensing)
HP t820 Flexible Thin Client Intel Core i5-4570S 4GB 16GB Windows Embedded 8 Standard x64 Bundle deal on HP t820 Flexible Thin Client Intel Core i5-4570S 4GB 16GB Windows Embedded 8 Standard x64
£911.24
saving £8.33
£824.54
Storage Type: SSD
Processor Model: I5-4570S
Type: Thin client
Case Style: Tower
Display: no
Optical Storage: None
Brand: HP
Price Range Ex VAT: 500 - 750
